Question about Bosch HMV9305 Microwave Oven
Do I need an install kit or a manual?
I found a HMV9305UC at an appliance outlet as an open-box special. It comes with no manual, or paperwork of any kind. I am also a little unclear as to how I'm supposed to mount/install this thing. Is there an install kit that I should buy, and am I asking for trouble if I buy this particular microwave?
  • 8,197 Answers
The mounting plate is screwed to the back of the unit. Also here is the installation instructions.
http://www.bshextranet.com/files/techtoolbox/HMV930x_engl_2008_Install.pdf
Here is the use and care manual
http://www.bshextranet.com/files/techtoolbox/HMV930x_engl_2008_C&U.pdf
Good Luck and Please Rate FixYa!
Posted on Jan 09, 2009
Do i need a special vent kit to vent microwave to outside
Yes, an adapter/kit should have come with the unit and then you would have to buy the piping etc.If you do not have the adapter/kit get it from the manufacturer or unit seller.
Sep 12, 2014 | Samsung 2.0 cu ft Over-the-Range Microwave...
Microwave doesn't start but the interior light goes on when you hit the start button
Hello
Remove the plug from the wall outlet and wait about 10 seconds before re-inserting it. The plug must be firmly inserted to transfer electricity to the appliance.
Open your home's circuit breaker box and reset the breaker if it has tripped and is set to the "Off" position. Simply slide the breaker over to the "On" position to fix a breaker that has tripped.
Plug a different appliance into the same outlet to make sure the outlet you are using is functional. Plug the microwave into a different outlet to see if this yields different results.
Press on the microwave door to ensure it is completely closed. The microwave will not function until the door is fully shut.
Press the "Start" pad on the display panel after setting the time. Failing to press this will result in the microwave not knowing that it should start.
Press the "Stop/Reset" pad on the panel if a program different from the program you want to run has already been entered into the system.
Press the "Clock" pad three times to turn off the demo mode. The demo mode will not allow the appliance to turn on and cook as it should.
Oct 04, 2011 | Microwave Ovens
The light inside goes on but the microwave doesn't
The trip breaker in my home for the electrical outlet keep tripping off what do i do. the breaker in my electircal box for my electrical socket keep tripping off
go to the qualified electricians on your place... but there is some helpful tips that can help you.. (1) for continued protection before starting. turn off the main circuit breaker. (2) unplug all the appliances or equipment installed... (3) check all the wall socket outlet... look for any damages on the wall socket... if the wall socket outlet have no signs of burned or wet marked, try to turn on the circuit breaker. check if the problem is solved.. (4) if the wall socket outlet have a signs of burned or wet marked.. just replace that w/ the same type of socket... check also the appliances that may caused the problem... the easiest way to know is to look at the socket plug itself... ty
Jun 21, 2011 | Microwave Ovens
Microwave works but doesn't heat food.
check if it heats through a different outlet by its self if not element is shot but if it works you need a better electrician unfortunately because you might have a new fire hazard with incorrect wiring but thats really only way to find out
May 07, 2017 | Amana MVH210W Microwave Oven
How to install a electric line for over stove micowave
This is usually best left to a licensed electrician, however in some homes there is already electrical wiring over the stove for an exhaust fan. You might be able to tap into the exhaust fan wiring and install an outlet that you can plug the microwave into, or if there is an electrical outlet near the stove area you might can tap into it just be sure that you are not overloading the outlet. For example if there is a refrigerator or other major appliance using power from this outlet it might not carry enough current to operate the refrigerator and the microwave at the same time and will cause the circuit breaker to open or fuses to blow.
Sep 09, 2009 | Kenmore Microwave Ovens
Jennair JMV8208BCS No instructions in box
Hello. the installation of wall mounting bracket is not too difficult. you will need a drill, some bits, and a scrrewdriver. you will also need an electrical outlet at that spot to plug in the microwave.
Jennair makes a bracket kit for each microwave. Call any jennair dealer, have your model # handy and they will get you the bracket you need, also ask specifically for the instructions.
Aug 12, 2009 | Jenn-Air JMV8208A Microwave Oven
Problem with electrical source
Does your manuel also tell you to use a DEDICATED 20amp circuit to plug your Microwave in to? More that likely you used a 15 amp circuit that other appliances were also plugged into. A refrigerator or other cooling item needs its own 15 amp circuit but can tolerate small amp draw items like a clock. The new, higher wattage microwaves need a 20 amp circuit for itself. Have your line checked , have your microwave fixed. Start new
Aug 26, 2008 | Microwave Ovens
Microwave dead
First, there is an outlet. Plug in something else. Inside the key panel, there are fuses and a thermo sensor. Either may be bad. The thermosensor is about the diameter of a dime, black and 3/8 inch thick...attached to the wall of the chamber. All should have continuity.
Dec 20, 2007 | Whirlpool GH7155XHS Microwave Oven
Broken Microwaive Door
I'm assuming your correct model number is KCMS145JSS? You have a broken "release lever", part number AP3033332. It's reference number 7 on the exploded view diagram found here: http://www.appliancepartspros.com/sect/4/g/4/4g4rya32jj.gif You can order it by part number from Appliance Parts Pros here: http://tinyurl.com/gv383 If needed, you can download the owner's manual and installation guide here: http://www.kitchenaid.com/custserv/literature_search_results.jsp?searchTerm=kcms145jss If you need further help, please follow up. I appreciate your rating of this answer.
Nov 17, 2006 | KitchenAid KCMS145J Microwave Oven
Bosch HMV9305 Microwave Oven Logo
1,047 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
