Question about GE Profile PDS22MHR Bottom Freezer Refrigerator
Help me with me frige not cooling bottom GE unit.
There is nothing blocking these vents.... Is there another thing that may be automatic that is not working...Something in the controls at the top of the fridge that control something other then the damper as I have checked all these things and can't seem to figure it out
    Scholar:
  • 31 Answers
When you close the freezer door, does the fan turn off? There isn't any thing else on my bottom mount beside the damper that regulates airflow to the refrigerator box.
You should be able to drop a string from the damper opening at the back of the refrigerator down to the duct to the freezer. If you can't there is some obstruction in that duct. I suppose it is possible there is some other mechanism in that duct on your particular model, but I can't understand what its purpose would be.
The picture below shows the vents at the back bottom of the refrigerator box that return air to the evaporator in the freezer box to be re-cooled. If these are blocked, the fan can't draw air in to be blown back up to the refrigerator, unless of course the freezer door is open. Help me with me frige not cooling bottom GE unit. - 7e3c57e.jpg
Posted on Jan 09, 2009
Frige not cooling on bottom freezer frige
Check the air vents, from the freezer to fridge. Air travels through those vents. Sometimes, products get shoved under the vents, preventing air flow. It sounds like, the vents are clogged with something. I guess, the fan is working inside, of the freezer? Ice in the bottom, of the freezer pan, could be clogging the vents. You'll have to dig deeper. Good luck.
Aug 16, 2014 | Kenmore Refrigerators
I have a ge frige that the freezer works but frige is warm
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 01, 2011 | GE GTL18JBPBS Top Freezer Refrigerator
GE PTS25LHSARBB doesn't hold temps.
Have no idea who may have responded to any of your previous posts.
The defrost heater is located behind the back wall of the freezer compartment. You will have to unload the freezer and remove the icemaker to get to it. It is located at the very bottom of the cooling coils (which are officially known as the evaporator). When you remove the back wall to reveal the evaporator, in a normally operating refrigerator, you would see a light even coating of frost if the refrigerator has been running for at least 20 minutes or more.
Feb 03, 2010 | Refrigerators
Dometic rm2652 frige just stopped working, gas nor
Check 12V supply and fuses on lower board. If display functions okay, then look for yellow residue on back of refrigerator near burner. If yes, then cooling unit has leaked and needs to be replaced. See if recall kit has been installed, and check for 12V at both sides of limit switch. If no power on either side, then thermal link has blown, and need to be replaced, If 12V on one side, but not the other, than limit is tripped, and needs to be reset, by pushing button, or if not resetting, then replace, Check for obstructions to the bottom and top vent to make sure they are not blocked, On models with top side vent, check cooling fan for proper operation.
Aug 22, 2009 | Refrigerators
Ge refrigerator model gss22wgph bb
Carben,
I have the same problem and I am able to resolve it by defrosting the element which is behind the inside rear panel of the freezer. I use a hair dryer to melt the ice build up. It happbed a couple of times so I know that there is a cause for this which may be the defrost heater but I am not sure how to confirm this. Let me know if you have any ideas.
Aug 20, 2008 | Danby (DAR604BLS) Refrigerator
GE HotPoint HSS25 not cooling, but interior lights are on
video on troubleshooting
http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
if after you try the things on the video you may have to replace the motherboard. you can reset the frige by unplugin the power and pluging it back in. If you decide not to replace the motherboard as the unit will work fine untill you press the dispencer i reccomend unplugging the dispenser unit at the top of the freezer door so the frige will not accidently shut down just unplug the connector leading down the door. your frige will work fine without this connection just no water or ice at the door. If your frige is still under waranty (1year parts& labor) call them up and they will fix it.
The motherboard on this frige seems to be sensitive to surges and the transformer for the ice/water dispensencer goes bad. repacing the motherboard corrects this problem they cost about $75 to $90 on the appliance websites to install the new one it is very easy and you need to unplug your fridge and pull the metal cover off the back of the unit by removing four screws. the cables are all different size and can not be pluged in wrong the replacement board should come with instructions. to remove the board you may need needle nose pliers to push in the tabbs on the white board standoffs it should take about 10-15 minutes
I have solved this problem by replacing the back board if you have any questions I can help out
Jan 21, 2008 | Hotpoint HSS25GFP Side by Side...
GE Refrigerator: GSS22SGRF SS - Not Cooling; Not dispensing ice or water; clicking noises
U need a new wr51x10101 heater harness 35.50 $ there is an ice build up on your coil defrost coils replace the heater harness U should B good to go
Oct 25, 2007 | Refrigerators
GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Refrigerator-Parts-Page-6901.cfm
Oct 25, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Bottom Freezer working but not side!
Typically the freezer air is circulated into the frige area to provide cooling. If the circ. fan is not working or the air ducts/channels/dampers are blocked with ice, food, etc. then no cool air will get from the freezer to the frige area. Check all the air channels and to see if the dampers are open along with the circulation fan running. The diagrams at the following link should help you see inside better. If your lower circulation fan is running then you likely have an air return/supply channel blocked with ice and will require an old style defrost (unplug unit and leave doors open for 24 hours to melt ice, etc.). If the fan isn't running then that needs to be replaced. Air channels can freeze up if a door is left open slightly overnight or other moisture enters the freezer/frige. http://www.partselect.com/MultiModels.aspx?ModelNum=ER6AHKXPQ&searchTerm=&RefineSearch=0
Nov 20, 2006 | Whirlpool ER6AHKXPQ Top Freezer...
Open Questions:
See all GE Profile PDS22MHR Bottom Freezer Refrigerator Questions
GE Profile PDS22MHR Bottom Freezer Refrigerator Logo
305 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
