Question about Whirlpool GEW9200L Electric Dryer
Dryer will not start
All lights on, press start, minutes just blink and dryer does not lock or start
  • juddfamily6 Jan 09, 2009
    Wrong model# is showing -- GEW9250PW0 --
    We have tried to reset by turning breaker on & off. Everything fuse wise seems ok. Cycle lights come on, but when i press start, it beeps once and minutes just flash.
  • 10,515 Answers
Refer to the link fr diagnosics :)
http://www.repairclinic.com/0088_8_1.asp#Level1_1
Thnks.
Posted on Jan 09, 2009
  • 2,071 Answers
  • Whirlpool Master
  • 19,396 Answers
Try first unplugging the power cord for ten minutes , or tripping the circuit breaker to reset the panel.
While power is unplugged try opening and closing the door, if it does not work try helping the latch gently with a scredriver, taking care not to damage the part.
If it still does not start and lock, then the problem is a stuck or faulty door latch that must be replaced.
Here is the door catch USE WPL 279570 (Door Catch Kit)
Click here to find assembly diagram and replacement parts for your appliance.
  • 142 Answers
Not too familier with dryers, but try looking in the troubleshooting manual, make sure everything is plugged in and assembled correctly. Worst case scenario contact manufacturer or store where you purchased product.
    Sergeant:
    Champion:
  • 334 Answers
Check the door switch. Also check the breaker turn it off and turn it back on because half of the breaker could be bad.
  • Greg Wilkins
    Greg Wilkins Jan 09, 2009
    Just look this manual over and see what you find because they don't give any information on anything
    http://owneriq.net/mdownloads/14de77a2-5...
Entrance light on Lift Master garage door opener won't stay on when door is opened ?
Light Feature
Activate the Light Feature
  1. Close the garage door.
  2. Start with the garage door opener lights "ON".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn off and come on 10 seconds later.)
Deactivate the Light Feature
  2. Start with the garage door opener lights "OFF".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn on and go off 10 seconds later.)
Light Timer
Press the Light button to turn the opener light on or off. It will not control the opener lights when the door is in motion. If you turn it on and then activate the opener, the light will remain on for 4-1/2 minutes. Press again to turn it off sooner. The 4-1/2 minute interval can be changed to 1-1/2, 2-1/2, or 3-1/2 minutes as follows:
  1. Press and hold the Lock button until the light blinks (about 10 seconds).
  2. A single blink indicates that the timer is reset to 1-1/2 minutes.
  3. Repeat the procedure and the light will blink twice, resetting the timer to 2-1/2 minutes.
  4. Repeat again for a 3-1/2 minute interval, etc., up to a maximum of four blinks and 4-1/2 minutes.
Oct 20, 2017 | Building Materials
Frigidaire Dryer model # LEQ1442ES0. The lights come on and beep at us like normal when I change settings but when I press start, they just blink and beep but wont turn on.
Thank you for your post, friend!
From my understanding your Frigidaire dryer is not starting and the lights just blink. It sounds like a faulty door switch or control panel. I would check to make sure the latch or door strike is not cracked or broken if the door is not closing properly that could be the cause of your dryer not starting.
You could also perform a reset on your dryer and that could help clear any faulty error codes within your dryer. To reset your dryer you would unplug the power cord for ten minutes. I hope this has been beneficial. -Matt
Oct 17, 2014 | Frigidaire Dryers
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not start. I also see that when you press the start button, the lights above the Control button blink and your dryer beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try running any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire FEQ1442ES Electric Dryer
Dryer will not start: when I hit the start button, dryer beeps and lights blink above Control button
-Best Regards-
WP
Affinity Dryer has all LED lights blink and then it stops running
Hello everclavel - Try reprogramming the dryer by flipping the household circuit breaker off or unplugging it. Wait approximately ten minutes and restart unit. If it proves to be ineffective, the dryer could possibly be experiencing a communication error with the main control board, wiring failure, or faulty door lock assembly. Connect with a certified technician to move forward accurately to assist with the repairs.
Jan 29, 2013 | Frigidaire Electric Dryer
Frigidaire dryer faqe7001lw blinking lights
Try resetting the computer like a cars e.c.m. by turning the dryer on and plugging it from the outlet. It worked for me once w our new Malta front loaders
Apr 07, 2012 | Frigidaire FAQE7001LW Dryer
Check filter light remains power light blinking
Hi friend,,,
welcome to fixya
try to unplug it for 30 minutes this should reset the control board. and clear any errors it has. and may start working again. let me know how it goes OR
try this to get it in diagnostic test mode have the dryer in standby mode then press and hold more time and less time and then press the power button to get out of this mode you will have to unplug the unit for at least 1 minute
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Dryers
When i press start the dryer just beeps and the time light blinks.
thanks, after reading similar problems and solutions, we unplugged the dryer for 5 minutes. according to the solutions i read, this resets the system, and it did!
happy and dry and canada!
Dec 31, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer won't start; all lights on; minutes just blink
well you may have a couple things wrong with your unit first check the door switch to see if its making contact telling the unit it's closed, if it doesn't read a closed circuit when pressed replace the switch if it does replace the main control board. If you are getting any fault codes you can remove the lower panel on the dryer ( 3 screws at the bottom ) and check the tech manual on what it is ( if someone did not take it ) hope this helps good luck.
Jan 09, 2009 | Whirlpool GEW9250 Electric Dryer
Equator EZ 2512 CEE Front Load dryer not starting
The blinks are the fault code on the unit you will have to watch them an count match them to the chart in the service manual
Here is a link to the service manual
http://www.appliancedesk.com/appliancedesk/service/CWD/EZ3612CEE_EZ2512CEE_EZ1612V/Service_Manual.pdf
Feb 20, 2008 | Equator EZ 2512 CEE Front Load Washer /...
Whirlpool GEW9200L Electric Dryer Logo
27 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
