Question about KDS 17S 17" Monitor
I have a KDS usa monitor that flutters with vetical lines for twenty minutes until it settles on the home page. The lines change to many colors. I tried to press f8 during boot up. The screen fluttered in white for twenty minutes. HELP
5 Suggested Answers
SOURCE: KDS radius 17"LCD RAD-7C shuts off during boot and won't come back on (mostly)
I am having the same problem and this seems to be very similar to the problem these users are having but that is a different screen. So I was hoping someone would have more info on this specific monitor. I am seeing no budging capacitors on my boards.
Posted on Jun 12, 2007
SOURCE: KDS usa k717
What to do about a power supply problem in the monitor?
Posted on Feb 21, 2008
  • 3 Answers
SOURCE: kds model 780 monitor no signal, power button does not work
My monitor does the same thing at times and sometimes shows "No Signal" and at other times the screen will maintain the images but the backgound color switches to mustard yellow. In each of these cases I have been able to solve the problem by unplugging the power cord from the electical outlet for about three seconds and plugging it back in. I have a KDS model 780 LCD.
GOOD LUCK
Posted on Feb 16, 2009
SOURCE: KDS Computer Monitor loses video one half hour after booting up.
After being away for a peroid of time I went to use the computer just to be looking at a totaly dark screen. I cant get a menu to pop up or anything.
Posted on Oct 13, 2009
  • 732 Answers
SOURCE: Problem started with a white screen, now It just
jimmoser45, Could be trash! Could be a Trade-in on a new monitor! Try to follow me on this will-ya!!! You take your K226WDB to store and maybe get $10 knocked off the new one? Anyhow, you walk out with new LCD display and 1, poss 2yrs warranty. But the sales guy who just toted your K226 back to the "bench tech" in the back room and says to his 'tech' "Hey, here's one more! You fix it,,, give it to your 8yr old!" The tech replys. "Hey... Thanks. I'll look it over after break." Well later that day the tech opens up you're K226 looks at some stuff inside and then proceeds to make a repair that might bring new life back to this monitor. Maybe an hour later the tech hooks up the K226 to a pc and pushes the "ON" button of the monitor and with $5 in new parts,and a little LUCK an 8 yr old will have an LCD monitor with a nice, bright, crisp text and graphics being displayed on your old unit!!! Check out youtube first for video clips on "lcd monitor disassembly" and "lcd monitor repair" to help you make a decision on what steps you might take to keep your K226 unit out of an 8yr old's bedroom!! 12fixlouie
Posted on Nov 21, 2009
Vetical lines on monitor
The LCD panel if failing, you will get more line as time goes by due to bad LCD t-con board (part of LCD panel). Nothing you can do but replacing the LCD panel.
http://s807.photobucket.com/albums/yy352/budm/ACER%20AL1916W%20Abd/
http://s807.photobucket.com/home/budm/allalbums
Apr 17, 2010 | Acer AL1916W 19" LCD Monitor
How do I return my KDS USA monitor back to factory settings for color?
The KDS has an 'OSD' ("on screen display").
Press one button on the front of the KDS to activate the OSD, and navigate through its various menu-items, to find the "reset" control.
Apr 16, 2010 | KDS K22mdwb LCD Monitor
My kds usa lcd 700p monitor use to work for like 10 seconds then go black and now it doesnt even turn on led in front doesnt even light up i put a volt meter to it to see continuety everything is good...
Do you get the 5vdc for logic circuits and 12~18vdc for the inverter circuits. Please recheck your soldering works, make sure the caps are installed with correct polarity. See some of my examples here: http://s807.photobucket.com/home/budm/allalbums
Jan 07, 2010 | KDS K22mdwb LCD Monitor
I get error message: Out of Range, on my 17 inch LCD KDS monitor
get the monitor that you used previously, and on the Windows desktop, go to display properties, in settings> advanced, under the monitor tab, change the refresh rate to 60, which is common on these flat panels.
Jan 05, 2010 | KDS Computers & Internet
Computer monitor doesn't show colors good only white and blue
Drivers not installed properlyu...install properly the driver, if then same proble check the VGA card for the desktop/ vga chepset chep in laptop.. or cable connection og vga...
May 31, 2009 | KDS Radius RAD-7 17" Flat Panel LCD...
Monitor Life
Instructions follow, RESULT "Replace and never buy a KDS USA Monitor again (less than 3 years usage)."
Dec 29, 2008 | KDS K717s 17" LCD Monitor
Kds model 780 monitor no signal, power button does not work
GOOD LUCK
Dec 15, 2008 | KDS Radius RAD-5 15 in. Flat Panel LCD...
The white screen tells me that the display cable (inside your monitor) may be unattached or broken.
The color bands if they are vertical or horizontal lines tell me that your display cable needs to be replaced.
So overall replace your display cable. If this doesn't entirely fix the problem your logic board (inside the monitor) needs to be replaced.
Feb 21, 2008 | KDS K717s 17" LCD Monitor
Reinstall of windows xp
This won't have anything to do with the monitor in the control panel, you should be looking at "Sounds and Audio Devices". Did the sound ever work?
Dec 19, 2007 | KDS Radius RAD-5 15 in. Flat Panel LCD...
No clear picture just wavy lines and error message
The spec sheet I found says your monitor should be able to display 1280 x 1024, 720 x 350, 720 x 400 and four other resolutions in the 640 x .... range which are pretty useless. Try setting ti to 1280 x 1024 at 16 million colors @ 60 Hz and let us know what happens.
Nov 26, 2007 | IBM 9516 Monitor
KDS 17S 17" Monitor Logo
189 people viewed this question
Top KDS Computers & Internet Experts
Michael
Michael
Gary Finch
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
