Question about ASUS P4SP-MX Motherboard
Hello my problem is that i am trying to set the frequency of the cpu of p4sp-mx mother board i cleared the jumper thena restart was required but now there is no display on my monitor
  • 43 Answers
You might have over clock it. You will need to reset the bios. to do thet you will need to open you computer and bull the mmcc bettery adn with 10 sec befor bull it in again.. then it will work..
Remember to rate if what i say whos to any help
Ty
Posted on Jan 09, 2009
Mother Board problem
use bios CD update bios on the mother board.ok
after that cpu fan...refix the cpu fan after cline,
apply the paste on the Proccessor.it working fine
Mar 16, 2010 | ASUS P5GC-MX/1333 Motherboard
I want to disable chasis intrusion switch. Beacuse mother board perfectily well out side cabinet ,but does not boot after fitting inside cabinet
ok do it only if u r a professional..'
refer to the extreme right-hand-bottom [as ur back panel to the left n cpu to the top] of u r mother/main board..in here there is a 3-pin jumper named 'CHASSIS'..place a jumper or set it to pin-2-3 [the middle n right pins respectively]..
hope it'll work..for reference :
http://www.filefront.com/4169747/P4GE-MX-Users-manual-for-English-Version-E1862/
always better to seek professional advice of ur system admin/vendor....
Nov 16, 2009 | ASUS P4GE-MX Motherboard
I added a Pentium P4 2.66Ghz cpu 533FSB, Bios appears and says the due to new cpu installed system has started at 64Mhz please select correct Frequency. I select 2667 Ghz and 133Mhz saved and restarted....
Turn the computer off.
Turn the computer on.
Wait a minute or two -- it may "time-out" and reset it to the "slowest" speed.
If that fails, look closely at the motherboard,
or read the manual for the motherboard, to find a "clear BIOS" jumper.
Turn the computer off. Move the jumper from "1-2" to "2-3".
Wait a few seconds. Move the jumper back to "1-2".
Turn the computer on, with the "default" settings.
Oct 28, 2009 | ASUS P4S533-MX Motherboard
No manual for conecting mother board
http://dlsvr03.asus.com/pub/ASUS/mb/sock478/p4sp-mx%20se/e1676a.pdf
CLICK ON THIS LINK AND DOWNLOAD THE USER GUIDE IN PDF FORMAT WHICH U CAN READ ON A ADOBE READER
RAHUL
Feb 22, 2009 | ASUS P4SP-MX Motherboard
My Mb does not give any sign, . What can I do ? Everything is desconnected except power on the Mb and the Mb switch. I switch the machine on and the only thing works is the CPU fan No any beep
Sometimes you have to have the motherboard , power , cpu , memory and 1 drive connected (IE the basic components) to get the system running
Also check the jumper settings where the board connects to the power switch on the case
Jan 22, 2009 | ASUS P4SP-MX Motherboard
When ever I start my computer it directly goes to bios settings and it says *********** board frequency not set properly. I tried with every kind of frequency but it did not work out and also it takes...
You should check the BUS frequency as well, for the RAM. If the ram and mobo frequencies aren't set in a pair, but board won't work properly. Is there an option to set to factory defaults? I'd use that.
Jan 10, 2009 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Problem with motherboard
When ever I start my computer it directly goes to bios settings and it says *********** board frequency not set properly. I tried with every kind of frequency but it did not work out and also it takes long time to get start.
Mother Board - ASUS P4BGL-MX , I bought this 2004. Please give me the solution.
Aug 30, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Powering up my computer
Hello there.
Your motherboard has 4x Serial ATA connections , as you are using 1 already this means you can add a total of 3 SATA new HDD to the system. Size doesn't really matter but thesedays you should be able to get good value for money on the 200-500GB version of the sata drives.
If you have windows installed already on the existing 40GB, then you can add the new HDD alongside the existing, then in Windows set up the new HDD as a new drive letter, giving you all the free space to save your files on.
Hope this helps.
Apr 15, 2008 | ASUS P4SP-MX Motherboard
Motherboard Jumper free code
Set Jumper Free Mode (manual) and new FSB in BIOS Setup - menu "CPU External Frequency (Mhz)".
Oct 24, 2007 | ASUS P4SP-MX Motherboard
ASUS P4SP-MX Motherboard Logo
91 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
