Question about MediaGear SongBank MP3 Player
ISymphony M110 blows fuse.
Unit is about 6 months old, when you plug in, it blows the 2A? fuse. Replaced fuse and it blows as soon as power is applied. Any help would be appreciated.
  • sgt-alain May 16, 2009
    the transformator in broken i guess and i dont find where to buy it another and the fuse blow up
There is an 022 farad cap right under the f901 f 904 f907 f905 6amp rectifier on the main board if short will blow supply board fuse first before it blows the 4 amp fusses on the main board. replace as needed.
Posted on Jul 27, 2009
Take a big hammer and gentle remove the entire front. Then with same motion with hammer remove the sides and back. Continue this until all pieces have been remove. Then place unit in garbage can with broom and dust pan.
Buy a different make and model.
Problem fixed.
Posted on Mar 09, 2010
I followed meblueyz99's tip and it worked.
Fix the short where he says on the main board first with a soldering gun and a new "222" 50v - ceramic disc capacitor.
The guy at the elctronics tsore said that the one they used looked like a 25v capacitor, which may be why it blows? He said the 50v one would hold up better.
Posted on Nov 06, 2009
Hi, my 6 month old Simpson 5kg Eziloader dryer blew a fuse today. Have plugged it into a different power plug and now its not working and making a humming noise. Any suggestions?
have a service technician come and look the start/run capacitor for the motor
blowing a fuse then humming indicates a capacitator problem
Jul 07, 2015 | Dryers
How do i fix a tricicty bendix dryer
You need to call a technician. If this unit is only 6 months old, it must be under some type of warranty.
May 04, 2015 | Tricity Bendix Washing Machines
WHERE ARE THE FUSES LOCATED IN THE ISYMPHONY M1
Hello
To access the fuse you have to open its main unit. It can be located at the power supply section. It is a glass cartridgetype, press to fit model.
Feb 26, 2012 | iSymphony M1 Shelf System
Is there a fuse inside the grinder to protect it from an electrical surge. I accidentally plugged it into a 220 volt outlet.
My MDF was built in September 1993. It has a fuse inside a black cylindrical fuse holder on the electronics board that sits aside the motor. If you have a right-angle flat blade screwdriver, you can get the fuse out without removing the motor unit from the case. I didn't have the right tool, so I ended up removing the motor/grinder unit from the case to replace the fuse. The fuse is a 2A/250V Slow Blow. I used a Buss CDC-2A to replace the factory "5TT 2A/250V" fuse.
May 09, 2011 | Gaggia MDF Electric Burr Grinder
My polk psw 10 keeps blowing the 2a fuse as soon as i plug it in ? Any solution besides the dump ?
Unplug the power, get inside it and disconnect either lead to the driver; stand back and plug it in to see if that helps. If so, the woofer is shorted and can be replaced failry cheaply. Otherwise it's probably more complicated and expensive for a hands-on tech to isolate the electrical problem.
Dec 23, 2010 | Polk Audio Audio Players & Recorders
Actually iSymphony M110 - it doesn't wont to turn on. Just the stand on red lamp is on and no response on any buttons. Does it has sort of reset button or it should be repaired in service center? Do you...
I just bought one of these "dead" units for $15...I replaced the blown 2A 250V fuse with a new 2A fuse and it blew as soon as I plugged it in so then I took one of the 4A 250V fuses from the other side of the unit(located right behind the speaker output terminals) and it works perfectly now.
Sep 18, 2010 | iSymphony M1 Shelf System
ISymphony M110 no workee
The first question we need to look at is does it still have a warranty?
If not, then have fun.
I did this for my son a couple of months ago.
1. Unplug the unit from it's power source.
2. Remove the back cover and one side cover, opposite the power cord.
3. There are 3 fuses, one located next to the cable inlet and on the right side there are two more, one for each speaker.
4. If you only replace the one fuse, the power may go on, but there might be no sound.
Try it and see.
If there is still no sound, you need to replace the other two.
They are hard to see.
You can get these at any hardware store and replace them yourself.
Jul 21, 2009 | Audio Players & Recorders
Can't find 2A 125v fuse replacement for on-off will 250v be OK?
There is no difference between a 125v and 250v fuse. The most important thing is the 2Amp. This fuse is probably the line fuse and could be the only trouble and may have blow with a line surge. Make sure the 2A you use is a Fast Blow Type. If it does blow again you most likely have a internal power supply failure.
Apr 19, 2009 | Sharp Aquos LC-20B2U 20 in. LCD Television
1989 honda accord headlight fuse blows as soon as replaced
you more than likely have a shorted wire in the headlight harness... you will have to check the wiring from the headlight bulbs to see if it has been pinched up against a sharp metal edge causing a grounded wire, or maybe the harness was crushed by an improper headlight installation.
Jan 12, 2009 | 1989 Honda Accord 4 Door
Blowing fuses
check your car battery and check your ground and check your power wire for any splits or cracks
Nov 22, 2006 | Rockford Fosgate Punch P3002 Car Audio...
MediaGear SongBank MP3 Player Logo
847 people viewed this question
Top MediaGear Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MediaGear Audio Player and Recorder Expert? Answer questions, earn points and help others
