Question about Canon MultiPASS C555 InkJet Printer
Can,t send or get fax need to know setup for fax
It well cope but not get or send fax
  • se4dogs Jan 09, 2009
    I did that phone line is working fine do i need to push hook or something to get the fax to work it is a stand alone no pc ?
  • Anonymous Mar 20, 2009
    can't send or recieve fax
    Genius:
  • 2,120 Answers
Check the phone line with a regular phone.
Posted on Jan 09, 2009
Not sending faxes
If you're only having problems sending to some numbers, check the dialing rules for that number if it needs an area code or country code.
There's nothing wrong with your fax or line. You can also try loweing down the maximum send speed for your fax. To do that, on the control panel of your printer, press on Setup > Fax Setup > Dialing and Sending > Max Send Speed.
Apr 24, 2012 | Lexmark Interpret S405 Wireless All-in-One...
Iam getting remote fax error
Please try this approach:
1. Try to resend the fax. There may have been a problem with the quality of the connection.
2. Decrease the transmission speed of your fax modem. Press Setup button > Fax Setup > Dialing and Sending > Max Send Speed > 9600. Resend the fax.
3. Re-register your user information - fax name and fax number. Some fax machines block faxes without sender information. Press Setup button > Fax Setup > Dialing and Sending > Your Fax Name (re-enter your fax name). Follow the same steps and go to Your Fax Number - re-enter your fax number. Resend the fax.
I hope this helps.
Feb 20, 2012 | Lexmark Platinum Pro905 multifunction...
Sir, whenever we try send any fax there are continue ring no fax tone received so i want know how i can solve this problem
Firstly you should try checking sending fax to other number as well if same thing is happening try following steps.
Go to Setup/Menu- Fax Setup/Menu- Distinctive Ring- Check what is it- If it on Ring Only change it to Fax tone.
Save the settings and get back to the main screen and the tru sending Fax again.
Note* you need to do these steps on the all in one or Fax machine .
Jul 06, 2011 | Office Equipment & Supplies
Setup FAX...
Plug a phone cord into the LINE port of your machine. Ideally it should be a dedicated phone number, but you can share a line.
Sending a fax is just like making a phone call.
Load your original face down , dial the fax number, press send or start.
Receiving will be automatic.
Mar 15, 2009 | Samsung SCX 4521F All-In-One Laser Printer
01.12.2008 i fax to one number. now i want aknowledgement of that fax. its gone or not. How i can find on HP Officejet 5610 all in One System?
You can get the manual here if you do not have one - LINK.
Here is an exert form the manual on this:
Print fax confirmation reports
If you need printed confirmation that your faxes were successfully sent, follow these
instructions to enable fax confirmation before sending any faxes. Select either On
Fax Send or Send & Receive.
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send &
Receive
Prints a fax confirmation report for every fax you send and
receive.
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Error 405
this usually happen when sending fax ,if thats the case take the following steps
1. Press the setup button (upper right corner of the fax machine)
2. Keep pressing the setup button until you get to the fourth option which says "Advanced Fax Setup"
3. Press OK to select the "Advanced Fax Setup" menu
4. Then using the left or right scroll arrows (below the OK button) scroll till you get to the sixth option which says "Fax Speed"
5. Press OK to select this menu item
6. Press the right scroll arrow till you get "slow" for the fax speed.
7. Press OK to accept this selection.
Then initiate a fax as you normally would.
hope this helps if you have further problem do let me know
Sep 23, 2008 | HP Officejet 4315 All-in-One Printer
Line on fax when sending or coping.
Open the document feeder (the keypad assy) and look for wite-out on the small scanner glass.
Aug 03, 2008 | Brother IntelliFax-4100e Fax
Wont send fax
Error 350: Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
Try these steps...
1. Press setup, then go to TOOLS.
2. press okay on TOOLS, then look for RUN FAX TEST. then press okay.
3. It will print a fax test page. Check if everything passed.
4. If it passed everything, try to press setup again, then go to ADVANCE FAX SETUP.
5. Scroll, down and look for ECM (Error correction mode), then press okay
6. Under ECM you will have to options "ON or OFF" try to choose OFF then press OKAY.
7. Now, try sending a fax.
Please let me know if the steps that i gave resolve your issue or not. So that i can still go ahead and give you another possible solution.
Thank you so much.
adonscott
Jun 29, 2008 | HP Photosmart C7280 Printer
Need some help
Go to www.brother.com. They might have your manual available for download.
Mar 28, 2008 | Brother IntelliFAX 885MC Plain Paper...
Hp laser jet 3880 fax/copier/scanner
Need a new LIU board the cost about 50.00
Mar 27, 2008 | HP LaserJet 3380 All-In-One Printer
Canon MultiPASS C555 InkJet Printer Logo
57 people viewed this question
old marine
old marine
