Question about Whirlpool Duet GHW9150P Front Load Washer
Frigidaire ftf630as0 Front-Load Washer TUB DOESN'T WASH OR SPIN
ALL WAS FINE TILL MY LAST LOAD WASHED AND DRAINED BUT WOULDN'T SPIN. WHEN I RETRIED THE WASHER FILLED,TIMER MOVED BUT THE DRUM WOULDN'T MOVE,JUST LIKE A BROKEN BELT. WE TESTED THE VOLTS AND OHMES AND ALL CHECKED OUT AT THE PROPER LEVELS. WHAT COULD BE CAUSING THIS?
How old is your machine? Mine was doing the same thing. After doing some research online (and a visit from a Sears technician), I found out that the bearings died on on the drum. The Sears technician told us it was a combination of the type of soap being used (non HE), and the amount of soap being used per load that contributed to the unit's failure. I wish someone had explained that to us 7 years ago when we bought the machine. Appearently there are enzymes in the soap that will eat away at the rubber washer that protects the bearings. There are less of these enzymes in HE laundry soap, thats why it's recomended for front loading machines.I think the HE soap will still eventually cause this machine to fail, but it would take a little longer than 7 years (maybe 10 or 12). By then it's probably time to by a new machine anyways. We bought a new machine because it would cost over $500 CND to get the old one fixed. We ended up with a Frigidaire Affinity (FAFW3577KN).
Posted on Jan 09, 2010
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
My maytag neptune front load washer will not spin this has happened before and I called service they held down some button where the start wash etc are on on top of the washer. It washed the load but when...
Check whether water is fully drained. Since the motor worked during wash motor is not faulty.
Check relay that poers the motor during spin mode. May be micro controller fault posiible.
Mar 31, 2010 | Maytag Neptune MAH6500A Front Load Washer
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
Front load Fridgidaire ftfb4000fs1 won't spin
This is a fault that resides within the motor control board. you will need to replace this failed module asap if possible. it has failed.
Jun 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
Drum/frigidaire washer
wow thats a long hard job ,,overhaul....the part your looking for is the spin tube surport,,you have to take the hold drum out than seperate the front tub from the back bearing tub,,and pull wash basket out though front..,,also if you had a leak or surport broke and is making noise.. change back bearing tub too.i recommend a professional technician...but if you want to do it your self ..post question how to change wash basket,,glad to help
Dec 27, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Jul 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Whirlpool Duet GHW9150P Front Load Washer Logo
705 people viewed this question
Dan Webster
Dan Webster
Sal De
