Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Icemaker not working
Installed a replacement icemaker, everything looked the same and seems to be hooked up as before it was a simple plug in, but it did not start up , is there a delay before it will start?????????
    Scholar:
  • 58 Answers
Most ice makers will take a few hours till it cycles. the t-stat has to get cold first but you can advance it but removing the cover and take out the Philips screw holding the center gear, now turn the ice rod clockwise till u see the brass gear start to turn now put it back together. it will fill with water and in about a hour or so drop some ice
Posted on Jan 09, 2009
OBD plug not working
That plug has its own fuse. Please consult the fuse box diagram for the location and size.
Feb 10, 2014 | Toyota Yaris Cars & Trucks
Lights on front of refrigerator seem to be locked. nothing works when you push one but lights are on and the temp area states the same 39
You are looking at a bad selector switch and or the door switches that activate the auger to push the ice out. You would be looking at replacing the whole control if you need the ice to come out of the door. I would first try the simple unplugging and plugging back in, sometimes resetting the unit can help clear it up. Good luck
Sep 09, 2012 | Refrigerators
Water will not stop flowing in to icemaker
Dirt in body of icemaker water supply valve. OR. Ice maker timer stuck when it selected "add water to icemaker.
The first solution is simple, change icemaker water filter and disassimble valve to clean.
The second is simple, buy a new icemaker.
May 15, 2012 | LG LFC25760ST 25 Cu. Ft. Panorama French...
LG RefrigeratorModel LFX25960ST - icemaker has been replaced once
Most ice maker heads cost less than $49 to replace if you get it at a wholesaler. The water quality going to it will effect how long it will last, Reverse Osmosis treated is the best, filters will help some but are not a cure. Your budget is the determining factor in this equation.
Nov 21, 2009 | Microwave Ovens
Icemaker overflows into holder freezing
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Sep 07, 2009 | Refrigerators
We just inherited what looks like a 57029. We
No, but it is easy to disconnect icemaker. Unplug behind icemaker (remove or loosen screws to see plug. Put tape over jack in freezer to keep moisture out. Put icemake back when ready to connect water.
Aug 24, 2009 | Kenmore 57029 Side by Side Refrigerator
Will the refrigerator work if the ice machine is not hooked up?
You need to have the icemaker assembly in the unit. Now unless you are talking a clrco2075 you have to hookup the water. If its a regular icemaker then by lifting the arm everything should work. The icemaker has sensors in it and thats why you need the icemaker in place. What model do you have? Just to be sure, some models you have to program the icemaker to stay off.
Jul 16, 2009 | U-Line Refrigerator Ice Maker
Whirlpool ET21DMXDW05 top freezer. icemaker not working
Give it some more time. The icemaker has an internal thermostat and it will not come back on until it reaches 16 degrees. It takes a while after it gets warm. if it doesn't start functioning in a few more hours you may have other problems. Hope this helps
Jun 07, 2009 | Refrigerators
Freezer is almost always running....
If you look at the icemaker, you will see a metal wire which runs along the side of the unit. If you manually swing the wire arm up until it locks in place (about 90 degree swing from the normal straight down position) you will have turned the icemaker off. (Alternatively you can unplug the electrical plug from the icemaker which goes into the freezer wall.)
If the icemaker is not turned off, it will periodically cycle, which turns on the ice cube mode release heater during it's cycle, putting unnecessary heat into your freezer. You do not need to plug the ice maker supply line. This should be a Fix-Ya for your refrig.
Feb 02, 2009 | Maytag MSD2756G Side by Side Refrigerator
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
153 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
