Question about Panasonic Vacuums
Removing motor cover on Panasonic canister vacuum
How do I open / remove cover over cord reel and motor on Panasonic Vacuum model mc-v9647? (canister vac with not a single screw in sight!!) Brute force?
  • 7 Answers
SOURCE: pwr cord rewind reel
You have to pop the grey button off for the cord rewind. There is one more screw under there. You have to be very careful, because you can break one of the tabs that hold the button on. In fact, it is almost a garuntee. There are three tabs that stick off the button that hold it in place on the orange hood. There's a long tab about 3/4 inch long on the inside corner of the button you need to be careful of. Good luck!
Posted on Jan 09, 2008
SOURCE: Replacement filters for Durabrand Canister Vac with HEPA Model# DB9191
The model DB9191 is equivalent to the model CB9191 made by the Clean Bloom Electric Co out of China. So if one can track down the replacement HEPA filter for it ...
Posted on Sep 07, 2008
advacak
  • 125 Answers
SOURCE: what bags do I use for Royal canister vacuum #3004
uses a royal or dirt devil type R bag
Posted on Dec 08, 2008
  • 744 Answers
SOURCE: power cord reel problem with a kenmore canister vacuum whisperti
Pull the cord all the way out and see if it's contaminated with anything sticky. Also check the guide rollers that the cord rides in and see if they are rolling smoothly and without resistance - they may also need cleaning. If so, clean it off and try again.
If not, it may be the spring reel itself in which case you may need to replace it.
Posted on Apr 30, 2009
  • 10 Answers
SOURCE: cord rewind nonoperational
sounds like the spring is either over stretched or broken. you may have to have the spring replaced
Posted on May 11, 2009
Where are screws located that access main motor compartment in panasonic canister MC-V9647? Something is rattling inside and smells hot. Belt or motor?
If the model is the same as pictured, the screws should be visible.
If the model is older like I think it is, the screws are going to be a tad tough to get to, but not impossible.
First you will need to take the bag door off. Open it like you would to change the bag and then push the bag door back farther so that the hinges "pop" out. Generally how i do it is put it on the counter, with the bag facing you, open as far as you can, grab the top portion of the bag door and push it back quickly.
Now, when the bag door is off, with a flat screw driver, the colored housing above the gray bumper will come off. insert the flat screwdriver in there and pry it open a touch. do that to the other side as well. Once both sides are open, you want to slide the screwdriver towards the back of the unit and gently pry the back off.
under there you will find 2 screws (if you need to go that far at this point) and you can remove the back of the unit easily.
Good luck,
Mark
Nov 08, 2010 | Panasonic Kenmore Canister Vacuum Vacuum
Tip
How to Replace The Cord Reel in a Miele Canister Vacuum Cleaner
Ok, so you need to replace the cord reel on a Miele Canister Vacuum, no problem! I'll attempt to try and walk you through this repair with a detailed explanation of it, and along with some pictures to help you. You'll first want to buy a new Miele series cord reel for your particular model.
Here are links to all of the Miele cord reels if you haven't already purchased one.
Miele Cord Reels & Rewinds for All Brands
So once you have the cord reel, you'll need either a Phillips head screw driver for the older Miele models, or a T20 Torx Screwdriver for the newer models. The picture below is actually of the Miele S518 Cat & Dog series, but for this repair the procedure is identical to most Miele canisters . You'll need to remove the hose, wand, and power nozzle from the vacuum cleaner before you begin.
The first thing you'll wand to do is open up the bag housing, and remove the vacuum bag, as well as the exhaust filter which may be either the Cloth Super Air Clean Filter, or the HEPA Filter cartridge which is blue in color. If you're using the Super Air Clean filter, remove the filter, and then remove the bracket that secures the filter in place as well. Simply pull straight up on the bracket and it will come out.
Once the bag and the filter have been removed, you'll need to take off the entire tool lid. While the vacuum cleaner is open so that you can see into the compartment where the bag just was, you need to pry two arms from the tool lid off of the main body housing. Simply put a screwdriver behind one of the blue arms, and pry inwards. Here's a picture of what this looks like;
Once you have removed both of these clasps, the tool lid will pull straight upwards and off, leaving you with only the bottom part of the canister. This is how the vacuum cleaner should look now;
Now you'll need to remove the black speed control box from the canister. There is one screw in the front of the black speed control box that needs to be removed. After the screw has been removed, turn the vacuum cleaner around so that the back of the machine where the cord reel goes into the vacuum is now facing you. If you look where the black speed control box meets the bottom part of the canister, you can see two clips that you'll need to release before the variable speed control box can be removed. Simply put a screw driver and push in on the clip while lifting the black speed control box at the same time. Here's where the clips are located on the vacuum;
Ok, now that the speed control box has been removed, it's time to separate the colored plastic from the base of the vacuum cleaner. There are 7 screws that need to be removed in order to get these housings separated. I have circled the location of each screw in the picture below;
After removing all 7 screws, you can then simply pull upwards on the colored plastic housing, and remove the housing from the base of the vacuum cleaner so that the motor and cord reel are exposed. Once you have exposed the cord reel, you'll need to remove the internal wires (white wire is in the higher position, and to the left of the lower right side black wire), as well as the rubber hose part. The rubber hose part simply pulls off, just like the wire terminals do. After removing these parts, you'll need to remove one more screw with your screw driver. Here's the picture of which screw needs to be removed;
After the final screw has been removed, you'll have to remove the rectangular shaped wire harness that sits at the top of the cord reel. Pay close attention to how this wire harness is correctly seated which will save some aggravation when putting the vacuum back together. Here's a picture of the wire harness that needs to be removed from the old cord reel;
Once the wire harness has been completely removed from the old cord reel, you may simply pull up on the cord reel and remove it. The new cord reel will come completely assembled, with all the parts and components that your faulty cord reel had. You simply need to line up the screw hole on the new cord reel with the hole in the bottom of the base of the vacuum. When installing the new cord reel be very careful that you don't pinch any of the wires down by putting the cord reel on top of them. The wires have a specific place they go, and you'll be able to see the correct path for these wires when paying close attention. Also remember to install the rubber tube back onto the new cord reel as well. Once the new cord reel has been installed, and screwed down, pull the plug out a little ways, and guide the plug through the colored top housing first, then screw the 7 screws that hold the upper housing to the lower housing back into to secure these housings together.
That's about all there is to that repair! Please feel free to request a repair clarification if you have any questions about the repair that I can help you with, I'm always more then happy to help.
If this repair guide was helpful to you, please click the thumbs up icon in the bottom right part of this solution to rate it has helpful.
Thank you,
Chris J.
GoVacuum
on Apr 07, 2010 | Vacuums
Power cord caught in rewinder, Sears bagged canister. 10 yrs old Model is 116.3285590C I replied earlier but don't know if you received the information. Thanks Bryan
Hi There,
I'm sorry, I didn't get your comment on your previous repair. In order to get the cord reel out of the canister, here's what you'll need to do:
I have uploaded a parts diagram of your model below so that you can follow along:
Step 1. Open up the tool lid as if you were going to remove the dusting brush or crevice tool from the top of the vacuum. Once the lid for the tools is open, simply grab the two arms at the base of the lid, and pull forward towards the front of the vacuum where the bag connects. You'll need to remove the tool lid completely from the rest of the vacuum. You may have to lift slightly upwards while pulling forwards to remove the lid.
Step 2. After you've removed the tool lid, now open up the lower part of the tool lid that covers the vacuum bag (Part 29 in diagram above). While this cover is open all the way, grab the two arms on this part as well, and pull towards the front of the vacuum where the bag connects, and slightly upwards, just as you did to remove the tool lid. Remove the vacuum bag lid completely from the vacuum cleaner as well.
Step 3. There are two visible screws that are now visible (The screw listed as number 16 that's directly underneath of the number 36) on the front corners of the motor housing. Remove both of these screws that are in the front corners of the motor housing.
Step 4. There are actually two more screws that are hidden on this model, that are located underneath of the foot pedal that retracts the cord reel. You'll need to now remove the foot pedal from the vacuum cleaner (part 36 on the diagram). In order to do this, use a flat head screw driver to pry off the foot pedal. Insert the flat head screw driver in the front of the pedal where the pedal meets the motor housing. There are 4 tabs that hold this pedal in place. Usually if you put your flat head screw driver in the middle of the pedal where two of these tabs are right next to each other, the pedal will come off right away. Insert your flat head screw driver where I have circled red, these are the two tabs that you want to pry off. Simply push towards the rear of the vacuum while the flat head screwdriver is inserted in between the foot pedal and the motor housing:
Step 4. Now that you have the foot pedal off of the canister, simply remove the two now exposed hidden screws (oh yea watch out for that spring that's underneath of the pedal! remember to put this back when putting the pedal back), and lift straight up on the motor housing. You'll now have full access to the cord reel so that you may push the cord back through the hole in the rear of the vacuum cleaner.
Please feel free to send me a message to chris (dot) jones (the rest of the address is under my name in the signature) if you have any questions, or need some further help in accessing the cord reel. If your cord reel has gone bad, we do carry all the parts for your vacuum, and we'd be more then happy to provide any part that you may need. Here's a link to the bags for your vacuum on our site, just in case you need to purchase some:
Kenmore 5055 Canister Vacuum Cleaner Bags, 9 Pack.
I really hope that this helped you. If you have any further questions, I look forward to hearing from you. If this was helpful to you, please be so kind and return the favor by rating my repair solution helpful. You may do this by clicking the 4 thumbs up icons in the top right hand corner of the repair. This is really what keeps repair professionals like myself continue providing free repair services, and it's greatly appreciated.
Thanks again,
Chris Jones
GoVacuum.com
Apr 14, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
Hi There,
I have uploaded2_bing.gif a parts diagram of your model below so that you can follow along:
Step 1. Open up the tool lid as if you were going to remove the dusting brush or crevice tool from the top of the vacuum2_bing.gif. Once the lid for the tools is open, simply grab the two arms at the base of the lid, and pull forward towards the front of the vacuum where the bag connects. You'll need to remove the tool lid completely from the rest of the vacuum. You may have to lift slightly upwards while pulling forwards to remove the lid.
Step 2. After you've removed the tool lid, now open up the lower part of the tool lid that covers the vacuum bag (Part 29 in diagram above). While this cover is open all the way, grab the two arms on this part as well, and pull towards the front of the vacuum where the bag connects, and slightly upwards, just as you did to remove the tool lid. Remove the vacuum bag lid completely from the vacuum cleaner2_bing.gif as well.
Please feel free to use the Clarification Request form here on the repair page if you have any questions, or need some further help in accessing the cord reel. If your cord reel has gone bad, we do carry all the parts for your vacuum, and we'd be more then happy to provide any part that you may need. Here's a link to the bags for your vacuum on our site, just in case you need to purchase some:
Thanks again,
Chris Jones
GoVacuum.com
Apr 11, 2010 | Kenmore 23612 Progressive PowerMate Bagged...
My Miele solaris will not turn (it's plugged in and no power)
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(/wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello There,
Usually when a Miele canister just stops working all of a sudden, it's a lot of the time caused by the cord reel going bad. The internal cord reel has a metal spring that's used to get power from the cord, to the rest of the vacuum. Over time this spring starts to loosen, and eventually will get so loose that it will no longer transfer the electric current. This is the most common problem that I we see on Miele canisters. The good news is that this repair is fairly simple to diagnosis and repair.
In order to test and see if the cord is the problem, rewind the cord all the way back into the canister, and move the canister to the closest wall outlet. Now only pull out the cord far enough to plug it into the wall. With the vacuum plugged in, use one hand to slowly pull the cord reel out of the canister, and use the other hand to to continuously push the main on/off foot switch pedal on and off, on and off while you're pulling the cord out with your other hand. Does the vacuum motor make an sound like it's starting up, or does the motor come on at all while you're doing this? If it makes a noise like it's trying to start, this means that your cord reel is bad and needs to be replaced. If you don't hear anything while you're doing this, it still may be that the cord reel is bad, but it also may mean that either the switch or the motor could bad. In my 10 years of fixing Miele canisters however, I find that probably 70% of the time it's the cord reel that needs to be replaced.
If you need to purchase a cord reel to try and replace it to see if this fixes it (don't worry, we have an excellent return policy if it's not the problem) , here's a link to the exact cord reel for your Miele:
Miele Cord Reel For S500 Series Models
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(/wysiwyg_rte/misspell.gif) repeat-x scroll center bot So once you have the cord reel, you'll need either a Phillips head screw driver for the older S514 models, or a T20 Torx Screwdriver for the newer S514 model vacuums. You'll need to remove the hose, wand, and power nozzle from the vacuum cleaner before you begin.
The first thing you'll wand to do is open up the bag housing, and remove the vacuum bag, as well as the exhaust filter which may be either the Cloth Super Air Clean Filter, or the HEPA Filter catridge which is blue in color. If you're using the Super Air Clean filter, remove the filter, and then remove the bracket that secures the filter in place as well. Simply pull straight up on the bracket and it will come out.
After removing all 7 screws, you can then simply pull upwards on the colored plastic housing, and remove the housing from the base of the vacuum cleaner so that the motor and cord reel are exposed. Once you have exposed the cord reel, you'll need to remove the internal wires (white wire is in the higher posistion, and to the left of the lower right side black wire), as well as the rubber hose part. The rubber hose part simply pulls off, just like the wire terminals do. After removing these parts, you'll need to remove one more screw with your screw driver. Here's the picture of which screw needs to be removed;
Once the wire harness has been completely removed from the old cord reel, you may simply pull up on the cord reel and remove it. The new cord reel will come completely assembled, with all the parts and compontents that your faulty cord reel had. You simply need to line up the screw hole on the new cord reel with the hole in the bottom of the base of the vacuum. When installing the new cord reel be very careful that you don't pinch any of the wires down by putting the cord reel on top of them. The wires have a specific place they go, and you'll be able to see the correct path for these wires when paying close attention. Also remember to install the rubber tube back onto the new cord reel as well. Once the new cord reel has been installed, and screwed down, pull the plug out a little ways, and guide the plug through the colored top housing first, then screw the 7 screws that hold the upper housing to the lower housing back into to secure these housings together.
Thank you so much,
Chris Jones
GoVacuum
Apr 07, 2010 | Miele S514 Solaris Bagged Canister Vacuum
No power when plugged in
Greetings,
This definitely sound like a cord reel issue to me. This is really the only problem that I ever see on a Miele vacuum cleaner2_bing.gif. 9 times out of 10 the cord reel needs to be changed. If you purchase the cord from us, and it's not the problem you may return it up to 60 days later for a full refund, that's how confident I am that is what's wrong with your machine.
Ok, so you need to replace the cord reel on a Miele S514 Solaris, no problem! I'll attempt to try and walk you through this repair with a detailed explanation of it, and along with some pictures to help you. You'll first want to buy the new Miele S500 series cord reel
So once you have the cord reel, you'll need either a Phillips head screw driver for the older S514 models, or a T20 Torx Screwdriver for the newer S514 model vacuums. The picture below is actually of the Miele S518 Cat & Dog series, but for this repair the procedure and parts are identical to the S514. You'll need to remove the hose, wand, and power nozzle from the vacuum cleaner before you begin.
Chris Jones
GoVacuum.com
Jan 04, 2010 | Miele S514 Solaris Bagged Canister Vacuum
Kenmore whispertone 100 model 116. powerhead no
  • The motor / cord compartment cover must be removed to access the cord reel. There are four screws that hold the cover to the chassis. Two of the screws are found under the cord-retractor-foot-pedal on the top back of the canister. To access these screws the pedal must be removed. To do this, press the pedal down and look (from the top) for the four plastic clips that attach/hold the pedal hinges to the cover. There are two at the end corners and two in the middle. Using a long, thin flat-head screw driver (or similar instrument) press each clip to unhook/popout the hinges. Note: the foot pedal spring will also come out when the pedal is removed.
    The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw
Jul 18, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
How do I open my Kenmore Whispertone 12.0 to get to the cord reel
The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw. Good luck. - Gary
Mar 30, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Need to open motor compartment
Use a flat blade screwdriver, The dusy compartemnt door will come off by pushing it back, it just pops out. Then the rear top cover is held on by a tab, one in each corner. Put the flat blat in the slot at the bottom of the cover and work it until it pops loose. Then there are 2 screws to tak out to remove the cover over the motor and cord reel asm. But now you can get to the motor.
Jan 24, 2008 | Panasonic MC-V9620 Canister Vacuum
Vacuums Logo
77 people viewed this question
Top Panasonic Vacuums Experts
jasbo
jasbo
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
