Question about Kenmore 25812 / 25813 Progressive Bagged Canister Vacuum
Blows dust and dirt out of brush area
My vacuum is sick! When I try to vacuum with it, all that happens is that it blows dust and dirt into the air. It does suck up some stuff, but leaves large clumps of cat hair afterwards. I have cleaned the hoses, filters, and changed the bag. What now? Sheri
Re: blows dust and dirt out of brush area
Did you make sure to cut all the strings, hair, etc. out of the brush attachment on the bottom? Look in the corners too to make sure none has gotten stuck on the sides that needs to be cut out.
Posted on Aug 10, 2007
0 characters
3 Points
Why don't my robot brushes turn?
Remember that at least every week you need to take out the brushes, and pretty much everything else that is removable and thoroughly clean them, including the brush hubs. If you have access to compressed air, gently blow out dust/dirt from all the sensors. Regular cleaning is mandatory to keep your Roomba running correctly. In my experience, a good cleaning solves most Roomba issues. Regular cleaning prevents most issues.
May 18, 2014 | iRobot Roomba Discovery SE Bagless Robotic...
Eureka vacuum blowing dust into the air
Check the leak (where the dust come from); maybe you need to tighten or reseat one or more part in that area.
Feb 09, 2014 | Eureka AirSpeed One Turbo Bagless Upright...
All of a sudden my hoover vacuum cleaner blows and does not **** I live in South Africa.All my other appliances work normally from the same plug
Take out the screws on the bottom and any on top
to expose all parts of vacuum
Look for a blockage of dirt and dust
Really need an air hose to blow out real good
Remove and clean ends and bearings on
rotating brush
Check for worn or broken belts
Jan 30, 2011 | Hoover Vacuums
My Bissell bagless vacuum does not seem to work anymore. It will start to with a suction and then instead of picking up the dirt, it appears to blow the dirt out almost in a cloud of dust and debris from...
this is caused by a dirty air filter and/or a blocked vacume hose ( most of the time the blockage is at the bend where the hose enters the floor sweeper area ) ---
remove and tap out and brush the filter ( or use a air compressor to blow out filter ).
then with the vacume on its side - remove the bottom plate ( like you were going to change the belt ) and use a coat hanger and clean out the hose between the floor sweeper and where the suction hoes attaches. this will restore your vacume to full operation.
Jan 23, 2011 | Bissell 6595 Lift Off Bagless Upright...
Seems to **** up the dirt/dust and simply blow it out instead of capturing it inside
Most of these have an suction hose and a blow port. One blows air, one sucks air. Make sure the suction hose is on the correct port. Also, a dirty air filter will cause the same effects. The filter must be good to prevent the dirt and dust being blow around.
Nov 08, 2010 | Craftsman 17026 Wet/Dry Vacuum
Dirt Devil bagless upright. sucks up dirt in the front and spits it out in the back. I have taken it apart to check for visible clogs in hoses and checked belt and rollers all of which are fine. what next?
There seems to be no vacuum drawing the debris away from the brush head. Remove the debris canister to check for air blowing into it. Check particularly, the area where the brush head pivots off of the upright portion. Hope this helps!
Jul 26, 2010 | Dirt Devil M110000 Bagless Upright...
Hoover Tempo Widepath Blows Dirt Out Back on Hard Surfaces
lots of times switching to hard surface floors you need to slow down because the air flow that does the actual picking up of the dirt can't work as fast as the spinning brush so the brush is throwing the dirt out the back before the suction can pick it up. Try slowing down
Jun 11, 2009 | Hoover Tempo Widepath Upright Vacuum -...
How do I change the belt for my dirt devil vacuum cleaner? It blows out dust.
To change the belt, take off the bottom plate, the belt runs between the brush roll and the motor shaft. But if it is blowing out dust, you may have a clog in the dirt inlet by the brush roll, or in the hose.
Mar 23, 2008 | Vacuums
Dust blowing out of my vaccuum cleaner
Usually when dust is blowing out it is caused by a clog, either the hose, or the dirt inlet down by the brush roll is clogged. Check them and clean them out and you should be ok.
May 30, 2007 | Bissell 3522 PowerForce Bagged Upright...
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Kenmore 25812 / 25813 Progressive Bagged Canister Vacuum Logo
694 people viewed this question
Top Kenmore Vacuums Experts
Roger Potts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
