Question about Cameras
Canon MV700i When switched to Camera there are just black and white shadowy movements in the viewfinder. (It replays recorded tapes as normal)
  • 2 more comments
  • wg_bell Jan 09, 2009
    When I record all I get is black with some movements or shadows on the image on the tape. The sound is recorded.
    Another comment: The images on the tape are just flickery cloud-like responses to light and movement. They are not blurry pictures of what the camera is supposed to be recording. Does this seem consistent with your explanation?
    The camera is a couple of years old but has not had a lot of use. ie it may have recorded about 4 mini DV tapes.
    Thanks.
    Comment posted on Jan 09, 2009
    Thanks for the assistance.
  • Cameras Master
  • 19,396 Answers
White shadowy images in the viewfinder means that the camcorder has a defective LCD screen.
The camera must be taken apart to replace the screen, to fix the problem you may need to send the camera for repairs.
Posted on Jan 09, 2009
  • 4 more comments
  • Ginko
    Ginko Jan 09, 2009
    Hold on, it replays fine, what about taking pictures.
    If it replays fine it is not the LCD.
    If it does not take pictures or movies, but you get only blurred images on tape or memory card , then it is a defective CCD sensor (blurry shadow like images, in pink or grey tones)
  • Ginko
    Ginko Jan 09, 2009
    The array CCD sensor is the optic sensor that capture light to generate the image.
    This part is even more difficult to replace, the camera must be sent for repairs.
  • Ginko
    Ginko Jan 09, 2009
    If the problem happens only when you switch to camera, then it is the camera CCD sensor, that is separate from camcorder one, the repair is expensive, and if you use unit mainly as a camcorder it may be not worth.
  • Ginko
    Ginko Jan 09, 2009
    " that is a defective camera ccd sensor, I have seen it many time the sensor for the camcorder is separate and it is working.
    Look:
    That is how it looks like, may be pink, gray, on black and white stains, more or less blurry, depending on how the array sensor is faulty.
    If the pictures that you take come out the same , that is a faulty CCD sensor.
  • Ginko
    Ginko Jan 09, 2009
    The viefinder shows you what is detected by the CCD sensor, and passed to the logical board.
    When the logical board is faulty it usually does not start, a problem of this kind is unfrequent.
    If the picture comes out the same as the image only on camera , then it is a faulty sensor.
    If instead you have static dark spots like blurred area, that do not follow the pictures while camera is moving that is a lens problem.
    From description it looks like a bad CCD.
    In either case the camera must be taken apart to replace the sensor, or reassemble lens.
  • Ginko
    Ginko Jan 09, 2009
    You are welcome.
When I flip open the LCD or look through the viewfinder and turn on the camera and take lenscap off all I see is black with shadowy white vertical lines.
Sounds like your iris is shut. Try giving the camera a good smack with the palm of your hand near the lens. That should free up the iris. Can you view previously recorded tapes??? If so your video board might be bad. Hope this helps.
May 27, 2011 | Samsung Compact MiniDV Digital Camcorder
Bars across picture when replaying tapes.
The tapes were recorded in LP mode and the replay is set to SP mode. Switch from "EASY" to "P" and replay and you should be OK
Apr 27, 2009 | Canon MV800i Mini DV Digital Camcorder
Canon MV700i - blank screen and viewfinder
There is a well known, but little publicised problem with CCDs on many cameras. Ther was a manufacturing problem in the components. Visit the Canon web site and look up the problem. They will tell you where to send it for free repair
Mar 24, 2009 | Canon MV700i Mini DV Digital Camcorder
Vertical lines
If the lines appear on the tape this way when it is recorded, then the CCD unit is going out on the camcorder. If it isn't recording the lines then the viewfinder wiring or screen is damaged.
You should problably take it into a camera shop to see if its worth fixing.
Aug 13, 2008 | Canon MV700i Mini DV Digital Camcorder
Dark screen on my video-camera Canon MV700i
I have the same problem, it appears that this camera is one of many cameras that have problems with the CCD (image sensor) have a look at this site for more info www.imaging-resource.com/badccds.html
I hadn't used mine for about 9 months, when I went to use it the screen was black with a bit of flicker. Canon are still fixing them if you're from the UK have a peep here - https://self-service.canon-europe.com/uk/pages/
Hope that helps
Jan 01, 2008 | Canon MV700i Mini DV Digital Camcorder
Blank lcd screen
wires have come off the ccd ! canon will fix free of charge,go to canon support
May 31, 2007 | Canon MV600i Mini DV Digital Camcorder
No image displayed through viewfinder or lcd screen
could be one from a batch with faulty CCDs - check out this fixya link (solution 2) - http://www.fixya.com/support/t115316-canon_mv30 - it's copied from a page at imaging-resource.com - my MV600i was out of warranty and I sent it back to Canon at the end of 2007 and they got it going again free of charge within the week - unfortunately within weeks a very similar fault appeared and now they're trying to charge me for the repair !!! even though they say repairs are under warranty for six months -
May 23, 2007 | Canon MV600i Mini DV Digital Camcorder
No picture in LCD or viewfinder
Flexwire in electronic viewfinder (EVF) is broken, you need pro fix.
May 19, 2007 | Canon GL2 Mini DV Digital Camcorder
Panasonic nv-rz15
ihave problem with my jvc camcorder,firstly the does not go in itself i have to hold the tape after awhile it sits in but when ipush any button to play rewind etc on screen it says that you needto reinsert &safeguuard is on when its no. will the head cleaner solve the problem or shall i take to repair it.please answer as quick possible thank you. Mrs Bahia
Mar 05, 2007 | Panasonic NV-RZ15 VHS-C Analog Camcorder
Cameras Logo
21 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
