Question about Motorola Mobility Bluetooth Hands Free Headset Wireless Headset
How do i pair my H700 MOTORAL bluetooth to my verizon cell phone?
When i turn my headset on and try to pair them together, my cell phone says no match found.
  • 827 Answers
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’, but try '1234' again if that doesn't work
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Posted on Jan 09, 2009
I need to know the bluetooth pairing code for sanyo M1
Well I know for sure the default pin for the M1 is indeed 0000. However I cannot tell you what the pin would be for your specific bluetooth dongle. If I where you I would try 0000, 1111, 2222 and so on
  • As with all Bluetooth headsets, the H700 needs to be paired with the device before it can be used, which is done in pairing mode. In pairing mode, the H700 makes a transmission so that Bluetooth-enabled devices can pick up the device and connect to the headset. Once connected, no other device can connect with the Bluetooth headset. To enter pairing mode on the H700, open the headset boom located near the microphone. After a few seconds the indicator light will turn purple. Once purple, the H700 is in pairing mode.
Searching for the Device With the M1
  • Once the H700 is in pairing mode, have the M1 search for Bluetooth devices. To do this, press "MENU/OK" and choose "Tools," "Bluetooth," "Add New" and "Search." A list of Bluetooth devices will show up on the screen. Highlight "Motorola H700" and press "MENU/OK." Choose "Add to Trusted," enter "0000" and press "MENU/OK." The devices are now connected and ready to be tested.
Testing the Devices
  • Once the devices are connected, test that both the phone and the headset are working properly together. First, place the headset in your ear. Dial a number on the phone and press "Send." If you can hear ringing, the devices are connected properly and ready for use.
    If the connection was not successful, repeat the previous steps and try again. Make sure the indicator light is glowing purple and is steady. If you have connected the headset to a previous device, make sure that device is turned off so as not to interfere with the connection procedure. Once the other device is off, close and reopen the boom to enter pairing mode.
Feb 16, 2012 | Sanyo Cell Phones
How do i sync my phone with the h700
Hi, Motorola H700 Bluetooth headset is a basic Blutooth headset that can be synced, or paired, with any Bluetooth-capable cell phone. Something unique about this phone is its retractable microphone, otherwise known as the headset's "boom." You can send and receive phone calls hands-free and wirelessly with your contacts using your H700 headset, in one touch of a button.
instructions
Press and hold the "Call" button on the headset for four to five seconds until the LED light glows purple.
Flip open the headset "boom."
Set your phone into "discovery" or "pairing" mode. Open the Bluetooth settings or options on your phone and choose to add a new device.
Select the "H700" on the phone when it finishes searching for Bluetooth devices.
Enter the passkey for the headset, which is "0000," to finish syncing the headset with your phone.
And your done..
Hope it helped.
May 30, 2011 | Motorola Mobility H700 Wireless Headset
My h700 bluetooth will not go into pairing mode
hi sammieyoungj. i'm sorry to hear about your troubles with your headset. Maybe this will help your situation. Ensure the headset is fully charged. Then turn on the bluetooth feature (discoverable mode/set to look for bluetooth devices) on the phone you are planning to pair it with. Next, turn off the headset by closing the microphone boom. After about 8 to 10 seconds or you know the headset is off, press and hold the call button for about 4 to 5 seconds. The headset should activate and show a steady purplish colored light. When the light turns purple, unfold the microphone boom. If the lights stay a steady purple color, then the headset should be in pairing mode and you can revert to your phone to pair them together.
If the light does not stay steady, or turns a blue color, repeat the steps above, making sure no bluetooth devices are around that it may have paired with previously. Hope that helps. Best of luck.
Mar 05, 2011 | Motorola Mobility H700 Wireless Headset
Can't pair bluetooth H700 to my phone.
Here is a detailed solution on how to pair your H700 headset with your phone;
STEP 1 You have to firstly put off the headset,by holding the call control button,which is the button on the face of the bluetooth,until the blue light turns red,as soon as the blue light turns red release the button.
STEP 2 After putting off the headset,wait for like 5 secs to ensure its completely off.when the device is off,you can now press and hold on the call control button for 5secs if its the first initial pairing,if it's not,then you have to hold on the call control button for 8seconds,afterwards the light should flash red then blue in both cases
STEP 3. At this point in time your headset is in discovery mode,and you have 60 seconds to pair it with your phone which should also be in the pairing mode as well.
To put your phone in the pairing mode,you have to put on the bluetooth of the phone which is found under the connectivity settings in the menu.
Your h700 headset and your phone are matched up and your problem is solved.
Thanks and take care
Aug 23, 2010 | Motorola Mobility H700 Wireless Headset
I can't connect my EnV2 to my Jabra Bluetooth. Is there a trick?
It could as easy as updating your phone by dailing *228 with a Verizon phone, select option 2 then press ok when the update is complete. When the phone resets, turn on the bluetooth headset, a prompt on the phone should come up to enter the passkey which should be 0000
Sep 01, 2009 | Motorola Mobility H500 Wireless Headset
Im trying to pair my verizon cell phone to my motoral headset
6) You will be required to enter in a pass code which is standard ‘0000’.
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | Motorola Mobility Bluetooth Hands Free...
Motorola bluetooth pairing
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Pairing LG VX8700 with Motorola H700
try to power cycle the cellphone by turning it off and remove battery, then reinstall and turn it back on
For headset pairing
How to pair the phone with a Bluetooth™ headset The phone identifies and maintains up to 16 devices which are displayed in a list. To add a new device or pair a headset via bluetooth, turn Bluetooth™ on in both devices.
  1. Put headset in pairing mode. See Headset User Guide for more information, if needed.
  2. Turn on Bluetooth in your phone, Go to menu, [SETTINGS] > [CONNECTIVITY] > [BLUETOOTH] and press "Select"
  3. Choose [TURN ON] , press "Select"
  4. Choose [MY DEVICES], press "Select"
  5. Choose [NEW DEVICE], press "Select"
  6. Choose the headset to be paired and press ' Select '
  7. Enter the pass key '0000', press "Ok"
Link for headset setting, just choose the headset model
http://www.sonyericsson.com/cws/support/products/pairinginstructions/w300i?cc=us&lc=en
If you are using a different device the just set the Bluetooth to on on it as well
Apr 22, 2008 | Motorola Mobility H700 Headset
H700 unable to pair up 'service not supported'
The term "service" refers to other types of services supported by bluetooth technology like keyboards, mice, etc. There's a lot more than just headsets now. I suggest checking the bluetooth options on your phone to see if there is a refresh service or other option....there is one like that on my blackberry that I once had to use to solve a similar issue. Have you tried disabling bluetooth, rebooting phone, enabling bluetooth, and rebooting phone before pairing? Also, look to see if there is an encryption on/off option on the phone...this could be causing an echo in either state due to interference...try switching encryption on/off. Also, check your update options on the phone, you didn't say which kind of phone it is but some can get firmware updates that may be needed for bluetooth to work well. Finally, you may get results by deleting the device on the phone and re-adding it thru discovery.
Jun 23, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility Bluetooth Hands Free Headset Wireless Headset Logo
208 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
