Question about Jenn-Air Ovens
Control panel error
The control panel does not work and then "F0" appears in the screen.
What do I need to do/buy?
thanks
    Scholar:
  • 31 Answers
On most Jenn Airs, this means a key on the keypad is stuck. Try shutting off power, inspecting the keys to see if one looks stuck in or feels worn out. Rapidly press each key several times to loosen and clean the contacts. Turn the power back on and see if the problem goes away.
If this fails to help, you will probably need a new keypad for the unit. I don't know what model Jenn Air you have, but you can find parts for most Jenn Air models at Appliance Parts Pros. This is probably an easy fix, but if you are not comfortable or do not know how to safely work on appliances, you may want to call in a qualified tech.
Posted on Jan 09, 2009
Error code F0 0 042 the 042 is to the right and slightly above the f0 0 I have replaced both the control board and the touch panel and the error came up the same. changes to F1
These errors generally mean the control board has failed in one or more ways. F1 is by far the most prevalent. When this happens you need to replace the control board. You may be able to buy a new board or have us (www.fixyourboard.com) repair it (particularly useful if the board has been discontinued by the manufacturer). We have many DIYers who remove their control board and send it in for repair.
On some models it is possible that F1 could also be caused by a keypad problem. In this case it will specify in the tech sheet to power down the oven, disconnect the keypad then power the oven back on, wait for a few minutes to see if the error reappears. If the error reappears it is definitely the control board. If not, it is probably the keypad but be aware that F1 usually starts out as being an intermittent fault, then gets more prevalent with time.
May 18, 2015 | Ovens
FO ERROR ON OVEN
Seems F0 is a problem either with the control panel or with the key panel
Here is a test to find out whether its your control panel or control board:
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
You can go to this site to find replacements
Mar 14, 2008 | GE Profile JKP56 Electric Double Oven
Double wall oven F0 error code
The F0 error code means that the control board has detected a defect within the control board itself, the F0 code can be cleared by pushing the CANCEL/OFF button and if it goes away and returns all is well,however if a short time later the F0 returns the control board would need to be replaced.
GENE
Oct 04, 2011 | GE Profile 30" Built-In Double Electric...
Double oven panel seems to have gone nuts! FO appeared on both ovens. When placed on bake they go to "ON" for serve warm or one goes to convection.
Hi
F0 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Kenmore Ovens
I am getting an F0 error code on my GE JTP15. It was working and then just shut-off. Then the error code appeared. I removed power for 30 minutes but the oven control did not reset.
F0
Stuck touch pad Usually means that either the touch pad or the oven control
(also called clock or ERC) is defective and needs to be replaced. If this fault
code cannot be cancelled, replace the oven control (also called clock or ERC),
touch pad, or both.
Jan 30, 2011 | GE JTP15 Electric Single Oven
Error code f0
Hi
Thanks for using FixYa. Error F0 means a stuck/faulty touch pad. You’ll need to check the touch pad and if faulty replace it. However, usually the Electronic Range Control (ERC) is also replaced if this error cannot be cancelled. You’ll need to check and replace the oven control (also called clock or ERC), touch pad, or both. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 11, 2010 | GE Profile JTP56 Electric Double Oven
Error Codes F0 and F7 on G.E. Wall Oven
F0 , F1 , F7 - Stuck keypad may mean relay is turned on.
You could have a Tech Sheet from :-
http://www.repairclinic.com/0078.asp
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 02, 2010 | GE Ovens
GE Profile Performance Spectra Range error code F0
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
Jun 20, 2009 | GE JKS05 Electric Single Oven
The oven controls are not working. then FO shows
If your appliance is newer than 1996 F0 error code is a stuck key pad .
To verify turn off power and access the control panel and remove the ribbon connector that goes from key pad to control board .
Now restore power.
If the F0 code goes away you'll have to replace the key pad .
If it stays it means the control board is bad.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 11, 2009 | GE 30" Built-In Single Electric Convection...
F0 error code on GE Profile PT956 double electric oven
you can also put a piece of paper between the ribbon cable where it joins up before the connector. It has been reported that the cable will short in this area. Try that before spending more money since most of the F-codes appear to be cable related.
Dec 01, 2008 | GE Profile PT956 Electric Double Oven
Ovens Logo
226 people viewed this question
Top Jenn-Air Ovens Experts
Mike Cairns
Mike Cairns
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
