Question about Zenith DVT216 System
DVD playback problems
My Dvd player is displaying a "check regional code" on the Tv screen while the unit is displaying a disc error message. The dvd's I am trying to play I have played before w/out any problems and the player will still play music cd's please help
  • 64 Answers
Did you buy these DVD's out of the country? Are they burned? did you pick English and the United States of America when you set up the dvd player? Try unplugging the player for an hour, plugging in and resetting everything up
Posted on Jul 26, 2007
SOURCE:
Logik Tv Manuals
Each DVD-Video disc contains one or more region codes, denoting the area(s) of the world in which distribution and playback are intended. The commercial DVD player specification dictates that a player must only play discs that contain its region code. In theory, this allows the motion picture studios to control the various aspects of a release (including content, date and price) region-by-region. In practice, many DVD players allow playback of any disc, or can be modified to do so. Entirely independent of CSS encryption, region coding pertains to regional lockout, which originated in the video game industry.
Nov 15, 2013 | Televison & Video
I have 2 problems with my lg hb 966trw: a)
follow this steps and fix it. God bless you
No power
  1. Check if the power cord has been properly connected to the power outlet.
  2. Check if the main power has been switched on.
    (DVD player's power supply transformer could be burned out)
Screen is "frozen" or completely black, or Power button does not work
  1. Try turning the power off and wait 3 seconds before turning it on again.
  2. Make sure the TV and VCR (if connected) are set to the correct channel or line.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
switching regions:
    • 1
Turn on your DVD player.
    • 2
Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
    • 3
Push "Info" or "Setup" on your remote.
    • 4
Use the remote to select the "Region" option as indicated on your TV screen.
    • 5
Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Oct 30, 2013 | LG Televison & Video
Hi I have a samsung DVD player model number p181 & when I insert DVD message comes up wrong regioncan you please help, thanks
Hi,on most of the DVD players regional set up cannot be changed.
As an easy solution ,you can play them in your Laptop and with proper connection you can watch them on your TV as well..
Hope this helps! Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
DVD region codes are a digital-rights management technique designed to allow film distributors to control aspects of a release, including content, release date, and price, according to the region.DVD video discs may be encoded with a region code restricting the area of the world in which they can be played.
The American DVD Copy Control Association in California requires that DVD-player manufacturers incorporate the regional-playback control (RPC) system - according to the Australian Competition and Consumer Commission, an Australian government agency.[1]
There are six different official regions and two informal variations.[citation needed] DVDs may use one code, a combination of codes (Multi-Region), most codes (Region 0) or every code/no codes (Region All). The commercial DVD player specification requires that a player to be sold in a given place not play discs encoded for a different region; however, region-free DVD players are also commercially available.[2] In addition, many DVD players can be modified to be region-free, allowing playback of all discs.[3]
Jun 27, 2011 | Audio Players & Recorders
Portable dvd player when you put disc in machine it comes up with wrong disc display on screen is it the settings
It would more likely be the types of discs used. They are either of a region code not compatible with the player, contain foreign/unknown data, or they are unsupported formats. For example, if the player supports DVD-R playback, and you put a DVD-RW in, the player will generate 'wrong disc' message if the player cannot recognise the disc or the contents on it.
The disc formats/types that can be played should be outlined either on the unit itself or in the instruction manual (if you still have it). If the player shows that message even with genuine shop-bought DVDs then there is a defect within the unit, workshop attention may be required to fix it, but it could be costly.
'WRONG DISC' usually means the disc inserted is of a different region code to the player, or the wrong format (DVD-RW instead of DVD-R as exampled above). Try using different discs before going any further.
May 04, 2011 | Televison & Video
I can get the home page up on the tv where it says cyberhome. i put disc in and it says loading and then it says bad disc. what does a bad disc mean?
Assuming the player is fine, the 'Bad Disc' display message usually means either a disc which is an incompatible format (for example DVD-ROM) with this player; a disc which is a region that does not match that of the unit; or a defective/damaged disc. Check the discs prior to using them in this player and if they are burned discs, make sure they are a compatible standard format for playback.
This model is not region-free by default unless stated otherwise in the manual.
Apr 16, 2011 | Cyberhome CH-DVD 300 DVD Player
Message,"This disc is not formatted to play in this region".
DVD video discs may be encoded with a region code restricting the area of the world in which they can be played. Discs without region coding are called all region or region 0 discs.
The commercial DVD player specification requires that a player to be sold in a given place not play discs encoded for a different region (region 0 discs are not restricted). The purpose of this is to allow motion picture studios to control aspects of a release, including content, release date, and, especially, price, according to the region. Many DVD players are or can be modified to be region-free, allowing playback of all discs.Region 1 Players/DVDs include: Canada, United States, US Territories, and Bermuda. See below:
Region code Area 0 Informal term meaning "worldwide". Region 0 is not an official setting; discs that bear the region 0 symbol either have no flag set or have region 1–6 flags set. 1 Canada, United States; U.S. territories; Bermuda 2 Western and Central Europe; Western Asia; Egypt, Japan, South Africa, Swaziland; United Kingdom, Turkey, French overseas territories 3 Southeast Asia; South Korea; Taiwan; Hong Kong 4 Australia; Oceania; Central and South America; Caribbean; Mexico 5 Ukraine, Belarus, Russia, Africa, Central and South Asia, Mongolia, North Korea. 6 China, Hong Kong 7 Reserved for future use (found in use on protected screener copies of MPAA-related DVDs and "media copies" of pre-releases in Asia) 8 International venues such as aircraft, cruise ships, etc.[1] ALL Region ALL discs have all 8 flags set, allowing the disc to be played in any locale on any player.
Jan 12, 2009 | Yahoo Diamond Vision DVDC803-04 DVD Player
Not able to play region 2 dvds
With remote control and player stopped,
press setup, vol+, vol-, vol+, vol-
Use arrow keys to select region 1-6 or 255 for all region.
Numbers appear on TV screen.
Press setup again to save and exit
Try this to make it multiregion. It should work.
Oct 14, 2008 | Coby DVD-209
LG RC797T Region Unlocking Codes
Purchased two of these VCR/DVD recorders (for the ATSC-digital tuner) in March 2007 at Best Buy. They play PAL/region 0 out of the box. To enable region-free playback I used the CD-ROM previously made for my LG LST-3510A. Visit this link for the files to burn your disc:
http://aiwaownersnetwork.tripod.com/pages/lg/5000_series_firmware.html
Next:
--Power on the player and load the CD-ROM
--In a few moments a text box appears displaying current DVD region and a second line to change DVD region
--Press the number you wish (most likely "0") on the remote control
--Press "Enter" on the remote control
--In a few seconds the player will eject the disc. Remove the CD-ROM from the tray and power off
Upon powering on the player my region 2 and 4 DVD's play fine but Macrovision still remains.
OR
Click the HOME button on the remote with the unit in 480i resolution
Click the setup page
Click Start
Click TV Aspect
highlight the 16x9 wide aspect ratio
enter on remote control this coded sequence:
1397139
Edit specific "Options"
Option 2: 35 (enables Divx/Xvid playback)
Option 4: ff (enables Vcd and SVCD playback)
Option 5: ff (enables region free playback (region 0) DVD playback)
Option 6: ce (enables Insignia brand startup logo on boot)
Option 6: c0 (enables LG brand startup logo on boot)
Sep 19, 2008 | Denon DVD-3910 DVD Player
DVD player problem
You may have had a brief power outage you did not know about. Then the DVD player needs to be unplugged from the wall and started up again or your lens may need to be cleaned Because your dvd player is only made to play region 1 discs and vcd's are region 2. You need to buy a dvd player which will play all region discs or is rated region 0 which is the same. www.dvdenergy.com/index.htm
Aug 06, 2007 | Sylvania SRCD227 27 in. TV/DVD Combo
Problem with original dvd
Before performing any operations, make sure of the following: ? Check the connection with the TV. ? Turn on the TV and select the correct input on the TV to view the pictures or on-screen indications on the TV screen. ? For DVD playback, you can change the Setup menu setting to your preference menu... Alos, make sure thay the system and disc region code numbers are incompatible: The following discs cannot be played back: ? DVD-Audio, DVD-ROM, DVD-RAM, DVD-R, DVD-RW, CD-ROM, CD-I, (CD-I Ready), Photo CD, etc. Playing back these discs will generate noise and damage the speakers. * Note on Region Code DVD players and DVD Video discs have their own Region Code numbers. This system can play back DVD discs recorded with the color system of NTSC and PAL whose Region Code numbers include ?3.?
Dec 15, 2005 | JVC TH-A5 System
Zenith DVT216 System Logo
138 people viewed this question
Top Zenith Audio Players & Recorders Experts
Damen Wong
Damen Wong
Gagan Telecom
Gagan Telecom
Level 1 Expert
Steve Allison
Steve Allison
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
