Laptop with not boot up
I have tried everything. For some reason the recovery disk will not work and it won't boot up at all just a black screen. it won't let me boot in safe mode or use command lines
  • 47 Answers
It sounds like a hard drive issue.. my advice is to replace it .. i had the same problem with an older laptop and the hard drive was actually not even spinning.. so go to you manufacturer and order a a replacement or a new pc...
Posted on Jan 09, 2009
In recovery mode and lost power, then battery went dead. Now turn laptop on get the ASUS logo , in center, and Intel Logo, lower right corner, on black screen. Then black screen comes on again with...
Take disk out. Power down. Restart. See if will start up without a disk in it. Might be confused by your disk. Did you try to F8 or F9 while restarting to get into BIOS (trying to remember which one will boot you to BIOS). Then see if the CD/DVD was disable for boot up. Turn that back on if you can get into BOS so it will boot up you recovery disk.. If your OS is completely gone, you will have to reinstall...
Sep 24, 2013 | ASUS K Computers & Internet
System Restore Disk won't work
The Recovery disk could be damaged or corrupted. The reason you are getting the Ethernet controller error your laptop can not find an operating system on the drive. With the aspire try ALT-F10 when you power on the system it will take you to a system restore partition. This will only work if the Hard drive is working. And it will wipe your drive so if you did not have any backups well you will lose all data on the disk.
Apr 27, 2013 | Acer Aspire Computers & Internet
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
Got blue screen.. Trying to restart, but it is going in a loop on all different start up modes. What can i do?
If your computer came with a recovery disk, insert the disk into the optical drive and power the laptop down. On the initial boot screen, select BOOT Options by pressing, typically, F4, F8, F10, or F12 (Each computer is different).
Tell your computer to start up using the "CD/DVD", and run Windows Repair from the recovery disk.
If you do not have a recover disk, remove the battery and the power cord for a few minutes (Let all the power drain out of the motherboard, replace and restart.
As a last resort, you may have to reinstall Windows. If you install Windows 7, there is an option when selecting a drive to install on (You can't miss it) that will backup your files prior to the installation.
Apr 12, 2011 | Acer Aspire One PC Notebook
Toshiba satellite L300 black screen. Tried the 0 key and it only goes 1/3. thinking booing/registry corrupt. No recovery disk or software came with my laptop. O/S is Vista I have data and photos that...
Yes everything will be wiped out, once you do the recovery. It will reinstall the factory settings.
You may try this first; Turn OFF the laptop, remove the power sources (ac adapter and battery). Without power sources, hold power button 10 secs. Put back the power sources, then try to boot from safemode. Tap F8 upon booting up to enter the advance boot option. Select safe mode, save your files once loaded in safe mode. You may first try the system restore from , go to start/all programs/accessories/system tools/system restore, select the previous date the laptop was working fine. If this will not work then the last resolution is the recovery.
Hope this helps.
Mar 22, 2011 | Toshiba Satellite Pro L300 Notebook
My laptop says windows error recovery
The Windows Error Recovery message can appear for several reasons- an improper shutdown, new software, new hardware, etc. Since trying both options that you are given doesn't work, you need to troubleshoot the Windows startup error. If you have recently added new hardware, disconnecting or removing it could solve the problem for you as it might be creating some type of incompatibility.
Troubleshooting Windows Error Recovery: Last Known Good Configuration
You can attempt to boot up in Safe Mode and select Last Known Good Configuration and see if that works to resolve the Windows startup error. Turn the computer on and immediately begin to press the "F8″ key. If this does not work, you might need to press the "F2," "F10," or "F12″ key. Once you see the prompt screen, select "Last Known Good Configuration."
Troubleshooting Windows Error Recovery: Booting up from the Installation Disk
If that did not work, try booting up the laptop using the Windows installation disk - provided you still have it. If so, follow these steps:
1)   Turn the power button to your laptop on.
2)   Immediately insert the Windows installation disk that belongs to the laptop.
3)   When you see the option for "Check System," press the "ESC" key. Next, press the "F1″ key. Your laptop should now boot up.
4)   You can now use the "System Restore" feature to allow your laptop to return to a previous setting when it was functioning properly. This might mean selecting "R" for recovery.
Mar 11, 2011 | Acer Cell Phones
When i turn on my laptop all i get is a black screen that says error 2 and error3 ..i tried the restore option didnt work i tried the recovery disks that came with my laptop and it wont read it
You should see what is written on screen as reason for not going with the restoring ..It may have a hardware fault ..Usually the only things that may go wrong is the hard disk recognition ..or functionality ..
cause anything else will not even start it ..
So .. my advice is to go to bios first and check the hard disk and see if it is read proper..and all its properties appear on ...after that select hdd0 (the one it is working ) ..and under its settings ..select to disable the ahci function ..and let it run ide compatible ..or sata as ide..depending on the choices you have there..
after that changes..select F10 to save the changes..and restart and try to boot again and see if its functionality is back ..
If it is not ..try the restore partition again if it has one ..or the recovery disk ..If those do not work ..it may be cause you made changes on hardware level ..so try a boot-able disk with the operation system on it ..
make or borrow a disk .. insert it ..and restart ..and press F12 or f11 to go to boot menu ..and select to boot from cd /dvd drive ..and enter ..This will start boot from the disk ..and will ask to press a key (any ) to confirm the action ..and go on with the installing ..
same procedure for the recovery disk is required..
let me know if you have issues ...
It may be the case your hard disk is corrupted and you may need to change it if non of these are working ..but after trying ..let me know what you've done ..and how it behaved ....to see what is to be done before getting to hardware replacements ..
Dec 02, 2010 | Compaq Presario CQ50-215NR Notebook
I own a Toshibe Satellite L350D-215 running windows 7, when I power on the laptop it brings up the Toshiba welcome screen then loads a screen stating that there is or has been a problem and you have...
Sounds like you need to run the recovery disk
If your have the Recovery Disk put it in and boot from cd/dvd,
[Push "F12" at the Toshiba boot screen to access the Boot Menu]
you will loss all your info,,
to save your info [pic's] you will need to plug your hard drive into a desktop with sata.. and back up you info that way then run the disk
if you dont have the disk you will need to get a new windows 7 dvd or contact toshiba for a new Recovery Disk set,
Some times they put the Recovery on the hard drive but i think you need the disk with this one.
May 16, 2010 | Toshiba Satellite L305D-S5874 Laptop
I need a Acer Aspire 5315 -2142 recovery disk.
You might be able to boot from a Windows Vista DVD-ROM Disc and perform a System Restore back to a time when it was working and MAYBE it might work. I am not going to guarantee anything however.
Those discs will run you about 33.00
Aug 17, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
145 people viewed this question
David Payne
David Payne
