Question about Cobra 29 WX NW ST 40-Channels Base CB Radio
Im looking for a plug to put in a wall socket and im trying to use an older cobra29 cb radio. Can you help?
  • 32 Answers
Hey AlexJacob
a mobile cb radio like the cobra 29 requires 12V DC, to plug the radio into the wall you need a Power Supply. A small 5 amp power supply will help you. Their is no plug that goes Directly from a Mobile CB rado into a wall. You will need to plug a power supply into the wall, Then take the power chord (red and black with 3 prong [o oo] and connect red to red on the power supply and black to black on the power supply. Unfortunatly a cheap power supply will be $50+ check your local radioshack
Posted on Jan 11, 2009
SOURCE:
Broken wire on sf/swr meter cobra29 ltd
first it was an orange wire nows it a red wire.Take the wire in hand and stretch it out. Look for a WR post and see if it has a wire in it .If it doesn't thats probably the spot.
Apr 29, 2014 | Cobra Radio Communications
Please help me with my problem i dont hear nothing on my cb home base radio
Did you turn it on? Is it plug into the wall socket ? Make sure its on CB not PA. Check to make sure its plugged into the back of the radio ,you should be good to go.
Nov 11, 2012 | Radio Communications
D-104 wiring to a cobra cb
Find your radio on this page and then look at the wiring diagrams
Oct 11, 2012 | Astatic D104 T - Ug8 Crystal Microphone...
When i hook up my cobra29 LTd to my pickup it keeps blowing fuses. What do i need to do or whats wrong.
HI, my name is John. Red to hot fuse under dash or battery and black to ground hope this was helpful.... good luck John
Oct 08, 2010 | Cobra 29 LTD CB Radio
Hello, I dusted off my old Cobra 2000 GTL and plugged it into the wall and it will not power on. The clock is on and adjustable. It was last working before I boxed it up a few years back. Is this a known...
Try this, plug it all up and turn it on, let it set over night, then try it, after a radio has been put away for a while, the capacitors lose charge...hope this was helpful....
May 09, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
I have a cobra29 wx nw st. its been peaked and tuned, an echo board installed, and soundtracker override when i key up if my mic gain is over 1/4 the way up it makes an awful racket what do i do?
is there talk back installed? if so its probably too loud. You are getting feed back. The talk back should be low, just enough to hear it to check echo. 470 ohm resistor is perfect.
Jan 04, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
My CB radio is bust
Check The Microphone Connections In the Plug On Mic wire could be off Or try another Mic. go to www.cbtricks.com look under cobra 89gtl or cobra 1000gtl both have the same board in them.
Feb 12, 2008 | Radio Communications
Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
109 people viewed this question
Top Cobra Radio Communications Experts
Steve Allison
Steve Allison
Chris
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
