Question about Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo Head CD Player
Radio stop working after battery change
Changed the battery in my 2001 Blazer. Upon completion the radio no longer worked. All fuses in the box are good. Help
  • 1 more comment
  • coachgruscho Jan 09, 2009
    There are not any in line fuses (I pulled it already to look). Unless the radio has an internal fuse it's not the problem
  • coachgruscho Jan 11, 2009
    Oddly enough the radio started working again? I did find the positive terminal on the battery wasn't in full contact. It doesn't make sense,but it's working. Thanks
  • blueextc3221
    blueextc3221 May 11, 2010
    Check the fuses behind the radio?
  • 15,935 Answers
If your radio is the pioneer model stated, it definately has a fuse!
The little black box on the yellow wire contains a fuse.
If there is no black box on the conctant power, you may have damaged the radio with a voltage spike(s) when connecting the battery posts.
Posted on Jan 09, 2009
Changed battery on 2001 olds silhouette and now the instrument panel and radio don't work. Any suggestions?
NEED RADIO UNLOCK CODE TO RESTORE RADIO
IPC INOP. SOUNDS LIKE IP CLUSTER IT'S SELF, COMMON ISSUE
Dec 27, 2013 | 1999 Oldsmobile Silhouette
My radio stopped working. I changed the fuse labeled CIG on the digram (under the dash fuse box) but this didn't help the radio. The clock also doesn't work but that stopped before radio did. What fuse...
Need to know your mocel and year to see if I have a diagram I can tell you the "cig" fuce is for the ciggarette lighter/power outlet. Some Toyota's the fuse for the radio is the "ACC" fuse and others say "RAD".
May 02, 2011 | Toyota RAV4 Cars & Trucks
Radio no longer works. The car battery died, so we
check fuse may have gotten a spike when boosted battery
Nov 01, 2009 | 2001 Hyundai Santa Fe
Radio problems
Check the radio fuse to see if it was blown when you changed the battery. there is no rest for a radio that I am aware of for this situation.
Sep 09, 2009 | 2006 Jeep Grand Cherokee
2002 lincoln ls stereo doesnt work
when you replaced the battery it was very possible that you may have blown a fuse. Check your fuses for your radio and your cig lighter.
May 11, 2009 | 2001 Lincoln LS
Radio just stopped working
Check the fuse box under the hood. It should be located on the drivers side. Open it up and check around for the radio fuse. Most likely labeled as "ACC" which is short for accessorie. It should be a 15 AMP fuse. Last winter my radio blew out as well and I check the fuse box and replaced the fuse and now it works fine. The fuse was burnt beyond believe though. If you havent already fixed the problem I hope this helps.
Apr 24, 2009 | 2001 Dodge Caravan
Changed my battery.
This may sound silly but place the actual key in the drivers door and cycle locked and unlock this should reset the security system.
Jan 30, 2009 | 2004 Suzuki Verona
1995 Chevy Blazer - Possible Electrical Problem
probably a loose fuse connection or a fuse box problem you may have to take it out and inspect it
Oct 24, 2008 | 1995 Chevrolet Blazer
Dodge radio
If you already checked the fuse, you need to check for power to the back of the radio. If power is present there you will need a new radio. Factory radios are expensive, the best bet is to get an aftermarket radio and install it.
Aug 26, 2008 | 2001 Dodge Neon
Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo Head CD Player Logo
1,375 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
