Question about Samsung PCN5425R 54" Rear Projection Television
Projection TV My screen is showing a double image highlighted in blue. I am also having problems with the focus option, it will always stop focusing at 37 percent of the way. Can you please help me with these issues? It would be greatly appreciated. Thanks againg! Mark
  • Anonymous Dec 12, 2008
    Blue focus won't sharpen up and remains blurred.
    President:
  • 1,284 Answers
You will need to repair the convergence circuit to fix the double image. The second issue of the "perfect focus" stopping at 37% will be fixed at the same time. It is halting because the sensors detect no movement of the blue image. here is a link to the part number and how to purchase the board. http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Posted on Jun 08, 2007
2 Suggested Answers
premtech
  • 934 Answers
SOURCE: Projection TV
Fame, The symptoms you're describing appear to be convergence failure and probably only one of the convergence amps. That unit uses two STK392-040 IC's and it is HIGHLY recommended that you replace both - not just the one. The convergence amps are mounted to a large aluminum heat sink with a heat sink compound for the greatest heat dissipation. My personal experience with this particular model has been that replacing the IC's only restored normal operation in 9 out of 10 sets as opposed to having to replace any other corresponding resistors or other components. In laymen's terms it's probably only the convergence IC's that need replacing. I strongly suggest that you not tackle this one by yourself unless your are fairly skilled at soldering. Too much heat on this multi-pin IC will destroy them and they're not cheap.. It's also a bit difficult getting the old ones out. If you don't do the job yourself find a good reapir shop and ask if they have the IC's in stock. If you're not sure where to find a reputable shop call NESDA, (National Electronic Service Dealers Assn.) They can refer you to a qualified member shop in your area... If you do tackle this yourself, order only the Sanyo originals from places like B&D Electronics, Vance Baldwin, ACME or Samsung. And use a fairly good heat-sink compound...
Posted on Jun 03, 2007
I recently bought a samsung hcn4226w at a yard sale for $50. Thought it was a good deal, but when i got home I saw the picture had a double image and the picture doesn't seem bright. After some tinkering...
This tv have convergence problems.Ur tv convergence board the 2 STK convergence ICS are defective,and some or all it resistor are dead.Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.Spend about $100 dollars more this tv can be save.
May 14, 2010 | Samsung HCN4226W 42" Rear Projection...
My rca projection tv has blue and green images like a 3D picture would without your 3D glasses, a double vision image and no other colors
sounds like the sensors are out of focus and your red sensor isnt turning on. look in the back of the tv for a master reset button or in your menu screen some sort of "Flash focus" or "convergence". They will realign the 3 sensors.
Dec 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
Images fading fast. Cannot read text on screen. Could hardly focus on images. Need to obtain part: Screen Focus Block
The lens is getting clogged. All u need if u have little expertise open up the TV.
and clear the lens or projection hd there with a soft clean cotton cloth
May 29, 2009 | Hitachi 51F59 51" HDTV Projection...
Double screen image
Double image shows that TV got problem of Convergence Out ICs failure and will be replaced two ICs mounted at D Board of TV.
ICs, STK392-360 are available in Part Store, click to see an image and price info.
Apr 27, 2009 | Sony KP-65WS500 65" Rear Projection...
Double image/ out of focus with green and blue seperation
Your tv is crt-based and is out of convergence. In other words, the settings for keeping the Red, Green and Blue images aligned have drifted and must be reset. This is common with CRT projectors and CRT rear projection tvs.
Refer to your owners manual for instructions on re-aligning it.
Apr 18, 2008 | Hitachi 51UWX20B 51" Rear Projection...
Out of focus
Rach, if it doesn`t move from green to red to blue in Magic Focus then there is a problem with the convergence IC`s and probably one or more support resisters. These components will have to be replaced, questions? ask away, BMW Rider
Dec 14, 2007 | Hitachi 57F500 57" Rear Projection...
Double image 6 yr old unit
Have you let set warm and then tried Magic Focus? Maybe after 15min.
Nov 25, 2007 | Hitachi 61UWX10B 61" Rear Projection...
Convergence images?
The blue picture tube of a projection tv is usually the weakest in ability to focus and in most cases loses its focus ablility before the red and green. Connect a cross-hatch generator to the rf inputs of the unit and check to see which areas are most out of convergence. The corners are usually the worst. HD will always bring out the slightest imperfections. If the unit was totally out of convergence, I would have suggested replacing the convergence IC'S.In my experience with rear projection, your problem is normal wear . You could conceivably improve the picture by adjusting the blue focus on the screen focus block. Scrivitron
Jun 15, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Projection TV
Jun 03, 2007 | Samsung PCN5425R 54" Rear Projection...
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
233 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
