I am trying to set up my Dynex N wireless router. I can not figure it out. The directions say that I should have colored wires that did not come with the router. I am so confused
  • 2 more comments
  • auntjojo1534 Jan 09, 2009
    I have the ethernet cable hooked to the router. Does it stay hooked to the modem also. What am I supposed to do with the blue wired I got with the router
    I used the installer that came with the router. I have to the ethernet cable connected to the router and modem now. I don't want a cable contacted to my lap top. What do I do now? If I take the cable off my computer I can't get internet.
    I'm using Window Vista
  • Randy Hough
    Randy Hough May 11, 2010
    Do you have the manual,or are you using the built is setup assistant?
  • 36 Answers
No worries. There should be a port labeled 'Modem' bordered in green'. Plug an ethernet cable (looks like an oversized phone plug) in to that port and run it to the DSL/Cable Modem. Power cord should be prtty straight forward it only fits one place. if you have hard wired computers, plug the network cable from the computer into one of the remaing 4 ports, bordered in blue.
If you still have problems, post a comment and I will get a copy & come back to help ya
Posted on Jan 09, 2009
  • 1 more comment
  • Andrew Podner Jan 09, 2009
    it can go from the wireless router to a desktop computer if that situation applies to you, or the ethernet port on your laptop if you wanted to go hardwired. But in reality, there is not a requirement to have a hard wire connected computer
    ok, that tells me that your laptop isn't linking up to the wireless router. XP, Vista????? what op system are u on?
    ok, good enough, unplug the ethernet cable, and then try opening the networking center and doing a 'diagnose this connection' on the wireless connection after first making sure that the laptop has recongnized and connected to the wireless network.
    if it hasn't then select connect to wireless network and select the apporpriate wireless netowrk id (strongest signal.)
    If after all of that it is still giving you fits, click start | run | in the run window type 'cmd' (no quotes) then type 'ipconfig -all' and paste the results into a comment here
I have a Dynex router model 10/100m router. I hooked up a netgear Prosafe Wireless Access Point model wg302. I have wireless internet connection but I am unable to "secure" the line. I have...
Any wireless security settings are going to be accessed from the netgear. When you chain one device to another, you need to know what the IP address the access point is assigned in order to log into its web interface. the wireless options will be missing if you just simply log into the Dynex web interface. To figure out the APs address, you may have to manually configure it to keep it simple.
May 17, 2011 | Dynex 4-Port Ethernet Broadband Router...
My computer is not connecting to my Dynex wireless router. I've called my locate cable subscriber and they told me that it's a router problem. I've disconnected the router several times and it shows that...
First off, verify that you can connect to your cable modem directly. After that, hook up your Dynex wireless router and reboot your cable modem. After this, directly connect your computer to the Dynex router (using a cable). If you cannot get an Internet connection, then there is some issue with your Dynex router configuration. It's possible that there might be an IP address conflict with the cable modem. It would be best to contact support for configuring the Dynex.
If you can connect to the Internet with your computer connected directly to the Dynex router, then there must be some router configuration problem affecting your ability to connect wirelessly. You'll have to check the configuration--might be a good idea to completely reset the router and start over. If that doesn't help, you should contact Dynex customer support, as each router has its own configuration specifics. Good luck.
Nov 07, 2010 | Computers & Internet
I'm trying to get a dynex DX-E402 to join my airport express
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jul 01, 2010 | Dynex DX-E402 Router
Router working as Access Point, unable to access via we browser
Please try first plug out the router and plug in again then press & hold the reset button till the power led become red and release. If that doesn't work, plug out the router, pressing and holding the reset button plug in the router.
Let me know the result please.
Thanks for joining Fixya.
Have a good day.
Feb 22, 2010 | Dynex Wireless-G Broadband Router
My dynex won't connect to my laptop
Try to change the channel first on your router. Access the router's admin page through and look for wireless tab and change the channel to 11. Save the settings. On your laptop, verify if your wireless settings is matching the router's wireless settings like the SSID and the security or encryption used.
Aug 02, 2009 | Dynex DX-E401 Router
Computer cabled to Dynex enhanced G wireless will not connect
Unplug the router for ten seconds and plug it back in, it needs to reset. Some routers have a reset button. I often wait longer than ten seconds, I find a beer is usually the right amount of time. Sometimes the modem needs a reset also; unplug everything, then plug back in sequence, with the modem first, the wait, then the router, wait, then turn on your computer. That system works for any brand modem and router.
Jun 09, 2009 | Dynex Enhanced-G Wireless Broadband Router
Dynex Wireless G Router
check the configuration of the router then re-configur the router it
Feb 26, 2009 | Dynex Wireless-G Broadband Router
I need help connecting my router. I am so confused.
Check with my tip.
Be sure you can browse internet using existing Modem connection (hispeed)
correctly follow instruction to connect router WAN port to modem.
Connect a PC to Router and follow instruction to config it
Jan 09, 2009 | Dynex Wireless-G Broadband Router
Siemens router & Dynex adapter
Double check if there is any wireless security enabled in your router. Verify if the type of security enabled in your router is already supported by your wireless adapter. If the wireless security enabled in your router is not supported by your adapter, change the security to something that will work with your adapter.
Try connecting your computer with dynex Wireless G USB to different wireless network for further isolation.
Oct 02, 2008 | Dynex Computers & Internet
Adding a wireless connection to an existing wired network
Go out to you local electronics store and purchase a wireless router , or Wireless Access Point (AP) , this way you will create a wireless connection by following the instructions given when you purchase the Wireless AP .
Basically when you buy the Wireless router or AP you just need to plug your existing Modem/Router into the WAN port on the Wireless Router / AP and then some initial setup to configure the wireless settings and then the appropriate settings inputted on your PC.
Heres a short guide i wrote to setting up a Wireless Connections
::Click Here::
Apr 28, 2008 | Dynex DX-E401 Router
Computers & Internet Logo
David Payne
David Payne
