Question about Danby DAC9003D Air Conditioner
A/c will not work
Plugged in the a/c unit - get a beep saying it recognizes there's power (and checked to make sure power is working in that outlet) ... but the LED control panel on the front does not light up, nor does pushing any of the buttons work I disconnected the LED control panel and made sure the connections were all reconnected tightly and tried again and the same thing... any suggestions?
  • cmccombs Jun 23, 2008
    i have the same problem..but mine is a 12304D
  • 105 Answers
Sounds like the control electronics are faulty. Replace control unit.
Posted on Jul 15, 2007
Drain water light is blinking unit wont power on
Make sure the unit is on a flat, level surface. If the floor is not level or the carpeting is too thick, the unit will not be level, causing the water in the internal tray to flow to one side. This will bypass the water full safety mechanism and the unit will not automatically shut off.
Check for broken or damaged casters. Check to make sure the casters are installed securely and evenly.
Check and make sure the drain cap and/or the rubber plug is installed. If cap or rubber plug is missing, use a cork. Check and see if the drain is cracked or broken, if so, shave broken drain flat and use a cork. You can use a plumbing adhesive or epoxy to repair the drain.
And regarding that the unit is not powering on i would suggest you with the following things.
Test the outlet that the PAC is plugged into is working. If the outlet is working than the powerplug breaker needs to be replaced. If the wall outlet is not working, there may be too many appliances on one circuit. Recommended circuit is 20amps. You can also administer a power plug check: Power Plug Check
1. Press the RESET button. The reset button may be stubborn so you will need to press HARD to reset it until a click is heard and the light comes on.
2. Insert the power plug into the electrical outlet.
3. Press the TEST button. If the circuit breaker is working you'll hear a click.
4. Press the RESET button until you hear another click. The circuit breaker in the plug is now activated.
5. Do not use the air conditioner if the above procedure cannot be successfully performed.
After switching the air conditioner off, wait 3 minutes before switching it back
Jul 18, 2015 | Heating & Cooling
I have an hp compaq dx2400 micro tower desktop , but it doesn't work when I pluget it to the monitor,PLEASE HELP I HAVE A LOT OF DATA ON THAT PC
Make sure you are set up for correct monitor. If keyboard lights flash and HD beeps, but no picture, you may have an incorrect monitor setup. In BIOS, make sure you are set for proper internal/external video, and be sure to plug into right port.
Dec 05, 2014 | Computers & Internet
Unit doesn't turn on by pushing power button
Check the power supply make sure it's connected properly then if plugged to an outlet you know works and it still has no power then I'd say the power supply is bad
Feb 20, 2014 | Uniden Guardian Wireless Video...
Power pack light red
Hello, let's try a few things. First I would try to unplug the cables at all points. The wall, unit and power block in the middle. Reconnect and see if that helped.Be sure the unit is straight to the outlet and NOT to a surge protector or power supply or extension cord.
If not, I would try to plug the unit into another outlet somewhere. In a different room or something. Be sure the unit is straight to the outlet and NOT to a surge protector or power supply or extension cord. If that works, it's clearly the outlet in the original spot.
If none of these solutions help, if possible, see if you can borrow someone else's power supply and give it a try. If it works, then you know for sure that's all you need to replace. If it still doesn't work, you may have an internal power issue and will need a repair.
You can also find Microsoft's power supply trouble shooting guide here.
I hope this helps :D
Nov 24, 2011 | Microsoft Xbox 360 Console
When i plug my wireless mouse into my laptop it keeps on coming up with a pop up saying usb devise not recognized. I tried replacing the batteries but it still doesn't work how can i fix it?
try to turn off your computer using Shut Down or pressing the power button and then unplug it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this help you fix that “USB device not recognized” Windows error!
Jun 29, 2010 | Logitech Cordless Mouse
Maytag M7Y15F2A-D A/C - won't turn on -long beep then nothing
The beeping might be an alarm that indicates the coils are iced over by too much humidity in the air...and/or the unit is overheating etc.
shut off power to the unit for a few hours, go out somewhere if it is too stuffy inside.. see if the unit operates better when you return... I also suggest not running these things constantly, this causes some units to ice up and **** up the power..
hope the unit does get replaced, newer ones are more efficient.
Jun 02, 2010 | Maytag Heating & Cooling
My APC keeps beeping.
possibly..you have unpluged or dislodge you power cable from the outlet or from the power plug shuye at the back of your ups.. double check all the plug and re plug all your power cables !!!! make sure they are tightly pluged in and firm in their outlets..
Jan 26, 2008 | APC Back-UPS Pro 650 UPS System
No Power
have you troed a different usb cable the installation says plug usb in to pc first then the drive then plug power addapter to main wall outlet if this does'nt work try on another pc to see if the drive is working if not take it back to shop where brought and say hdd is not working if in warrenty if brought from web then send to maxtor for service it might have gotten knocked about during transit. enter maxtor in webbrowser to search for web site address ans locate their contact us link this is all I can give you addvice on problem
Aug 20, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Danby DAC9003D Air Conditioner Logo
347 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
