Question about WYSE Winterm 3235LE Network Terminal
Wyse wt3235le running on windows 2000 server
After I did a netxfer flash the screen size change back to default I have change this before and forgot the steps to increase the screen resolution for the desktop. thanks steve
  • 12,061 Answers
OK What ya do is right click the desktop and go down to properties.. open this and there ya should be able to adjust ya resoloution and colour... It's max is 1024 x 768.
Posted on Jul 31, 2007
Tip
Reset a WYse WT3235LE back to Factory setting.
Hold down the G key when powering on and during the booting process to reset it back to factory settings. You can also do this in Control Panel under System.
NOTE: The G key trick is very picky so make sure you hold the G key before you press the power button and until it is booted. Also don't be frustrated if it doesn't work the first time.
on Feb 06, 2009 | WYSE WT3235LE (902032-68) Network Terminal
Wyse 1200LE - error - out of frequency
This is caused by the terminals default display resolution (or the resolution that it was set to in its previous environment). The easiest way to get a display, would be to use a different monitor with a higher range of supported resolutions.
Fingers crossed the previous wnos.ini file would allow a G-key reset. If so, just hold down the G key when the terminal is booting, and it will reset to factory defaults. This might allow your monitor to work. (I think the default resolution is 800x600)
The problem you have is that the terminal might be locked down via the .ini file. So changing the configuration might be difficult. You could use a program like Wireshark to perform a network trace, this would tell you where the terminal is looking for it its wnos.ini file.
Then you will be able to setup a new wnos.ini on an FTP server set to the IP address(and path) the terminal is looking for, and this will allow you to set your own configuration.
May 28, 2009 | WYSE Winterm S30 Network Terminal
Orange Light, Will not boot When Powering on Wyse WT325LE
go on line and type in the following information:
motherboard manufacture, nake, model, and orange light comes on
enter
see if anyone else had that same problems
rod
Wyse v90l
Best thing to do here is a re-image the client using the tools on the Wyse website.
The new USB imaging tool is pretty handy at imaging this model, and should get this back to a default image and working very quickly :)
Jan 14, 2009 | WYSE V90LE Thin Client VIA 1.2GHz, 1GB...
Does other terminal emulation VT220/VT100 work on WYSE?
vt220 on wyse
Sort of but f3 and f4 wont work and f1 would be ctrl + o
Dec 11, 2008 | WYSE WT3235LE (902032-68) Network Terminal
WYSE 3235 thin client needs bios flashed
The easiest way to would be to take apart the machine so that the motherboard is exposed. Once you do, you will see a small, circular watch-like battery. Remove this for about 15-30 seconds. By doing so, it will perform a hard restart when the BIOS memory is cleared and you will have your original factory settings. If this does not work, consider the ports/card for the peripherals. Perhaps it is a hardware problem.
Dec 01, 2008 | WYSE Winterm 3235LE (90202401R) PC Desktop
Conection to Microsoft Windows 2003 server terminal server
G key reset the unit, or failing that, re-image the device, and then setup your RDP connection from the default desktop.
Jul 09, 2008 | WYSE WT3235LE (902032-68) Network Terminal
Howto add a network printer on Wyse winterm S30 terminal?
The S30 terminal has the CE 5.0 operating system loaded as default. So you are limited by the operating system and not the hardware when it comes to network printing.
Here is a extract of the release notes for Windows CE 5.0:
"In Windows CE, TCP/IP supports network printing through the Server Message Block (SMB) protocol. It does not provide the Windows Line Printer Remote (LPR) Spooler. However, independent software vendors (ISVs) and original equipment manufacturers (OEMs) can add this support."
In short, you need a 3rd party software program or a (SMB) printer server setup to setup network printing on the S30 terminal..
Wyse also have add-on software to help, if you have CE 5.0 loaded then try the "Thinprint" add-on supplied as a free download by them.
Download Link:
http://www.wyse.com/supportdownload/3series/Addon_ThinPrint_B0010.exe
I haven't tried this, so let me know if it works.
May 02, 2008 | WYSE Winterm S30 Network Terminal
No display in monitor
This may be the problem with the WYSE driver. Ensure that correct driver is intalled and colour profile is compitable. Syncmaster is auto detected by window based OS.the message "Sync out of range" comes due to improper out put video signal.
Jul 24, 2007 | WYSE Winterm 3235LE Network Terminal
WYSE Winterm 3235LE Network Terminal Logo
262 people viewed this question
Top WYSE Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
Edward Greene
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
