Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Futura ce 200 not problem insalling on window vista
My software ran fine and is stuck at 100% have not been able to close the screen only minimize. Try to go back and uninstall getting message box stating "could not be installed / access is denided" I don't know what else to do. Here I am with a embroidery machine that I am not able to use. I hope singer can come up with a solution. Has anyone else have this problem.
You have to ctrl alt delete to get it to go away. If you look in the patch section it gives you the directions on how to patch it, and that is what it tells you to do. do the ctrl alt delete, and then end the install.exe, and then finish the install
Posted on Jan 17, 2009
Trying to use my futura ce-200. original software hangs on Win7 machine, updated software just says: entry point not found... the procedure entry point splash textcolor@@yaxk@z could not be located in
http://www.futura-support.com/products/ce-200/software
Make sure you downloaded the correct update. Reinstall the original software. Now right click on the program file (.exe) file in the software folder (prob on c:, folder called Futura **). Mine is different than yours...so end of file will be different, so I put ** instead). After you open the file folder...right click on the program file & choose properties; choose Compatibility; Check the run as box (mine is set to winXP 2); and check the run as administrator box.
Try opening the program...if it opens...you can then do the update install.
May 15, 2014 | Singer CE-200 Quantum Futura Computerized...
CE 100 Singer Sewing Machine Vista Premium
all you want to do is go to the store of singer sewing machine, they are the one who know how to download your software
Mar 27, 2010 | Singer CE-200 Quantum Futura Computerized...
Singer CE-150 Futura can not locate driver software?
Most probably you have a pc with Windows 7 or Windows Vista/XP 64 bit that are supported since latest Futura software versions. For 64bit support you will need a version 3.0.0.7 and higher, for WIndows 7 support a latest update 3.0.0.9
http://www.futura-support.com/downloads/ce150.html
Feb 20, 2010 | Singer CE-100 Futura Computerized Sewing...
Is the Singer CE-1oo Futura Windows Vista compatible? Also, can you put a #1 card in it to do the alphabet?
No it's not, All Singer futura users should be intitled to a 100% refund, or Singer should install new chips in the c-100's for former users. This is obsurb! you invest in the machine, and when the software upgrades itself, you are unable to use your machine. This is so awful
Nov 07, 2009 | Singer CE-100 Futura Computerized Sewing...
Singer CE0100 Futura connection error....
Hi I had the same problem sent question to Singer and this was their reply
"Do you have Vista 32-bit or Vista 64-bits? Unfortunately the CE-100/200 machine will not be compatible with either Vista 64-bit systems or the newest Windows 7 computers. The CE-100/200 will only be compatible with Windows 98 through Vista 32-bit operating systems.
This appears to be a hardware issue and not something that we will be able to create a patch to correct. Drivers necessary for 64-bit operating systems are not compatible with the CE-100/200 machines." so I guess we are SOL
Sep 27, 2009 | Singer CE-100 Futura Computerized Sewing...
Need a driver for vista
I have found some information and the news is not all the good.. Please read below what I have found.....
Singer Sewing Company With the recent release of Microsoft's Windows 7 OP system, many consumers are enquiring whether the Futura CE-100 and Futura CE-200 are compatible with this new version of software. Unfortunately due to the driver capability in these machines, an update or patch for Windows 7 is not currently available. We are continu...ing our research into creating such a patch, we ask for your patience during this time. If a patch becomes available we will announce it here. It will also be posted on our futura support site at www.futura-support.com. See More
safe_image.php?d=4bde5f922d15447b35f002d7e7cb03b2&w=90&h=90&url=http%3a%2f%2fwww.futura-support.com%2fimages%2flogo.gif Futura-Support www.futura-support.com
This article as written was found here on FaceBook
here is the link to see it if wanted
http://www.facebook.com/posted.php?id=45056394921&share_id=291608811659&comments=1
Jul 09, 2009 | Singer CE-200 Quantum Futura Computerized...
My software won't run on the vista windows
I had the same problem. I called a singer service center and he told me that was a major issue with the futura....no software made for Vista. I was determined to find a solution and finally found a patch. Here you go: http://www.futura-support.com/downloads/patch.htm#
May 12, 2009 | Singer CE-100 Futura Computerized Sewing...
Can not download software
I too am running vista and had problems installing software ... I called singer support and they walk me through removal of futura ( you have to be sure u remove the already installed clem driver) and ALL futura... then re-install.... my machine is running fine on vista now!!!!
Nov 20, 2008 | Singer CE-100 Futura Computerized Sewing...
Vista unable to install Futura software
I found a solution that seemed to work for my setup (Vista-Futura 200): Go to the Futura support site www.futura-support.com . Choose "Service Updates" from the left-hand Menu. Choose "Quantum® FUTURA™ (CE-200) Owners running Windows XP Service Pack 2 operating system WITH one or more of the Options (AutoPunch, CrossStitch, PhotoStitch, and HyperFont) installed". Look for the bullet-point list in the explanations. It says there: "If you own the AutoPunch Option and you could not successfully install it, download the Service Update by clicking here." Select the highlighted link, download the patch and install it. Worked fine for me, I hope it helps you, too.
Nov 03, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
62 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
