Question about Vizio VX32L Television
I have a Vizio 42' and a cable box and there's a constant humming
Do I turn the cable all the way down or do I use the cable to change the volume? Where's the humming coming from? I heard use both the TV and cable to change volume but nothing works
I think I had the same problem. This is how I fixed it.
I have my vizio 42 hooked up to a Harmon Kardon surround sound, and the digital cable box. Essentially, I can adjust the volume 3 ways - through the tv, cable box or av receiver. The humming sound happens when you have the volume maxed out on the av receiver and not the cable box.
For example, the sound level on my Harmon Kardon goes from -10 (lowest) to 10 (loudest), with 0 being the middle ground. The buzzing was happening when the Harmon Kardon was set to 10, and I was using the cable box volume to adjust the sound. To fix it, I turned down the volume on my receiver to 0, which may be about 50% max volume of the receiver. Then, I switched devices and used the volume on my cable box. This got rid of the static I was getting. Hope that helps.
Posted on Jan 13, 2009
Volume does not stay level it increases by it srlf
You sure it's the TV? Are settings at default? Have you tried a factory reset? Does it change with a DVD? If it only does it with cable/satellite it could be the set top box and not the TV, in that case just exchange boxes with your provider.
Oct 19, 2014 | Vizio 42 in. LCD TV
Volume control problem.constantly having to ajust volume.have 2 volume control remotes; one is the vizio volume control and one is our cable company volume control. could their also be a setting in the...
Also have the same problem with ours - purchased a 55" lcd/hdtv and have to constantly adjust volume especially between commercials and programs. Can bearly hear the program turn it up and it blasts you out of your seat at commercial time. Had cable company out and it is definitely not the cable. Also have a problem with TV constantly shutting on & off. Does anyone have a solution???
Jan 14, 2011 | Vizio 42 in. LCD TV
Vizio TV with comcast cable box has always worked fine; tonight getting pic. but just the hum of white noise/static instead of any volume... The Xbox 360 has volume/sound when that is turned on, but...
comcast boxes can either have component cables or hdmi. sometimes the red and white cables come loose. check the cables on the TV and the box. If you are using hdmi, let me know and I'll walk you through some steps...
May 04, 2010 | Vizio VX37L Television
I have a moxi box and i just bought a vizio tv and i cant find the code so i can use the volume control on the moxi remote or to turn off the tv either
The Code for the Moxi Cable box remote control for VIZIO TV's is "1178". I just programed my 47" VIZIO TV with this same code
Feb 10, 2010 | Vizio VW42LF 42 in. LCD HDTV
Hum from tv
try unplugging any equipment that you have attached to the tv one at a time, such as dvd players, surround sound, cable box, etc. also if you have a cable box attached, try adjusting the volume on it. if you have everything unplugged from tv and it still hums, then it may be a tv issue
Oct 21, 2009 | Televison & Video
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
A buzz in the sound can come from having your audio cables to close to the power cords. Or a problem with the cable box. A problem with the Ac power supply like a bad input filter can cause a buzz. If it changes when you turn the volume up and down it is not power supply. Hope some of this helps.. It is hard to be sure without hearing it
Mar 24, 2009 | Vizio L32 32 in. LCD HDTV
Volume control
unplug the cable box for about 1 to 2 minutes. By doing this it will reset the cable box to its original settings. This will bring the volume to acceptable range. Hope i was able to help.
Jan 12, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio 42'' TV Sounds like it is in a metal tube.
The volume was up on the TV, but down on the cable box remote. By raising both volumes the sound quality improved dramatically.
Nov 23, 2008 | Vizio L32 32 in. LCD HDTV
Vizio Volume Control
I am sure you did this but recheck your audio menu on all your inputs. I have found that cables can go bad so make sure they are in good shape. Are you haveing the problems with all your inputs dvd, cable (direct cable or a cable box) whatever? It is hard to affect the audio by just moving the set. I am hoping that you changed something or the cables went bad that would be the easy solution.
Good Luck!
Aug 04, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio VX32L Television Logo
515 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
