Question about Aiwa HV-MX100 VHS VCR
About VCR power.
Whenever I turn my VCR on the power stays on for few seconds and goes off.
    Novelist:
    Champion:
  • 254 Answers
This often indicates an error condition of some sort. Has a tape been forcibly removed or forcibly inserted? If so, then mechanism timing or positioning could be out of whack. In regards to timing... often, the cassette carriage, and other mechanicals are gear driven, and if a gear set should jump a tooth or more, timing will be off. Often the gears had marks on them which must lined up according to manufacturer specs. Other possibilities include: dirty/erratic mode switch (tells the logic circuit the position of the mechanicals), or a bad sensor. Malfunctions in the electronics are still another possibility. If this is a low-cost VCR, as are most in the last 10+ years, repairs might not be cost effective.
Posted on Jun 04, 2007
SOURCE:
It was working perfectly until I hit the pause button. When I hit it, it turned off immediately. Now whenever I turn it on, it stays on for a few seconds after the display goes away and then turns off....
I believe that the tape must have fowled up and the mechanism has gone haywire and now out of sync. Every video has a mode switch. This tells the electronics what position the mechanism is in. However if the mechanism develops a fault, the mode switch will no longer be able to tell the electronics the true position and thus chaos develops, so the whole thing shuts down. You need to investigate to see if the tape is entangled or damage has occurred.
Aug 05, 2010 | Emerson EWV601 S-VHS VCR
Syntax Olevia flat screen tv video goes off then on
Hi, Replace the bulging capasitors on the main power supply board. Thanks.
Sep 22, 2009 | Insignia 37" LCD Flat-Panel HDTV
Dvd/vcr unit will not stay on
Sounds like you are having an internal electronical problem. It is most likely the capacitors inside the power supply. You can either replace the capacitors if you are good with electronics, otherwise you will have to replace the power supply. You can search around on google to find another one.
Apr 01, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Will not get off of "VCR" when I press DVD it stays on VCR
either your toggle is bad or the dvd mech has a problem...
Jul 05, 2008 | Panasonic sa-ht800V Home Theater Audio...
Dvd/vcr
well sounds like one of the players is not in correct spot thus shuts down (kinda timing issue) see if there is anything preventing it from going jiggle or turn upside down see if you hear anything.
Feb 12, 2008 | Philips Magnavox DVD/VCR Dual Player
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
Goldstar KMV-9012 (year 1990) TV/VCR Combo
This is the problem with these combo units. When the VCR has trouble (this sounds like a mechanical one) it inhibits the TV from working as well cause they share the same power supply. It needs a VCR expert to fix ya up.
I tell people all the time not to buy these combo units unless they really need the conveinience cause you get to throw away the TV when the VCR goes bad.
Nov 17, 2007 | Goldstar GVR-DD1 VHS VCR
Emerson TV won't stay on
I am currently have the same problem . I just got off the phone with the support tech and he suggested unplugging TV for about 5 minutes and if that doesnt work to unplug TV for about 2 hours. He said that may reset the TV . I am waiting now. If it works , I will leave feedback.
Nov 15, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
My Tv is turning off by itself
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Nov 05, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Aiwa HV-MX100 VHS VCR Logo
186 people viewed this question
Top Aiwa Televison & Video Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
