Question about Kenmore Elite 45986 Front Load Washer
Code "F 35" What does this mean?
I just hooked up my new Kenmore Elite HE 5T washing machine. It suggests to run the express cycle without clothes first. When I did this the code "F 35" was displayed. What does this mean?
  • 15,935 Answers
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Kenmore washer
You can check the belt. It's posible to be worn out.
All the best !
Oct 02, 2017 | Kenmore Washing Machines
Kenmore Elite HE 5t 4778 (or 4779?) : Stopped during cycle and flashes the code F 35. I had to pull the plug to re-set the washing cycle, as pushing the stop button twice as instructed did nothing. What is...
If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked
Check the drain pump filter for debris
If all the above checks out good . This would indicate that the pressure switch or also called the analog pressure sensor has failed. First you will need to remove the top lid. Usually 2 or 3 screws on the back and the top comes right off. The pressure switch has a clear hose and a clump of wires going to it. Then unplug the hose and blow thru it it should be clear. Check the hose for leaks or obstructions. Also in the back of the washer on the left hand side is a air dome this is where it gets it pressure reading from, make sure it is not obstructed. If all is clear the pressure switch will need to be replaced. Here is a link to help with accessing the pressure switch also if you need diagrams or illustrations of your particular model.
Sep 30, 2010 | Kenmore Washing Machines
I have a kenmore elite he3 front loader; it gives me the "sud" code during a wash cycle. What could be the potential problem?
either way too much soap or the wrong type,run a couple of washes,without clothes to purge excess soap and see if this clears up the sud code
Jul 07, 2010 | Kenmore Elite 45986 Front Load Washer
My Elite Kenmore HE 5t Steam on Bulky setting will not run shows F99 error code what does the code mean?
The F99 error indicates the interface and central control are not compatible.
It means you selected a cycle on the interface that the central control does not recognize.
Usually this means the two controls are not compatible which might happen if an older control was installed in a new machine.
If the washer is brand new then I suggest scheduling a warrantee service call.
The only thing I could suggest you try yourself is to enter and run a service test.
The instructions to do so are in the image below.
(Be sure to press the button for a full 4 seconds.)
Perhaps this will reset and coordinate the interface and control.
http://media.fotki.com/1_p,sskrstwsgdkssbtxgtqsskgwtqkq,vi/rqfqbsgwdxsbftrkdks/1/1303472/5961857/image7062766216422141446img-or.jpg
Jan 25, 2010 | Kenmore Elite 45986 Front Load Washer
My kenmore elite He 5t wash machine is flashing F
This typically indicates slow drain condition. Check for any clogs or kinks in the drain line. Also check that the pump is not clogged and that no pump impeller blades are missing/broken and that the impeller moves freely. Any broken/missing blades or if the impeller won't turn freely will indicate a faulty pump. Hard objects can sometimes make it to the pump and cause damage. Hope this helped and best wishes.
Sep 09, 2009 | Kenmore Elite HE5t Washer
I Kenmore Elite mod# 110.22062102
The "Ld" error means long drain. May require a new pressure switch
Aug 03, 2009 | Kenmore Washing Machines
Code F20 is appearing on me washing machine
http://www.fixya.com/support/r3608632-f20_error_code
May 27, 2009 | Kenmore HE2 Plus Front Load Washer
F 11 code
The electronic control board is damaged. It needs to be replaced. I think its Part#8182237. As of this date, it is on back-order. Check your warranty book on this part, it is highly expensive. It may be covered under a 2-5 yr. part only warranty.
Sep 03, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he (5t)
You can wash Shoes in it... But the manufacturer does not recomened it.. I would suggest that you remove the laces and you should be just fine
good luck
May 27, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
156 people viewed this question
Sal De
fordexpert
Robert Rankin
