Harman Kardon speaker A.C. supply
I found a couple of Harman Kardon 15v. 1.1 amp speakers at a second hand store, but they didn't have the power cord/transformer with them. I thought it would just be a standard size in to the back of the speaker, but even Radio Shack didn't have an adaptor to fit. Do I have to go to Harman Kardon themselves, or is there another way to power these things, or an adapter that would fit?
I have the same problem, did you find a solution?
Thanks
Deb
Posted on Mar 28, 2010
Is it possible repair a power supply of Harman Kardon?
You can certainly try replacing the capacitors, they should have the values written on them, but be aware they are glued/epoxied as well, to reduce vibrations..
My supply has also failed - after verifying that the speakers were otherwise functional (using a 19v supply and 16v regulator, which got pretty hot)), I ordered a new one from ebay for $26 shipped.
Aug 30, 2012 | Harman Kardon SoundSticks Computer...
Harman Kardon SoundSticks II Computer Speakers
Hello
It seems that the power supply section of your speaker systen has the fault. Check the fuse inside it. If it found blown out, never replace an other fuse in place. Check the power supply circuit board for any short circuited components in it, before replacing an other fuse.
Mar 21, 2012 | Harman Kardon SoundSticks II Computer...
What type of power supply is required for this speaker system? If available, how much can I expect to spend for the power supply? I have the speakers but no power supply.
Check the power-connector on the speaker for the rating:
* AC versus DC
* 4.5 versus 5 versus 9 versus 12 versus 18 volts
* 0.5 versus 1.0 versus 1.5 amps
* pole-negative-ring-positive versus pole-positive-ring-negative
Try the local "Thrift Stores", once you have the specifications. You may get the correct suppy for less than $5.
Apr 20, 2011 | Harman Kardon HK595 Computer Speakers
Hi there! I would like to purchase the Harman Kardon Soundsticks II power adapter as I have no clue where to buy it from. Pleasee help me with this. Many Thanks! p.s. The warranty is out.
Do you have a Radio Shack or other consumer electronics store in your part of the world?
If you can find a non-bigbox type of electronics store, take the old power supply in and have them match it (power output and plug type). Good luck.
Mar 06, 2011 | Harman Kardon SoundSticks II Computer...
Need the AC 15V 1.1a power supply
Hi Tracy,
Wow, this was a hard one. I called both Harman Kardon and Dell, seems HK made the speakers for Dell, but neither company carries parts any more. I called Radio Shack thinking they would have a generic power supply, not even close. I looked at several places on the internet and had no luck.
I do have a little good news, I was able to find a few on Ebay, so if you don't mind buying used, you can get a power supply there. They even have a Buy Now offer so you would not have to bid on it. The power supplies are listed as 1100mA which is the same as 1.1A.
Also, if you get the it and the plug in is not the right size, take the speaker to Radio Shack and they will be able to sell you the correct plug, all you will have to do is splice in the new plug. With it having an AC output, you don't even have to worry about the wires being crossed as you would with DC. Hope this helps you.
Here are the links:
http://cgi.ebay.com/Harman-Kardon-A481511OT-15V-1100mA-Black-AC-Adapter_W0QQitemZ190450725250QQcategoryZ79846QQcmdZViewItem
http://compare.ebay.com/like/370463130288?ltyp=AllFixedPriceItemTypes&_dmd=Gallery&var=sbar&rvr_id=189044360544&crlp=1_263602_304692&UA=L*F%3F&GUID=0234523512d0a0b3f8f79f17ff3c9895&itemid=370463130288&ff4=263602_304692
http://cgi.ebay.com/Harman-Kardon-A481511OT-HK-01T-AC-Adapter-15V-1100mA_W0QQitemZ190450725272QQcategoryZ79846QQcmdZViewItem
Dec 23, 2010 | Harman Kardon HK19.5 Computer Speakers
I have a harman/kardon class 2 transformer model# 661520oo3ct. It was with my computer equipment but not hooked up. I don't remember what it was for. what uses does it have?
hi,
it comes with ur desktop speaker harman kardon hk 206. it is a 12v 1A dc power supply. u can use it in any equipment which needs that power rating. only thing to remember is, check the polarity of both before connecting.
ok
Dec 17, 2010 | Harman Kardon HK206 Computer Speakers
Need AC 15V 1.1A power cord for HK195 speakers
Hey, I was in the same situation. I tried a 9V DC (yes DC) converter I had and it works perfect. You can use a DC on a AC input - never the other way around. Due to insufficient power I get distortion at very high volumes... but I never play that high so I'm good..
Oct 07, 2009 | Harman Kardon HK206 Computer Speakers
I need a power source for my HK19.5 computer speakers.
you can order on ebay and they will give u the price on there this is only somewhere to help you fimd what your looking for or if you need help with fixing something
Feb 03, 2009 | Harman Kardon HK19.5 Computer Speakers
Transformer output
the volts are not as important as the amps the amps must be the same
Dec 01, 2007 | Harman Kardon HK19.5 Computer Speakers
558 people viewed this question
 Grubhead
Grubhead
