Question about Miele 24 in. Incognito G843SCVi Built-In Dishwasher
Machine off completely
Salt light was on & rinse aid light on, tried to hit all the buttons and it shut off completely
Any suggestions?
  • 128 Answers
Hopefully a button is jammed in between positions - the lights are just indicating that you need to add salt to the reservoir and that your rinse aid is getting low.
Posted on Jan 09, 2009
AEG 50879
This option can be selected by pressing the corresponding button, and remains in memory until the same
button is pressed again. This option modifies the phases of the programme in order to optimize performance
when "3 in 1, 5 in 1, 7 in 1, ......." detergent tablets are used:
- variation of the duration of the programme and the temperatures required to dissolve the detergent tablets.
- reduction of water exchange
- exclusion of introduction of rinse-aid
- exclusion of regeneration
If you use a dishwasher in the traditional manner (detergent, rinse aid, salt) then the Multitab function is disabled. If you use tabs that are already on the market with rinse aid and salt there is a possibility during washing cycle to add a double dose of rinse aid. From rinse aid dispenser and rinse aid from tabs. This will lead to poor cleaning results, glasses will look like they have been washed in milk..To avoid that you must turn on "Multitab" function and thus exclusion of introduction of rinse-aid from rinse aid dispenser. This function also stops the regeneration and will not spend salt because salt is already in a tabs. Also extends the washing time because tablets need more time to dissolve in relation to the traditional powder detergent.
Dado
Jul 15, 2014 | AEG Dishwashers
Dishwasher salt beko
Rinse aid and salt are not necessary if you use powder that is similar to the tablets. The lights are warning you that you havent added them, you know that so ignore the lights. If you live in a hard-water (limescale) area salt can be used as well as tablets or powder to make the water kinder to the machine, but most people just use tablets without rinse-aid or salt.
Dec 14, 2013 | Dishwashers
What do these mean on a zanussi dishwasher model DE 6854
The top light is apparently to indicate that the salt (!) has run out.
The bottom light is apparently to indicate that rinse aid has run out.
For the record, that seems to be a Zanussi DE-6854 dishwasher, and I found the manual here: (link)
"Special salt can be added in one of two ways: 1) If you are using dishwasher detergent that already contains salt, the detergent including the salt is placed in the detergent compartment. - In this case the water softener must manually be set to 1 and electronically to 1 to ensure that the special salt is taken from the detergent container only. 2) If you are using dishwasher detergent and salt separately, the special salt is to be put into the salt container. - In this case the water softener must manually be set to 1 or 2 and electronically between 1 and 5 (depending on the water hardness in your area) to ensure that the special salt is taken from the salt container only. Only use salt specifically designed for use in dishwashers. All other types of salt not specifically designed for use in a dishwasher, especially table salt, will damage the water softener. Only fill with salt just before starting one of the washing programmes. This will prevent any grains of salt or salty water, which may have been spilt, remaining on the bottom of the machine for any period of time, which may cause corrosion." (Page 6)
"Only use branded rinse aid for dishwashers. Never fill the rinse aid dispenser with any other substances (e.g. dishwasher cleaning agent, liquid detergent). This would damage the appliance." (Page 7)
The manual also explains how to turn the Rinse Aid light off permanently if you do not wish to use rinse aid.
Mar 23, 2013 | Dishwashers
What do these lights mean there not going off
The "Rinse Aid" red light
The rinse aid light is just an indicator to let you know the rinse aid is low. You fill it in the container next to where you put the detergent. Just push the yellow button and the lid will pop up. rinse aid is more important on the newer miele dishwashers, as they dont have "active drying" like the older dishwashers did. They depend on the rinse aid to sheet the water off the dishes at the end of the cycle. They are designed this way to reduce energy consumption. If you choose not to use rinse aid, and you dont mind wet dishes at the end of the cycle, either disregard the red light, or fill the rinse aid dispenser with water to trick the machine into thinking it is full.
If you are not going to use the onboard water softener, you can turn it off. Refer to your owners manual, or call miele tech support at 800 843 7231 and they can walk you through the programming to disable the water softener. these are not fault lights, they are simply reminders that you need to fill the containers.
Jul 20, 2011 | Miele Dishwashers
If i use combination tablets in dishwasher do i need salt & rinse aid, thank you.
The combination tablets are very convenient and do work well but you will still need to use salt and rinse aid for the best results. The reason for this is that every dishwasher has a specific time or times that it needs that chemical (rinse aid or salt) to be released. The tablets will release it but maybe not at the best times.
Aug 01, 2010 | Bosch WFMC 3200 Front Load Washer
Where do I put salt into a G665 model
Salt and rinse aid are low if the indicator light is on.
Salt is placed in a compartment in the bottom of the inside of the dishwasher. It has a round approx 10cm diameter screw cap.
Rinse aid goes in under a flap in the inside of the door near the powder dispenser
Dec 02, 2009 | Miele 24 in. G665 Built-in Dishwasher
Blooming on everything in the machine changed from powder too liquid no mchange tried light soil,rinse half load no change.rinse aid is full salt is ok
solved the problem by rechecking all the pipes in/out,filter,rinse aid dispenser and salt cellar. Hey ho the salt cellar was empty!!!! obviously had an elderly moment, thanks for checking back, dont laugh it comes to us all eventually Gary
Aug 18, 2009 | Zanussi Dishwashers
MY G892SCUPLUS MIELO DISHWASHER LIGHTS AND CYCLES ARE STUCK.
The rinse aid light means you are out of rinse aid. The salt light means you have to add salt to your built in water softener. If the drain/intake light is on, that is when you have a problem. It will flash when there is a problem. You have to count the flashes and that will tell you what the error is.
Sgt 48
Jun 01, 2008 | Miele 24 in. G892SCU Plus Built-in...
Dishwasher not cleaning
The dishwasher salt response is acceptable for Europeans, but U.S. dishwashers do not have a salt dispenser, nor is dishwasher salt sold in U.S. stores. U.S. consumers should descale their dishwasher using Dishwasher Magic, Lemi-Clean, Lime-A-Way, CLR, or vinegar until scale is removed from the machine, then add a rinse aid to the dispenser, which should prevent future problems. For very hard water, regular, periodic descaling treatments should be done. For the vinegar cleaning, place a full cup (8 oz) of vinegar in the top rack of the dishwasher. This way the vinegar is release throughout the wash cycles, performing a more thorough cleaning.
Sep 13, 2007 | Dishwashers
Miele 24 in. Incognito G843SCVi Built-In Dishwasher Logo
411 people viewed this question
Top Miele Dishwashers Experts
mpservices
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
