Question about HP Pavilion DV5234US Notebook Laptop
I can't connect internet even though I have connections appearing
I have a HP Pavilion dv4-1114nr Entertainment Notebook PC, I can connect only if I hold it in a certain position, but it still says limited or local connection and I cant  to the internet. I used to be able to connect just by clicking on the name, or it would automatically connect for me, now I cant get online. My other laptop I'm using at the moment can connect to the internet with out problems and I reset the router turned off my laptop and my problem continues. I only bout my laptop 3-4 weeks ago in December 2008. This laptop is new and I don't want to spend more money then I have to please help!
  • Ulises Tejeda Jan 09, 2009
    Sorry which icon? I'm running windows vista, so the set up your talking about might be Windows XP. If not could you please give more specific directions?
  • 520 Answers
Use your other pc ..when connected click on the icon in task bar and select properties open internet protocol(may have to scroll to it) and check details and write them down.
if its set to obtain ip and dns auto then cancel the network status box which should still be open click on support.
here youll find ip and dns details..write them down..
boot other pc and once up and running open network connections in control on wireless icon and select from list(to your left) change settings for this the properties page scroll to internet protocol and insert the detail ip ...subnet ...default gateway and dns server.(the dns is the same digits as gateway)
you should now be able to connect no prob.
Posted on Jan 09, 2009
  • tat4u
    tat4u Jan 10, 2009
    ok so your in vista..
    use the pc that connects first of all ....
    in the bottom right hand side of screen youll see a tiny icon letting you know your connected.
    you could also access in control panel.(network connections)
    you can also use xp type viewing If you like.
    I personally dont like vista ...too pushy.gfraphics are brilliant but when it comes to installing specific software its a nightmare.
    anyway all you need to do is access your wlan properties...(internet connection)
    then write down and transfer details(details in internet protocol)..
    all is described above of how to .
    cant remember if you said you have wireless router or not(probably not cos if you did it would connect no prob).
I have an HP Pavilion dv2000. Lately I've had a really hard time staying connected to the internet. I'll be connected for about 10-15 before the connection is lost. I know it can't be the...
look when this type of problem occurs,the first suspicion is the ISP in fact.And i wouldnt put it past them to snoop on people like this.
Logicaly the second bet is some sort of corrupted code but this is untested terrrotiry.Re-install of OS would be a first.
Aug 02, 2011 | HP Pavilion dv2000t (RM668AV) PC Notebook
HP Pavilion dv9913cl Entertainment Notebook PC I want to know if this unit is able to be used on 220V power with just an adapter versus needing a transformer.
Check the power adapter, if it says 100~230V INPUT, it's fine to connect to 220V. If says just 90~120V, it cannot be connected to 220V.
Nov 08, 2010 | HP DV9913CL-RB Entertainment Notebook
My p.c. keeps blocking my internet access by saying something about a Proxy. Even though it says my internet access is working.
You may have malware changing your settings. Open a browser window and look to the right side, click on the button marked "Tools", scroll down to "Internet Options" and click on that. When the window appears click on the "Connections" tab. Look to the bottom and click on the LAN Settings. Make sure that only the top box is checked and all others are UN-Checked. Click apply and ok. Now refresh the browser window and it should connect. I would suggest a malware scan quickly.
Jul 11, 2010 | HP Pavilion dv9000z Notebook
I have a HP Pavilion Entertainment PC. I push the
It sounds like a power supply problem (low voltage), or could be a battery going bad. Also, the vents to the cpu fan could be clogged up and overheating the cpu, causing it to shut down. You can spray the vents and area out with compressed air. Other than that, it will have to be serviced.
Good luck and hope this helps.
Jul 08, 2010 | HP Pavilion DV5234US Notebook Laptop
I purchased a hp pavilion entertainment pc. I
The naughty sales person should have explained, yes! you need a connector/adapter. not expensive just a pain to have too return to purchase.
Nov 10, 2009 | HP Pavilion dv6000z Notebook
Webcam not working..
do you have firewall, check the firewall have access to the webcam applications.. while using with yahoo messengers..
Sep 27, 2009 | HP Pavilion dv6000z Notebook
My HP Pavilion Entertainment PC will not turn on!
Jun 07, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Compatibility between HP Quickdock 2.0 Docking Station KN745AA and HP TouchSmart tx2-1020us laptop for external monitor viewing
Your tx2-1020us is not compatible with the KN745AA as this device is only compatible with the following:
  • HP Pavilion dv2700 Entertainment Notebook PC series
  • HP Pavilion dv6700 Entertainment Notebook PC series
  • HP Pavilion dv9700 Entertainment Notebook PC series
  • HP Pavilion dv2600 Entertainment Notebook PC series
  • HP Pavilion dv4-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1100 Entertainment Notebook PC series
  • HP Pavilion dv6-1000 Entertainment Notebook PC series
  • HP Pavilion dv6-1100 Entertainment Notebook PC series
  • HP Pavilion dv6600 Entertainment Notebook PC series
  • HP Pavilion dv6800 Entertainment Notebook PC series
  • HP Pavilion dv6900 Entertainment Notebook PC series
  • HP Pavilion dv7-1000 Entertainment Notebook PC series
  • HP Pavilion dv7-1200 Entertainment Notebook PC series
  • HP Pavilion dv7-2000 Entertainment Notebook PC series
You can find the compatibility chart by clicking here
You can find the compatibility information for the ES631AA by clicking here
To resolve your issue you should purchase one of the following:
To dock your notebook you need the HP QuickDock KN744AA#ABA or
You could get HP Notebook Media Docking Station
May 15, 2009 | Computers & Internet
HP Pavilion DV5234US Notebook Laptop Logo
1,405 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
