Question about Linksys Wireless-N WRT150N Router
CANT FIND SERVER AFTER FOLLOWING CONNECT DIRECTIONS ON WRT54G2 ROUTER. TERRY
  • 55 Answers
Upgrade the firmwere
i had the same problem
-tg
Posted on Jan 09, 2009
Slow internet speed when connected to router
So, If you have internet connection speed problem with your wireless try with the following steps,
1.)Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from www.ScanMySpeed.Com before and after following these steps.
Jan 26, 2013 | Linksys WRT54G2 Wireless Router
Show me how to connect linksys wireless
Hi
The Router configuration is not that much difficult, only few thing you have sure,
1) Correct ADSL Connection User name & password,
2) Chose unique ip address in All host.
Follow the mention bellow instruction to configure and connect to Wifi Router,
  • Plug the network cable ( Mine was Blue ) which comes with the Router Box pack to your computer. The other end goes into any of the Router Ethernet Port ( 1 or 2 or 3 or 4 )
  • Now type in 192.168.1.1 in IE or Firefox or any browser. You will prompted for password which is admin. You must be logged into Linksys Router.
  • Now since your ADSL modem is also having the same IP , we will change the IP address for WRT54G2 Router to 192.168.5.1
  • Under Setup >Basic Setup look for Network Setup and Change Router IP. Change to 192.168.5.1 and Save changes.
  • Since the IP has changed you will need to close the Browser.
  • Sometimes the IP doesnt change automatically. Do a IPCONFIG / RELEASE and then IPCONFIG / Renew
Making WRT54G2 Router talk to ADSL broadband modem
  • Plugin the Ethernet cable which comes from the Modem into the port on Wrt54g2 router which says Internet.
  • Open Internet Explorer and Type in 192.168.5.1.
  • Type in same password ( admin )
  • You will be in Setup > Basic Setup
  • Take a look at Section , Internet Setup. The current selection should be Automatic Configuration DHCP. Select Static IP instead.
  • Add following details to it. In the first step we backed up All the IP configuration. Use them here
Internet IP Address: . . .
Subnet Mask: . . .
Gateway: . . .
Static DNS 1: . . .
Static DNS 2: . . .
Static DNS 3:
ADSL Modem Settings to Wrt54g2 Router
  • Once Done just save changes and you should be back at same page.
  • Now try to connect any application which talks to internet. You should be able to connect
Configuring for Wireless Connection :Now once your Router is talking with Modem, it is pretty easy to connect on Wireless. The only thing we need to setup here is Security. Lets get WIFI
  • Get to the Lynksys page again. Do all login and regualr stuff.
  • Now look for menu Wireless, click on it. You should land on Basic Wireless Settings.
  • Select wireless configuration to Manual .
  • Wireless network mode to Mixed.
  • Give a Wireless Network Name (SSID), make sure its unique.
  • Make Wireless channel selection 11 ( 11 - 2.463 GHZ)
  • Select Wireless SSID Broadcast to Enable
  • Save Settings and you will be back at the same page with changes you made.
Now Lets secure the Router :
  • Go to Wireless Security on the same page.
  • You will need to configure here Security Mode : WPA Personal, WPA Algorithms: TKIP
  • WPA Shared Key is what you will need when you connect to your router without wire. This key does the authentication and keep unwanted people away. Add 8 digit alphanumeric key.
  • As suggested in comments, there is a new mode which you can use : WPA2 with AES
  • Save changes.Just make sure you save that key to a notepad or remember it.
Wrt54g2 wireless security
  • Now last step, Move to next menu Security > Firewall .
  • Uncheck Block Anonymous Internet Requests .
  • Save Settings.
Wrt54g2 firewall settings
  • Remove the blue cable which you had connected with Router.
That's it. Now just turn on your WIFI and Search for the router. The name should be visible. Click to connect. At this stage it will ask you for the Password or Shared Key which we configures just above. It will connect and you will be able to connect to Internet.
That's all Folks. This is how you connect WRT54G2 Linksys router with Adsl Broadband Modem. If you have any questions feel free to comment.
Aug 03, 2011 | Linksys WRT54G2 Wireless Router
Cant connect to linksys router wrt54g2 v1.5...able to recognize home connection not able to connect to internet...dsl modem works properly...I have the password and user info for the modem...please help...
Most modern DSL modems operate as a NAT. If you plug directly into the modem and get an IP address that starts with 192.168, the modem is the NAT. Instead of connecting the modem to the WAN port on the router, connect it to one of the LAN ports.
To see what your IP address is, assuming Windows, open a command window. At the command prompt, type "ipconfig" (without the quotes) and hit Enter. It'll return your computer's IP address.
The simplest way to test this is to simply connect the modem to the #1 LAN port, using the supplied ethernet cable. Power the modem and router down. Fire up the modem. When it's active, fire up the router. Now connect and see what happens.
Jun 18, 2011 | Linksys WRT54G2 Wireless Router
I lost my password for my WRT54G2 Linksys router. I need it to connect my other computer to the enternet.
To reset your router, use the following steps:
  1. Press the reset button for 30 seconds.
  2. The settings should now be returned to the factory default settings, meaning any changes you had made would be deleted.
  3. Open up your Web browser and enter "192.168.1.1? in the address bar.
  4. For the login, leave a blank ID and enter "admin" as the password.
Sep 28, 2010 | Linksys WRT54G2 Wireless Router
Wireless connection problem
hi
go to following link it will give you all your solution for wireless networking
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Jul 24, 2010 | Linksys WRT54G2 Wireless Router
MY LINKSYS WRT54G2 IS OK BUT CAN'T FIND SERVER.
The Linksys WRT54G2 is Cable/DSL router with 4 port switch. It has many features including a built-in DHCP server. By default, it's IP address is 192.168.1.1, username: blank and password: admin.
Plug in the Modem to the Linksys router's Internet / WAN port then plug your PC's to any of the 4 ports (1,2,3 & 4). The Linksys router once turned ON will automatically provide your PC with IP address starting with 192.168.1.xx (x means number from 100-149).
Make sure that known working ethernet cables are being used. Check your computer's IP adress by going to the command prompt. Start>RUN>type CMD then press Enter. Type IPCONFIG and check the IP address (e.g. 192.168.1.100). Check you PC's network adapter if you don't get an IP address from the Linksys router.
You may opt to reset the router by pressing the reset button at the back for 30 seconds if it fails to give out DHCP.
Cheers!
Angel
Jun 22, 2010 | Linksys WRT54G2 Wireless Router
I cant access my router
192.168.1.1 is the router's Ip address which will take to you to its ADMIN console. Defualt username is: admin and password is: password or admin. Try these. Once logged in you can then configure the router as required. Dont forget to set the WEP key to make your wireless network secure. WRT54G2 is the name of your router which is sending you the request to fill in the login details.
Please rate if helpful.
Thanks
Apr 12, 2010 | Linksys WRT54G2 Wireless Router
How to find security code for linksys WRT54G2 to
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here
for step by step Instructions on how to find the network key
Jan 28, 2010 | Linksys WRT54G2 Wireless Router
Tells me Unable to connect to Server
My iphone 3g is unable to connect to internet , even though it gets connected to my WIFI modem. Cant vierw any mails of cant even connect to websites thro safari or to Itune store....
Jul 16, 2009 | Apple iPhone Smartphone
VPN connection - Client cannot connect
Hi mwells960
Theres alot of differnet things i could ask you, but im going to assume you're jsut setting up a basic VPN. That means that somebody is telecommuting to work and wants to hit the server at work.
That means you have a static ip at work, and your at home workers has whatever, a internet connection lets say. Im thinking DSL with ATT since its a netopia 3347N.
If the netopia has a gui interface, you cant vpn thru it. Its not a VPN router. Its a residential router that you're trying to make do too much.
The sad news is, you can't upgrade it to an Enterprise having firmware router anymore, netopia use to offer that, but when Motorolla bought them out last year, they did away with that nice little feature. For true VPN'ing with a router, first, go get a VPN router to start with.
Most people accomplish what you are doing by putting the netopia in to bridegemode, and then putting a VPN router like a linksys behind it.
spin
Apr 15, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Linksys Wireless-N WRT150N Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
