New speakers not working computer says no audio installed
  • 238 Answers
Hi, you should install the audio driver for your new speakers to work. If you don't know where you can find the driver, drop me a comment and post the manufacturer and model name of your motherboard or sound card so I can assist you further. And also the Operating you are using now. Your computer says "No audio installed" because it is looking for the audio driver for your sound card.
Posted on Jan 09, 2009
My computer doesn't detect my speakers, I do have windows 8
Do you have the AC adapter plugged into a live outlet and have you turned on the speakers? Make sure that the speaker signal cable is plugged into the correct port on your computer (the lime green port on a desktop). Check that the correct audio driver is installed for your computer. (With Windows 8, use the Device Manager to check. From the Start Screen, type in Device Manager. Click on Settings and then select Device Manager. Alternatively, Windows key+C on the desktop. Select Settings and then Control Panel. You can find the Device Manager under System and Security or Hardware and Sound.) Scroll down to the Audio devices. Expand the section and look for a red triangle with an X or a yellow triangle with an exclamation point. Try updating the driver (check with the manufacturer of your computer for the latest driver). Even if you don't see the error triangle, try reinstalling the latest driver.
Next check if the speakers work on another computer. If they don't work, the audio cable may be damaged. Try a different set of computer speakers on your computer.
If other known good speakers do not work and the correct audio drivers have been installed, check the audio output devices. Go to the Control Panel > Hardware and Sound page (as described above). Choose Manage Audio Devices. Check if the HDMI port is set as the default audio device. Disable it for a bit (right click on the device) . Sometimes when a new video card is installed, the audio device defaults to this port. This messes up the drivers for the regular audio.) Reboot the computer and then try reinstalling the audio driver. Reboot again.
If it still fails, there is probably something wrong with the audio device hardware. If you are using an add-on sound card, try disabling it and using the motherboard audio device. (A number of add-on sound cards didn't work well with Win7 or Win8. The on-board audio drivers worked better.) If you are using the motherboard audio on a desktop, try an add-on sound card. (Check for Windows 8 compatibility (drivers) before selecting any card.)
I hope this helps.
May 29, 2013 | Kinyo PA-1158 2.0 Amplified Speaker System
Speakers work...just not when plugged into desktop
You may new a new audio driver. Visit the support website of the manufacturer of the computer's manufacturer (Dell, HP, etc), type in your computer's model number, and download and install all "Audio" drivers.
Mar 05, 2011 | GE ULTRASONIC PRO 2.0 Computer Speakers
Computer won't recognize that there are speakers plugged in
go to the pc support website---the should be access to drivers for your model
Apr 27, 2010 | Altec Lansing VS4121 Computer Speakers
I installed a new hard drive and now my speakers don't work?
Hi , have you installed the Drivers for your Audio , or Soundcard on the new HDD...
Hope this helps bud
Happy new Year
Jan 03, 2010 | Dell 5650 Computer Speakers
My speakers won't work
Hi! It seems that your problem is in your computer system setting. You have to install the audio device DRIVER and install it. After that, problem solve. Good luck, THANKS
May 06, 2009 | Audio Players & Recorders
Speakers
Hi c-king,
Ah, cavaet emptor the dreaded used computer. I'm going to assume that it had speakers that worked in it's previous life. Check all cable connections, make sure system is not muted, speaker control knob is on. In windows, most editions, follow: start, control panel, sounds and audio devices, volume tab-speaker settings-advanced settings. Here you can configure and choose your speaker setup(it may be set at headphones) i.e. 5.1, 7.1 etc.. Also check the audio tab to make sure you have a digital audio device installed i.e. Sigma Tel Audio or what ever is installed in your computer. I hope this helps a little, if not, hit me back, we have other options i.e. new audio drivers.
Thanks for using FixYa.com
Sincerly, cyyyd7
Oct 09, 2008 | HP Audio Players & Recorders
Please help me
If after connect your usb speaker cable the system it is asking for software (drivers) you have to install them to get your audio working properly. Check it out the box of your new speakers for a installation CD.
You can also verify:
Check if your audio es working properly (start >> control panel >> sound and audio devices)
Check if your sound card is properly installed (My pc >> Properties >> Hardware >> Device Manager >> Audio)
Oct 05, 2008 | Audio Players & Recorders
No sound
i think your speaker is working in good condition
but your computer audio out not working
due to driver or hardware problem
  1. check sound driver is properly installed
  2. using other multimedia software instead of now using
  3. check audio hardware trouble
Jan 16, 2008 | Altec Lansing Multimedia Computer Speakers
Altec lansing sudio problem
1)Please install a motherboard cd to your system without failure..
after that it will work properperley..
2)In the volume control set the speakers to windows default option..then the speakers will get ready to through output..
Oct 18, 2007 | Altec Lansing Multimedia Computer Speakers
427 people viewed this question
 Grubhead
Grubhead
