The ink of my epson L200 is running out, how can the code of the ink to be input?
To pour the ink, follow instructions in http://goo.gl/rX6uY0 .
Then, if any code window doesn't open up, then download wicreset.exe from Free Epson Ink Reset ID Codes for L100 L200 L800 printers or watch video from Epson L100 L110 L200 L210 L300 L350 L351 L355 L550 L800 printers Ink...
Hope this helps... e-mail me at [email protected] if you have any doubts or if you want to thank me...Lol!
SOURCE: epson stylus photo rx580
Hi-
You are having a hardware problem with the printer, the sensor is damaged. call epson @ 5622761300 for replacement ink and printer.
Hope this helps
SOURCE: Epson CX8400 ink cartridges run out early
Epson gives you a miserable 12 ml of ink. Then it reports empty when there is still 10-15% of the ink left. I saw someone set up a brand new CX8400, print a single 4x6 photo and it said he was out of cyan. I use reusable cartridges from http://www.ccs-digital.com They hold 20 ml, which is 2/3 more ink. The chips automatically reset to full if you take the cartridge out and put it back in, so you get to use every drop. The ink is in a separate container inside the main cartridge. When it's really empty, you pop out the ink tank and pop in a new one. The tanks are under $3 each. I think this is brilliant because it's like refilling only it avoids the risks and mess of refills.
SOURCE: Epson Tx100 does not recognize my ink!
there is a chip re-setter located just above the cartridges. it is actually a small button switch. if that does not work, try to remove the cartridges. just lift them (1 by 1) slightly then put it back again
