Question about Dell Inspiron 1501 Notebook
My Dell Inspiron E1705 screen went blank. I can hook it up to a PC monitor and it works fine....just bulky as hell.....Help
  • 1 more comment
  • janineharri Jan 09, 2009
    It seems to have happened out of the blue
    In the dark......I can barely (and I mean barely) see the screen.
  • Sean Osborne
    Sean Osborne May 11, 2010
    Did you drop or bang the laptop, or did this just happen out of the blue?
    Problem Solver:
  • 11 Answers
Sounds like your CFL tube or the inverter than powers the CFL tube have died. It is something that a standard dell warranty would cover, first go to www.support.dell.com click on warranty information in the upper left hand side of the screen, then click on "Warranty Status" It will prompt you for your "Service Tag" which can be found on the underside of the laptop on a small oblong sticker about 1/4 inch wide and 3 1/2 inches long. If your able to veriy that your warranty is in good standing you can chat (recommended) or call into technical support explain that 1.) there is an image on the screen BUT theres no backlight so you cant quite make it out. 2.) A known good External monitor works just fine so you know its not the videocard itself. If however you have no warranty, you could buy a Replacement Monitor assembly from Dells Spare Parts department 1-800-357-3355 Or purchase a replacement inverter for around $20-$50 (just google Dell E1705 Inverter) but that would require the ability to A.) replace the inverter assembly on your own B.) Hire someone to replace it. your final option would be to buy a replacement panel from a third party, which usually costs somewhere around $150-$250 dollars depending on what you buy, and that is actually a pretty simple thing to replace once you get around the intimidation factor. Be sure you check your warranty first, you could save yourself alot of blood sweat and tears by doing so.
Good Luck! (if you have any problems with Dell and you have a warranty let me know)
Posted on Mar 28, 2009
    Problem Solver:
  • 21 Answers
If you display don't have problem ,
it should be the inverter for check inverter you may find here
Posted on May 16, 2009
  • 33 Answers
Well, it's one of two things, both hardware: Either the monitor died, or one of the connections - power or graphics ribbon - burned out.
This is not a d-i-y sort of fix, unless you love to tinker and are willing to declare the laptop a possible dead loss. You need an experienced tech to open the case and diagnose the problem, then replace whatever is broken.
I'm sorry to be the bearer of bad news.
Posted on Jan 09, 2009
  • Sean Osborne
    Sean Osborne Jan 09, 2009
    OK, your last comment about seeing the screen (barely) in the dark might hold out some hope. It could be the ribbon that carries the graphics signal to the screen has come loose. This ribbon runs through the laptop hinge, so they do pull loose sometimes.
    Still, it's a job for an experienced tech, unless you want to risk poking around inside your laptop yourself. If you want to give it a try, let me know and I'll try to give some pointers.
I have a Dell e1705; I had an external monitor hooked up when the LCD display died. I continued to use it with ext. monitor. However, now on re-boot it won't boot with external monitor unless I go the...
I think now problem is from Monitor side,Check with another monitor and also possibility of VGA driver problem,so reinstall driver for VGA.I think it helps. Let me know.
Jan 08, 2011 | Dell Inspiron E1705, Intel Core 2 Duo...
Dell Inspiron E1705 monitor changes brightness
If you have your Dell driver disc have to uninstall the video adapter driver and reinstall it. Restart the laptop and observe if things still happening. No need to do an update for the video driver though on this regard. Or on the other hand try to do a System Restore. Restoring your computer profile/settings on the previous date that it was working fine. But before you gonna do that have to back-up first the important files that you have to your external hard drive or USB flash drive. Hope these things help. Thank you.
Oct 09, 2009 | Dell Computers & Internet
Dell Inspiron E1705 does not show any picture
First of all, check that the laptop is set to output video to the LCD. There should be a function key which will determine whether it is outputting video to the built-in LCD, the external monitor, or both. That should be holding down your "FN" key and hitting "F8." If it is on CRT ONLY, it should switch within 1-2 keypresses.
Secondly, take a good bright flashlight and shine it directly at the LCD panel from about 1-2 inches away. If you can actually see the graphics on the screen faintly in the background, your backlight is not turning on. The backlight is literally a bulb which lights up the screen, and they can burn out. It is repairable, and shouldn't cost more than $150.00 from a reputable repair shop.
Sep 01, 2009 | Dell Inspiron E1705 Notebook
Loss of light on screen Dell Inspiron E1705
Check your backlight settings, Power Settings, etc.....
You may have Vista (vista has other power settings such as a custom sleep mode which can fail sometimes to work properly with some hardware/monitor configurations).
So Disable any unconventional Hibrid Hibernation options k!
Apr 20, 2009 | Dell Inspiron E1705, Intel Core 2 Duo...
Spilled soda on it!! No picture!
i think you just damaged the wiring, soda is like some kind like a acid. which can do so
Feb 05, 2009 | Dell Inspiron E1705 Notebook
Spilled soda on it, screen doesn't work now...
boot the laptop up, plug in monitor
press anf hold fn key on keyboard, now tap f4, keep hitting f4 until both monitor screen and laptop screen come on
Feb 05, 2009 | Dell Inspiron 1501 Notebook
Dell Laptop E1705 Screen goes Blank
If your video output works fine when connected to an external monitor, then the issue is with the LCD display panel. I’m afraid the only way to fix this is have the LCD panel replaced. The ribbon cable that plugs the LCD panel into the motherboard could also be the culprit. Here's a link to the display assembly for 1501: http://support.dell.com/support/edocs/systems/ins1501/en/sm_en/display.htm#wp1022270
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Jan 09, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
1,535 people viewed this question
Alun Cox
