Question about Viking VGIC3074 Gas Kitchen Range
Viking gas range makes a skskkkksssss noise when using the oven intermittenly
I have the exact same range and the same problem. There was also a gas smell that burned my eyes
The whooshing sound is because there is too much pressure in the burner, forcing some of the gas to come out where the orifice goes into the burner. I know this because there was a carbon build up in that location.
It turns out that the oven burner was drilled and then formed into the "u" shape while very hot. That distorted the holes in the burner. I got a small drill the same size as one of the "good" round holes and re-drilled all the holes in the burner. The only thing to be aware of is the "cross over" holes that go from one side to the other are a little smaller then the main holes that go around the perimeter. Now there is no smell, no whooshing sound and it works beautifully. Needless to say, we were very disappointed having spent the extra money for a supposedly "quality" product only to have it perform badly with no service man with any knowledge of the problem. I went through the whole range just to check it out. I found 22 problems. Mostly small, but things that should not have been allowed to get through quality control. Seems there is very little of that in Vikings Mexico plant. One thing in particular that was a safety issue (other than the oven burner) was a plastic grommet meant to protect a wire going through some sheet metal. The grommet was too small and was just sitting around the wire instead of locking into the hole in the sheet metal. Thusly, the wire was aloud to "chafe" on the metal where it went through. I suggest you look very carefully at as much of the range as you can, just to be sure. Good Luck, Wade
Posted on Jan 20, 2010
  • 23 Answers
Could be the burner is plugged up and the gas is not coming out all the way. Try cleaning out the whole with a paperclip.
Posted on Sep 04, 2009
  • 59 Answers
It sounds as though air/gas mixture needs to be adjusted.
Close the port on the burner so it has about 1/4" open.
If this doesn't work then the orifice may be a size or 2 too big and needs to be reduced
Posted on Mar 06, 2009
Viking VGIC oven burners ignite but cycle off repeatedly temperature rarely gets to 300 after 30 minutes. If igniters ignite is problem elsewhere - like bad bi-metal valve? Range and broiler work OK,
There is a sensor that detects the oven temperature, it must be defective and sending a signal that oven is at set temperature and this shuts off the gas valve.
Nov 02, 2016 | Viking Kitchen Ranges
Griddle makes backfire noise
I get the same sound but I found it is actually coming from my stainless steel backsplash, it seems like the heat makes it flex from time to time.
Jul 10, 2010 | Viking VGIC485-6G Gas Kitchen Range
My Viking range is making a gushing noise when the
Jan 10, 2010 | Viking VGIC485-6G Gas Kitchen Range
Have a Viking range, gas top, electric oven, neither work.
Check connector block where electric is brought into stove for loose or burnt wires. Check Breaker in house power box. Push the breaker firmly to off and then return to On position. Read owner's manual to see if ignitor circuit has a fuse and check said fuse.
Sep 12, 2009 | Viking 30" Dual-Fuel Range, VDSC3054B...
Viking oven
We had a hurricane come through and power was out at our house for 2 weeks. The top burners worked but the oven would not. Our outside gas grill worked perfectly also using the utility provided natural gas. We were told by Viking that the oven is designed to work only when there is electric power. This is a safety feature, according to Viking.
Sep 22, 2008 | Viking VGSC306-4B Gas Kitchen Range
Viking VGIC3074 Gas Kitchen Range Logo
489 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
