Question about Kenmore Washing Machines
My washer wont drain
My washer fills with water and washes but when it comes time to drain it just puts the water back in the washer.
  • 2 more comments
  • lcantu20 Jan 09, 2009
    what i a catalsyt? My washer is a top loader. Super Capacity. It fills with water. Washes. Then when it tries to drain, the water comes out of the spot where it originally filled from. It is just recycling itself
  • lcantu20 Jan 11, 2009
    Thank you very much for the reply. My husband is going to check it in the morning and I will let you know if that works. I appreciate your input
  • lcantu20 Jan 13, 2009
    That was the problem. We ordered the part from Sears and are awaiting its arrival. Mahalo Nui....Loretta
  • Dean Rhymer
    Dean Rhymer May 11, 2010
    what kind of washer is it a catalsyt?
    New Friend:
  • 88 Answers
It sounds like you need a 2 way valve , its a valve thats suppose to recycle the water during the wash and then open so that the water can drain. it's at the bottom of the washer right by the drain hose.
Posted on Jan 11, 2009
My Whirlpool Duet ht Washer starts washing fine, it drains then it starts flashing FH and wont take in water for the rinse cycle. It does this for every cycle, it will wash fine but after it drains and is...
The first thing I would check is shut off the cold water valve at the wall and remove the hose at the washer.carefully pry out the little screen in the inlet and clean well,reconnect hose and turn water back on FH is a water inlet issue I am hoping that what is happening is that when the washer starts its wash cycle it is probably filling with warm (hot) and cold water at the same time even though it might be mostly hot,but when it comes time to rinse (cold water ) there is not enough to make the computer happy and you get your FH error.. Hope this Helps,,If not your probley looking at a new fill valve assy
Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer stuck on wash n wont spin not filling up with water
If water is coming into your machine but not filling up then you have a siponing problem (draining and filling at the same time). Raise the drain hose up higher at the drain at the back of your machine.
Jul 09, 2010 | GE WBSR3140DW Top Load Washer
Washing machine keeps filling and draining at the same time and wont fill enough to move on to the next cycle
The drain hose is too low and the water just runs right out...The highest point of the drain hose needs to be higher then the top of the washer before it goes back down into the drain. Also if the hose is sticking into water it can create a siphon which pulls the water out of the washer... make sure that you also have an air gap...
Heatman101
Mar 10, 2010 | Frigidaire FGX831C Top Load Stacked Washer...
I have a GE washer that won't drain!
The pump is clogged. Remove the tub to pump hose and you will find debris in it not letting the pump work. Do this and you will be good to go. Thanks, Rick
Mar 04, 2010 | Washing Machines
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Jan 31, 2010 | Whirlpool Inglis IP4400 Washer
LSR8233JQ0Washer won't fill
The water is syphoning out the drain hose.
Many times when the stand pipe is backing up someone will seal the washer drain hose to the pipe to avoid overflow of the stand pipe.
This causes the water to syphon from the washer.
Or the opening for the stand pipe is just big enough to put the drain hose in and is to tight causing the syphon.
Putting the drain hose to far down the pipe can cause a syphon also.
Jan 20, 2010 | Washing Machines
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Whirlpool ultimate care 2 water wont stop filling...over flowing everywhere.
Your level switch hose has come loose.first open the display panel to check in back of water level switch,and look for a hose that is not attached to the back of it.
Jun 07, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
55 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
