Question about Microsoft Xbox 360 Console
Xbox 360 plays in black and white
Checked with different tv's and cables. not on HD mode. was working fine for a long time, just started doing this. at first if i turned it off and on or if i kept it on for a while i could get color back. now it's black and white all the time. please help!
  • Anonymous Feb 25, 2009
    The color on my 360 is black and white, I dropped it on a pile of sneakers then tried to connect it to another tv, thats when the problem started.
    Problem Solver:
  • 10 Answers
Well, I have a couple of solutions that might work...
  1. Check your AV cables, it's possible that they could be the main problem (or try purchasing/borrowing a new cable to test with)
  2. Check your TV's settings, such as if it's NTSC or PAL (if the option exists) and it's colors.
If it's not the TV at all, then I'd say it's definitely #1 -- especially if it's a "Mad Katz" cable. Also, be sure that the AV cable is tight into the ports. One last suggestion would be to try a different TV. Hope this helps! Rob
Posted on Jan 09, 2009
XBOX NOW PLAYS IN BLACK AND WHITE WITH OLDER TV DID WORK FINE AND DOES ON NEW HDTV ALL CABLES GOOD NOT SURE WHAT TO DO TO GET COLOR BACK
There is a switch that changes the video cable from SD( for use with older TV's without high definition connectivity) to HD (used for newer HD TV's with high definition.
If your older television is using a composite (yellow) connection for video, make sure the switch is in the SD position and NOT hd.
Mar 02, 2011 | Microsoft Xbox 360 Console
Had the box 360 60gb for 3 weeks. Been running it via the tv scart option with yellow wire and audio red & white. Worked for 3 weeks until during playing Assassins Creed Brotherhood the screen went...
Maybe someone stepped on your cables try getting different cables.
For example if your tv is hd get a hdmi cable or buy another set of those cables.
Maybe it will help.
Jan 04, 2011 | Microsoft Xbox 360 Console
I have an Xbox 360, and when I got an HD tv, I got the HD cords for it and when i use the switch on the cords to go from standard tv to HD, my screen goes black and i get diagonal lines that run up the...
Either the cable you are using is no good, or there is an issue with the internal video subsystem. Try changing cables, and if possible, try a different input on your display. If the issue still exists then you may have an internal issue. The only way to diagnose this is to have your local Xbox repair center diagnose it unless you have the tools and experience to do it yourself. Certain parts of the subsystem can be replaced, but for the most part the entire system is replaced.
Mar 04, 2010 | Microsoft Xbox 360™ Premium White Console
My XBox 360 does not show up on the tv screen, but it has sound.
this happens a lot. what happend is the red white and yellow wires that you put in the back of your tv. the red one is not in the right area or
there is a switch right were you plug in that cable with the red whit and yellow cables to your xbox that says hd or normal switch that to whatever your tv is
Jul 17, 2009 | Microsoft Xbox 360 Console
No sound or video on HD and TV modes
I would see if the cable is the issue. If not, you may have a nice new paperweight. Microsoft should fix this for $100 or you could buy a brand new one for $200.
I had this same issue with XBOX 360 #3.
May 13, 2009 | Microsoft Xbox 360 Console
NOO black xbox 360 screen and sound do not work and only day 4
Check to make sure all your cable is plugged in all the way, and if you are using the HD cable, that it is switched appropriately (regular TV to "TV" and HDTV to "HDTV"). If all that is well, call Microsoft, your system is under warranty and they will RMA it.
Dec 30, 2008 | Microsoft Xbox 360 Console
Xbox 360 won't work in hd
is ur tv has just red white and yellow then ur tv is not hd trust me
Oct 26, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
A GREEN HUE!!!
U have to make sure your xbox 360 is set to the HD pixels as your tv.
Dec 13, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
234 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
