Question about Exercise & Fitness
Life Fitness Elliptical X5 Motor Error
Display monitor says motor error. I have tried unplugging the maching but to no avail.
  • alechev Feb 01, 2009
    Hi. I have the same problem on my Life Fitness Elliptical. It shows on the display the message "Motor Error".
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
Posted on Jan 08, 2010
  • 16 Answers
SOURCE: Life Fitness Treadmill "FET" error
Can you please provide model of unit.
Posted on Feb 20, 2010
maxtreadmill
  • 832 Answers
SOURCE: Treadmill (Vision Fitness T8500) turns on, motor doesn't run...
open motor shroud and inspect all connection on the motor control board see if all LED 's are lit except that light up when incline motor is moving up or down. then check the two connector coming from the drive motor to the board sometime over time the two connector will have a cold soldier I would move them to see any excessive movements of the pins then hit start and see if there is any belt movement. Last but not least unplug unit and check the motor brushes if they are less than 3/8 in in length replace them. Call them @ 1-800-335-4348 they under their parent corp. Johnson fitness.
Posted on Mar 01, 2010
maxtreadmill
  • 832 Answers
SOURCE: Where is battery located for Life Fitness 9500HR
These units are not self generating unit theirpower cords is in front bottom if it is missing then you will a power module got to www.sportsmith.net goto life fitness and get pricing
Posted on Mar 03, 2010
bwinton
  • 83 Answers
SOURCE: FET Error
FET error is caused by a short in the driver transistor on the motor controller. Unfortunately, the fix for this is to replace the motor controller.
Posted on May 07, 2010
Life Fitness 9500HR Console Reads Motor Command Error and the Red Led #1 is not flashing.
motor controller board has error comunicating with console, you can try to disconnect all leads connecting to console and reseat. failing that you would need to send off board for repair as new motor controller for next gen model is 700 gbp.
May 30, 2014 | Life Fitness 9100 Next Generation...
Error 20 on Q47 Octane Eliptical
Sounds like it needs to be fixed. It will need a new left motor and cord most likely, less likely a lower board.
Apr 14, 2013 | Octane Fitness Octane Q47 Elliptical...
No led display is their a way to replace the battery or does it runs on batteries
There is a 9 volt battery in the back of the console. This small battery could be your problem. I am attaching a link to our Website for parts, as well as a link to the diagram for your machine.
Search Results
http://www.sportsmith.net/images/product_support/lifefitness/Crosstrainer/Consumer_CrossTrainers/Ct5500%20Rear%20Drive/CT55-0XXX-01%20SN100000%20Parts%20Diagram.pdf
Dec 23, 2012 | Life Fitness X5 Elliptical...
Error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Feb 17, 2010 | Life Fitness T3 Treadmill with Advanced...
I have a Life Fitness T3-0 which shows a "FET error".What does that mean?
FET Stuck on Error / Err 5 - This error is probably caused by the driver transistor on the motor controller is detected to be shorted out. The fix is replacing the motor controller.
Jan 13, 2010 | Life Fitness T3 Treadmill with Advanced...
FET Error
Nov 08, 2009 | Life Fitness T3 Treadmill with Advanced...
Life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Feb 28, 2009 | Life Fitness Remanufactured Next...
Ironman 520e elliptical
i believe this is error occurs when the console doesn't get a reading from the gear box. while debugging a problem with the reed switch (the thing that detects motion, that you have started pedaling) I had the gearbox unplugged and it indicated error 1. once plugged back in, it was fine. possibly you have pinched/cut wires? I had this problem where the stem meets the body.
The gear box wires are red/yellow/orange for the servo positioning, and brown/black for power to move the motor.
Jan 02, 2009 | Ironman Fitness Achiever Elliptical...
Exercise & Fitness Logo
402 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
