Question about Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator
Kenmore 106.53342300-side by side-icemaker not working..at all
Recently bought house....with this refrigerator already installed...it was not in use (pluged in and cold, but not used) for many months. Freezer works just fine. Water from door works just fine. There is no water entering the icemaker, therefore no ice. Ice maker makes no noise, no movement, nothing....just sits there.
  • dlhamrick Jan 10, 2009
    Would the water inlet valve be the same one for the through the door water dispenser...which works just fine...or are there seperate water inlet valves for both water and ice maker??
    Also, if the defrost timer is bad, wouldn't I notice that inside the freezer....with build up?? There is none after several months of operation???
    I really appreciate your help
    Problem Solver:
  • 15 Answers
IT COULD BE 2 PROBLEMS
1 .YOUR DEFROST TIMER IS BAD.
2. YOUR WATER INLET VALVE IN THE BACK COULD BE BAD.
BOTH PARTS ARE VERY INEXSPENSIVE(USUALLY UNDER 20 BUCKS AND YOU CAN GET FROM YOUR LOCAL SEARS OR ANY WHERE ON LINE. GLAD TO BE OF SERVICE
Posted on Jan 09, 2009
  • greg kephart Jan 12, 2009
    yes that valve woulld be the same it actually has two water inlet valves go off of the one you hook to, most likely one of them is bad have to replace the whole valve but its eassy and very inexspensive. glad to be of service
Kenmore coldspot model 5155 2101 we just replaced the ice maker. I can fill it with water, it freezes and dumps but does not refill. the water dispenser on the door works fine
From what you are stating this is a dispenser refrigerator with 1ce/water through the door. This type refrigerator has a dual sided water inlet valve. It looks like the half that fills the icemaker may be bad or may have the power connector that came loose. This is the part on the back that the house water line connects to. It should 2 wires going to each of the 2 coils (total 4 wires). If wires are connected, I would say 1 coil is bad and the valve needs replaced. Since you already replaced the icemaker that rules that problem out.
Apr 12, 2015 | Kenmore Refrigerators
Ice maker not working
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2010 | Kenmore 57029 Side by Side Refrigerator
Replace icmaker on kenmore
Unplug refrigerator. Take a moment to examine how the icemaker is positioned in the freezer compartment prior to proceeding (e.g.: water inlet tubing coming into the icemaker, etc.). Remove or loosen (where applicalble) screws holding icemaker. Unplug icemaker's wire harness connection. install new icemaker by reversing the screws harness, etc. Make certain that the new icemaker is in the "on" position. Plug the refrigerator in. Allow approximately 6 to 8 hours (some models take fewer or longer timeframe) for ice production.
Feb 10, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Icemaker not working after installing new filter
I have a Kenmore 106.56542400 icemaker stoped working ,water line is cleared not getting water to icemaker
Jul 02, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
How to install Kenmore icemaker
2 screws on top of icemaker into wall (loosen almost all way) 1 screw bottom remove. pull IM up and off of 2 screws and disconnect wiring plug from IM (depress tab). reinstall in reverse.
Jun 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side 253.54662400 makes hollow ice cubes - do not dump
yes i would replace the icemaker. it sounds like the heater and ejectors have lost their sync. could be caused by the internal drive motor.
Jun 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice Maker problem
check if it has one the filter, hollow ice = lack of water flow into the icemaker
Apr 26, 2008 | Refrigerators
Ice/water supply inadequate
When installed some debris may have gotten into your water valve and partially clogged it which is located where the water line hooks to your frig. Stargazer
Jan 12, 2007 | Kenmore 55692 / 55694 Side by Side...
Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator Logo
348 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
