Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door sensors out of alignment
I have one green light and one yellow light on my garage door sensors which is causing my garage door not to raise all the way up, it currently only goes up about a foot, then stops. How do I get both light green again?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
The lights are suppost to be yellow (power to photo eyes) and green (lined up).
 1.Check to see if the door is running correctly.
  A. Run the door down and pull the emergency release. See if the door will run easily by itself.
  1. If it runs hard by hand try lubricating the rollers and hinges with silicone spray or some form of lubricant (not WD 40)
  2. If the door is heavy and falls back to the ground, you probably have a spring issue (either broken or needs more tension) in this case call a professional door repair company in your area.
  B. If the door runs fine then check the up force on your operator (the box that hangs from the ceiling). If the light bulb(s) on your operator are on the front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
Posted on Jan 10, 2009
Why is the sensor light yellow on my craftsman 3/4 hp garage door opener?
Because you have power to it! If properly aligned, the other one will be green.
Jun 05, 2014 | Craftsman 3/4 Hp Garage Door Opener System...
Door suddenly will not close without holding the button down continuously that is inside the garage. The remote button will open the door but not close it. The door starts to close and stops right away.
It definitely sounds like a sensor problem. In normal operation, one sensor will have an amber or yellow light on, indicating power to the sensing circuit. The opposite sensor should have a green light on. If the yellow light is not on there is no power to the circuit due to a broken wire or circuit board failure. If the green light is not on or is flickering, the sensors are not aimed at each other or the light path is blocked.
Aug 04, 2011 | liftmaster Garage Door 1/2 Hp
DOOR CLOSES MOST OF THE WAY AND THEN OPENS. LIGHT THEN BLINKS TEN TIMES. I NOTICED THAT ONE SAFETY SENSOR IS GREEN AND ONE IS YELLOW. PLEASE ADVISE.
Hi. The sensor with the yellow light is telling you that it is miss-aligned, Usually it only takes getting bumped to knock them out of alignment.
I would slowly turn or adjust the positioning of the sensor.
The one with the yellow light should turn green when it is all the way in line so that the beam is completing it's path.
It's out of adjustment, so the sensor is looking at it like there is an object blocking the door from closing.
It's called the obstruction sensor.
It's there as a safety feature, so that the door doesn't come down and smash anything in the opening.
I hope this helps you out.
Feb 04, 2011 | liftmaster Garage Door 1/2 Hp
We can't close our garage door
Make sure neither light on the sensors is flickering. Tweak them a bit to make sure they are aligned properly.
May 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 41A5389 won't shut
it has to be aligned with its mating optical sensor on the other side of the door. try adjusting it until you get a green light.
Aug 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP garage door opener with one green and one yellow
It sounds like a logic board problem to me. I would remove the board and look for bad connections especially around that small transformer.
Aug 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
One of my garage door sensors is yellow while the other is green.
It means your sensors are properly aligned. Are you having a problem?
Jun 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door sensor light on one is green the other yellow. When they are lined up one stays yellow and one is green. When I point the yellow sensor away from the other one the green goes off. Do you think...
They are doing what they are designed to do. To work properly they must be pointed at one another and to tell when they are aligned the light on the receiving unit turns on.
Jun 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
6 month old garage door will work.
On the back of the opener near where all those white wires go you will find 2 controls. One is labeled "up force." Increase this about 1/4 turn.
May 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,260 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
