Question about Maytag MDE6000 Dryer
Maytag dryer MDE6000 is only blowing cold air.
It is only blowing cold air. there is no heat. what could this be? It is a Maytag MDE6000 AYW
Style: (y) 7875516
Maytag Intellidry
    Scholar:
  • 47 Answers
Electric dryers run on 220 volt, it is usually a double breaker at your main panel, however, depending on the electrician and how old the wiring is you might have two breakers, so start there first. If not, there are several parts to this dryer. It could be an element, a thermal fuse, high limit thermostat, or as simple as a burnt wire. Most important please turn off power before working on this.
The other thing that most people forget to check is the outlet pipe or vent pipe. If they get blocked, when the heat turns on, and it is blocked, the dryer will detect it and immediately turn off the heat but the drum will still turn. Bed Bath and Beyond has a dryer vent clean out kit that hooks to a shop vac.
Posted on Jan 09, 2009
  • Ron Jan 09, 2009
    Most important I forgot the timer to, I am sorry.
Maytag dryer MDE9700 AYW We replaced the dryer heating element and the dryer still don't heat can anyone help me figure what parts I need
http://www.appliancepartspros.com/01-blower-heater-parts-for-maytag-mde9700ayw.html 14 and 15
Jan 12, 2016 | Maytag Dryers
The heating element connects to a thermal fuse and then to a thermostat. The thermal fuse may be blown. There is no outward sign of failure http://www.appliancepartspros.com/01-blower-heater-parts-for-maytag-mde9700ayw.html
14 and 15 on the diagram
My Maytag electric dryer model# MDE 4658 AYW does not dry my clothes (no heat) and the light no longer stays on when the dryer door is open. started happening after i turned all fuses off in the house. can...
I gotta assume you're joking since it looks like you're asking why the dryer isn't working when you've turned all the power off in your house.
If this is the case then the only way your dryer is going to function is if you bought it with the optional Maytag Cold Fusion power supply. Or you could turn the power back on...
Oct 30, 2013 | Maytag Dryers
Maytag dryer model 6000AYW overheats
Probably due to a bad blower wheel. The wheels on these are made of plastic. Over time the wobble out and don't blow enough air.
Home movie of repair:
Oct 15, 2012 | Maytag MDE6000 Dryer
I have a MAYTAG MDE6000AYW Series Dryer. It does not heat up, it makes no noise, tumbles, and the lights work, what can I do to solve the no heating problem with the dryer?
the heating coil needs fixing you can fix it yourself but try a repair man first allot of them come too your home and fix them so choose your repair guy wisely...
Apr 12, 2011 | Maytag MDE6000 Dryer
Dryer won't heat maytag neptune mde 5500 ayw
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
No Exhaust? Very Damp-not dry clothes
i would check for further blockage. also check the blower fan to make sure it is blowing properly. sometimes the blower fan can wear on the motor shaft and slip, thus reducing the air flow considerably. sometimes i have found the blockage just at the point of the blower fan.
good luck; jay
Jan 04, 2010 | Maytag MDE6000 Dryer
No heat
probably just the heating element. If that isn't it, you might have a bad moister sensor. It tells the dryer to stop heating once the clothes are dry. My first suggestion is to check the heating element, they go out all the time. Usually there is just a tall narrow cover of them, so you can check them without disassembling the whole back of the dryer. Goodluck
Sep 13, 2009 | Maytag MDE6000 Dryer
Maytag dryer MDE6000AYW keeps blowing the fuse in the panel box, what is wrong? I reset the fuse in the panel box and turn the dryer right back on and it will start right back up. It may or may not blow...
Bad breaker in the panel box.Loose wires at the breaker. Loose connection in the wall outlet. Loose connection at the dryer cord terminal. Bad cord.
One or more of the above.
Jul 05, 2009 | Maytag MDE6000 Dryer
Blows only cold air
Check connection to heating elements. My have bad heating elements
Jan 19, 2009 | Maytag Neptune MDE6800 Electric Dryer
Dryers Logo
530 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
