Question about HP Photosmart C7280 Printer
Wireless problem setup/ What is WEP?
Hi, I get as far as the HP Photosmart C7280 ALL-IN-ONE recognizing my router, then the machine asks me for a WEP KEY and I am sent to a keypad page, I have no Idea what it is asking for and have tried many different combinations of possibie keys, don't know what it is, so can't continue my setting up my laptop to the PHOTOSMART!!!
This is really NOT funny, Why can't this be more user friendly, so I can put the thing to the use it was intended?
Please tell me WHAT IS A WEP KEY??? HOW do I find a WEP KEY?? HELP ME SET THIS THING UP SO MY HUSBAND IS A HAPPY CAMPER, PLEASE???!!!
  • 1 more comment
  • janineh_9202 Jan 09, 2009
    this didn't work, I tried and this number was unacceptable, so I went to start and put in CMD, got a whole lot of messages after putting in arp, and ipconfig, but, not the right one, how do I know what number is to be used for the WEP KEY needed for all my wireless ID needs?
  • debbiejoi Mar 29, 2009
    I bought a photosmart c7280 printer and I am trying to connect it to my home wireless network. When I use the Network wireless wizard on the printer, it does locate my network. The problem I have is when I highlight my network name and push enter, it doesn't go to the input WEP key screen. It gives me the message: Error. Can not connect to the network. Unsupported authentication or security type. What does this mean. I have a D-link router that I have a 64 bit wep key enabled. On this particular router I can not change security type. Shared or open. I am assuming the default is open, but again when I set it up there was no place that asked me to choose.
  • Anonymous Apr 03, 2009
    cannot get my HP printer to connect to my wireless network, continues to ask for wep key
  • 181 Answers
The WEP or WPA is the password to get onto the network. Think of the router as the doorman. The printer needs to get into the club so it needs the password otherwise it can't get access.
The WEP key and WPA passphrase are obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with your router to see how to access this information. Some routers provide more than one WEP key. Use the first WEP key if this is the case.
Posted on May 18, 2009
    President:
  • 2,559 Answers
It is the security key used for your wireless router.
When you set up any device to connect to the wireless router you will need it.You should be able to go on you computer,open internet explorer,and type 192.168.1.1 to get to your router page to see all the info needed.
Posted on Jan 09, 2009
  • Randy Hough
    Randy Hough Jan 09, 2009
    If you go to network and internet connections on your computer and right click on the local area connection and click status and then details,look for default gateway.That is the number need to get to the router page.you have to get to the router page for the WEP key
    Problem Solver:
  • 11 Answers
Installing the HP All-in-One in a Wireless Network (Infrastructure Mode) Introduction This document contains instructions for installing the product in a wireless network using a wireless WLAN 802.11 router. Connecting network elements through an access point, such as a router, is referred to as setting up in an infrastructure network. NOTE: The solution to this issue includes instructions that might require navigating to another page on the HP Web site. HP recommends creating a bookmark to this page before clicking any links. Figure 1: Integrated wireless WLAN 802.11 network setup wireless problem setup/ What is WEP? - c00718777.gif Installing the unit in an infrastructure network Follow these steps to connect the product to an integrated wireless WLAN network. Step one: Gather the necessary hardware and information Gather the following items and information.
  • A wireless 802.11 network that includes a wireless access point or router
  • A computer connected to the network
  • Internet access
  • A wireless HP product
  • The network name or Service Set Identifier (SSID)
  • If the network is using security, the Wired Equivalent Privacy (WEP) key or Wi-Fi Protected Access (WPA) passphrase NOTE: For help getting wireless network information, click here to go to the HP Network Assistant page. Follow the on-screen instructions to download and install the HP Network Assistant.
Step two: Connect to an integrated wireless WLAN 802.11 network
  1. Make sure that the Ethernet cable is disconnected from the product.
  2. Press the Setup button (c01395353.jpg ) on the control panel display.
  3. Press the down wireless problem setup/ What is WEP? - c00718778.gif(c00718778.gif ) to select Network , and then press OKwireless problem setup/ What is WEP? - c00718778.gifs="h_mi"> Press the down arrow button (c00718778.gif ) to select Wireless Setup Wizard , and then press OK Press the down arrow button (c00718778.gif ) to select the network name (SSID) found in Step one: Gather the necessary hardware and information, and then press OK
  4. Press the down arrow button (c00718778.gif ) to select Enter New Network Name (SSID) , and then press OK . The virtual keyboard, which appears on the control panel display, becomes available.
  5. Use the 4-way arrow button to type the SSID on the virtual keyboard. Select a letter or number on the virtual keyboard, and then press OK to select it. NOTE: Make sure that the uppercase (capital) and lowercase (small) letters are typed exactly as they appear in the SSID. Otherwise, the wireless connection fails.
  6. After the SSID has been cwireless problem setup/ What is WEP? - c00718778.gifss the 4-way arrow buttons to select Done on the virtual keyboard, and then press OK .
  7. Press the down arrow button (c00718778.gif ) to select Infrastructure , and then press OK .
  8. Press the down arrow button ( ) to select WEP encryption or WPA encryption , and then press OK . NOTE: If WEP encryption is not used, press the down arrow button (c00718778.gif ) to select No, my network does not use encryption , and then press OK . Proceed to step 7.
  • Type the WPA or WEP key when prompted to do so.
    1. Use the 4-way arrow button to type the WPA or WEP key on the virtual keyboard. Use the arrow keys to highlight a letter or number on the virtual keyboard, and then press OK to select it. NOTE: Make sure that the uppercase (capital) and lowercase (small) letters are typed exactly as they appear in the SSID. Otherwise, the wireless connection fails.
    2. After the WPA or WEP key has been completed, press the 4-way arrow buttons to select Done on the virtual keyboard.
    3. Press OK to confirm. NOTE: The product will attempt to connect to the netwowireless problem setup/ What is WEP? - c00718778.gifpan>Can not connect to network message appears, make sure that the network key is correct, follow the prompts to correct the key, and then try again.
  • Press the down arrow button (c00718778.gif ) to select Wireless Network Test . The wireless network test page prints. Figure 2: Wireless network test page c01405155.gif
  • Review the Recommendations section and make any appropriate changes.
  • After the product is connected to the network, install the HP software on each computer that uses the network.
  • Posted on Mar 03, 2009
    I have an acer computer with and hp photosmart printer connected to a belkin router what is the wpa passphrase to link them
    on the front panel of the printer press the tool button and look for wireless settings and press ok. under wireless settings look for wireless setup wizard. it will ask for you wep/wpa. it's the same as your wpa when connecting to a wireless router or wifi.
    Mar 23, 2011 | HP Photosmart Premium C309A All-In-One...
    Setting up wirless connection for D110 Photosmart printer. Like everyone else asking for the wep number. Where do we find this?
    WEP or web encyption protocol is the encryption code used to protect wireless systems to stop others "borrowing" your broadband. If you haven't got one set up I suggest you do so. Use letters (upper and lower case mixed) and numbers. This is the code then that you give your printer. Make a not once you add it into your router and keep it safe.
    An example of a WEP could be
    a67DD1iPp84wSq
    Jul 07, 2010 | HP Photosmart C7280 Printer
    Now we have gone wireless how do I set up my printer as wireless.? I have a photosmart C7280 all in one
    a) Locate and write down your wireless router settings:
    Network Name (also called SSID) :_________________________________________
    WEP key/WPA Passphrase (if needed) :_____________________________________
    IMPORTANT :You must have this information available to continue with your wireless setup. HP provides
    a web-based tool called the Wireless Network Assistant [URL: www.hp.com/go/networksetup (English
    only)] that can help retrieve this information for some systems. If the Wireless Network Assistant is unable
    to retrieve your network information, you must consult the documentation for your wireless router, the router
    manufacturer, or the person who originally setup your wireless network.
    b) Press the Setup button on the HP All-in-One. (wrench/spanner symbol)
    c) Press down arrow button until Network is highlighted, and then press OK . The Network Menu appears.
    d) Press down arrow button until Wireless Setup Wizard is highlighted, and then press OK . In a few moments, a list of detected
    networks appears on the display. The network with the strongest signal appears first.
    e) Do one of the following:
    - Press down arrow button to highlight the name of the network that you wrote down earlier.
    - If the network name that you wrote down does not appear in the list, you can enter it manually. Press down arrow button until Enter New Network Name (SSID) is highlighted, and then press OK . Then use the visual keyboard to enter the network name.
    f) If your network uses security, a prompt appears for the WEP key or WPA passphrase. Both are case sensitive. Use the visual keyboard to enter the WEP key or WPA passphrase, as requested.
    Note : If your router provides 4 WEP keys, make sure you use the fi rst one.
    g) Follow the prompts on the display to complete the network setup.
    Visual keyboard tips:
    To Select: use Arrow keys to highlight, and then press OK .
    For mistakes: Select Clear .
    For lowercase: Select abc
    For numbers: Select 123
    For symbols: Select .@!
    When you are finished: Highlight Done , and then press OK .
    Mar 31, 2010 | HP Office Equipment & Supplies
    I am installing a wireless printer to my laptop. it finds my network when i click on it i am asked for a WEP key. I anot sure what they are looking for.
    A WEP key is a security code needed for communication with wireless router so if you don't know that code you cannot connect to router and through the router to printer.
    You can change or view that code by entering in wireless router setup.
    Mar 04, 2010 | HP Photosmart Premium C309A All-In-One...
    Using the HP C7280, lost power and now its asking me to input a WEP #. Where do i get this number?
    Check with your network administrator or the person who installed the Photosmart C7280 on your network.
    A WEP key (in short) is a security code allowing a group of devices to communicate with each other while maintaining privacy from a device outside of the network. Usually a WEP is a string of digits and the letters A-F the length of which is determined by the level of encryption.
    Jan 03, 2010 | HP Photosmart C7280 Laser Printer
    How can I connect my wireless laptop to print wirelessly?
    run the wireless setup wizard on the printer from the front panel menus of the printer...this would assign an IP address to the printer from the router...then use the s/w cd that came along with the printer and get the drivers and s/w installed on your computer....if you want a wireless connection it would give you approprite options
    Jun 21, 2009 | HP Photosmart C7280 Printer
    WEP key fro netgear DG834G v3 WIRELESS ROUTER/MODEM
    Okay, first you will need to access your router (usually 192.168.0.1 or something like that) you will be asked for a user name and password. (admin password respectively if you never set these up previously)
    From there you would click on Wireless Settings and scroll down to WEP Key. Whatever is typed in Key 1 is your WEP key. Write that down. Plug in those numbers for your printer and you should be go to go.
    Mar 21, 2009 | NetGear DG834G 802.11G Wireless ADSL...
    Days to set up Wireless laptop to HP Photosmart C7280 All-in-one
    try this Update the firmware in the wireless router
    http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859761879&packedargs=sku%3DWRT54GS&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=6187961879B01&displaypage=download
    Broadcast SSID(if changing security, you may want to change this)
    Use WPA security(some devices won't work unless WPA security)
    Mixed b and g mode
    use channels 1, 6 or 11. Most devices work better on these channels
    Save and log out restart everything, Routers and computers. Now connect.
    Drivers can be found here
    http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3204785&lc=en&cc=us&dlc=en&submit.y=9&submit.x=10&lang=en&cc=us
    Download them. When you install them, choose network.
    You do have one of these?
    HP Wireless Printing Upgrade Kit
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00783236&lc=en&cc=us&lang=en&rule=5307&dlc=en&product=3204785
    Jan 09, 2009 | HP Photosmart C7280 Printer
    HP Photosmart C7280 Printer Logo
    2,120 people viewed this question
    Ben Johnson
