Question about Brother IntelliFAX 770 Plain Paper Thermal Fax
Brother intellifax 770 No Power? LCD is blank
Hi, came in yesterday, walked over to send a fax. The LCD screen is blank. Unplugged it, went over to another outlet that I know has power, plugged it in, and nothing. Same thing. Tried another outlet in another room. Same thing.
Any ideas?
  • 1 more comment
  • julieannora Jan 14, 2009
    I have the same problem. After plugging in, I heard typical startup sounds and the paper feed pulled the page I wanted to fax through, so I am confident that power is successfully going to the machine. But my lcd screen is also blank. I called Brother and after 10 minutes on hold and 10 more minutes going through the live-automated, guided response protocol, the service assistant told me there was nothing to do but take the machine to an authorized service center. Grrr! Are fax machines for the blind this complicated?
  • cathii69 Feb 22, 2009
    Hello, I have the same problem. My 770 has absolutely no power. I have tried several electrical outlets, but it does not turn on. It worked fine about three months ago. Has been unpluged ever since. Sure don't want to trash it, as I loved that little machine... when working... please help!
  • julieannora May 11, 2010
    I considered the power surge possibility and rejected it. We do not keep the fax machine plugged in unless in use. It worked the last time we needed it and it has been unplugged since then.
I have the same problem: no LCD. Determined that the outlet was fine, but the machine did not respond when unplugging/plugging it in. Support said I needed to take it in for repair. Unplugged it, unscrewed the bottom plate, and found a blown fuse on the circuit board connected to the power cord (needed to gently lift it from its cradle).
Posted on Aug 25, 2009
  • 1 more comment
  • William Kizer Oct 29, 2012
    Bingo! Gentle does it, but there is the blown fuse! Big thanks to those who take the time to help others.
    This fax machine was minutes away from the garbage can. I bought a 120 volt 5 amp fuse at Ace Hardware, popped it in and put the case back together. Plugged it in and it worked as good as new. I paid a Brother serviceman $75 to do exactly this 5 years ago. I would not have done that again. Thanks to all who chipped in their help on this.
  • Jerry Mortellaro
    Jerry Mortellaro Dec 28, 2013
    You hit the nail on the head , many thanks, it was just the fuse and would never have found it without your help!!!!
  • 320 Answers
Posted on Jan 19, 2009
I have a brother 770 fax. When making copies or sending faxes the paper has long black narrow lines running from the top to bottom. Please help.
Hi There!
One reason why you're having a black line on the copies you make and faxes that you send it's because the scanner glass inside the fax machine is dirty. Here's what you can do to resolve you're issue.
-Make sure the printer is off and unplugged from the power outlet for your safety. -Open the control panel, Prepare a dry lint free cloth and isopropyl alcohol, dampen the cloth with a small amount of alcohol. -Inside the fax machine look for a the long scanner glass clean it with the dampened cloth, using hand try to feel if there are debris or dirt and concentrate on cleaning that part. -Directly above the glass you will see a white strip clean that also with the dampened cloth
Once you're done cleaning, close the cover and plug it back in. Try to copy a blank sheet of paper and if you can still see the same line clean it again for about 3-5 times, Make sure to make a copy everytime you clean the glass.
Hope this helps!
May 08, 2011 | Brother IntelliFAX 770 Plain Paper Thermal...
Brother Intellifax 770 - how to connect to PC?
The intellifax-770 deffinetly cannot connect to a PC. There are several other models that can, but not this one.
May 29, 2010 | Brother IntelliFAX 770 Plain Paper Thermal...
Need to print fax journal from yesterday. When I printed one this morning it is blank. Can you walk me through steps to change.
The reason your your fax journal maybe blan is caused by 3 possibilities, the first being a possible power failure, the second being the unit had been unplugged from it's power source and the third being that the unit has been reset to factory defaults.
Mar 26, 2010 | Brother IntelliFax-2820 Laser Fax
Have a Brother Intellifax 770. Machine went completely dead
Probably fried. Sounds like more of a power surge than a paper jam.
Apr 07, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
No dial tone when sending fax
Jan 06, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Set up
Try this links for download manual
Sep 17, 2007 | Brother IntelliFAX 770 Plain Paper Thermal...
Brother IntelliFAX 770 Plain Paper Thermal Fax Logo
1,141 people viewed this question
James Cagle
James Cagle
Jim Keysor
