Question about Brother HL 5250DN Laser Printer
Paper tray not lifting the paper up for the initial paper feeder
I have a Brother ML-5250DN printer. The mechanism in the paper tray that is designed to lift the paper at one so it can feed into the printer no longer lifts the paper. It seems that the spring designed do do this isn't doing it anymore. I have disassembled it and, by design, I don't know how this spring ever developed enough force to lift that mechanism, let alone sy, 100 sheets of paper. Any suggestions?
  • 1 more comment
  • scottjwalton Jan 10, 2009
    Thank you Razor. I made the rear paper stop adjustment per your suggestion. Since I asked my question last night I disassembled and cleaned everything I could. I found some paper jammed way up inside that somehow was still letting the unit print but the finished product would not come out all the way and would get stuck half in/half out. It seems to be working ok now though it "creaks" a lot when it is running. It only has about 11,500 lifetime prints on it but it creaks and is noisy like it were some kind of dinosaur relic or something. Oh well.
    Thanks again Razor!
  • rockhound758 Jan 27, 2009
    I have the same problem as what was described, and I don't see the paper stop having anything to do with it in my case. The little spring/wire that was holding up the paper ramp is not holding it up, and like the original poster said I don't see how it ever did. The paper is therefore not lifted up (spring-driven ramp doesn't lift) and the printer reads as out of paper. Any help would be appreciated...I've taken the tray apart and can't see how the spring wire could have given enough lift in the first place. AND I can't see how a replacement tray could POSSIBLY cost $100+. Again, any help would be great appreciated!
    Larry in Powell, OH
  • downtick May 07, 2009
    Same problem here. It's not a paper jam problem as it prints OK from
    the MP feeder. It seems the paper out sensor is not being moved out of
    the way with paper in the tray. If I insert a rod up through a hole
    in the bottom of the paper tray to lift the paper up to the sensor it
    pulls paper from the tray & prints OK. Is there a spring or gear
    that's not engaging?
  • 215 Answers
Most common problem on these is the rear paper stop pressing too hard against the rear of paper causing paper not to lift. make sure you have about an 1/8" gap.
good luck,
razors
Posted on Jan 09, 2009
  • diywifenmom Dec 07, 2010
    I have the exact same problem as described by the original poster, and it can't be the rear paper stop because the paper-lifter does not rest in the raised position when the tray is empty. It has to be that spring and I cannot figure out how to fix it! Help!
Brother HL-5250DN Laser Printer making noises and not printing
some gears are not in proper position , pull out the paper tray and closed it strongly .
Nov 17, 2009 | Brother HL 5250DN Laser Printer
My Brother 5250DN is not pulling paper through. What could it be?
do a test print... see you manual. You hold a button for 3 seonds and it'll print a test page. If that works you should be OK. Make sure that your paper tray is NOT over loaded. Maybe try less paper. Try the manual feed using one sheet of paper
Oct 27, 2009 | Brother HL 5250DN Laser Printer
Brother hl5250dn laserprinter problem due to no impression.
unistall the printer driver and reinstall it or cheak it,s ink cartrage
Aug 22, 2009 | Brother HL 5250DN Laser Printer
Status light is red and paper light blinking
Alex,
To isolate the problem, please try the steps below:
Remove and re-insert the paper tray and then click Go.
Take the drum unit out of the machine and put it back in.
Here, I provided you a link that might help you:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000070/faq000170_007.html?reg=us&c=us&lang=en&prod=hl5250dn_all
Have a great day!
May 07, 2009 | Brother HL 5250DN Laser Printer
Paper feeding problem
3 possibilites.
1.. the paper pick up rollers are jammed
2. you have a small piece of paper stuck inside
3. pickup roller gearsor solenoid are damaged
Apr 17, 2009 | Brother HL 5250DN Laser Printer
Brother hl 4040cn will not load paper from tray loud clicking noise coming from paper tray on dislplay it says no paper
Remove main tray. Check adjustable paper back stop. If the backstop is set so that the paper sit too tightly in the tray....it will prevent the spring loaded front portion of the tray to lift up allow paper to contact the pickup roller. The clicking sound you hear is the paper lift mechanism trying to push up the paper. Arrange both backstop and sidestops to allow some movement of paper in tray.
Apr 13, 2009 | Brother HL4040CN Laser Printer
WHEN PAPER FEEDS THROUGH PRINTER COMES OUT WRINKLED. HL-5250DN BROTHER PRINTER
Try these - is paper dry?
Are you using good quality (80 gsm minimum) paper?
Are the fuser rollers (open back of printer, pull down inner paper guide using projecting lugs) in good shape?
Is there any paper debris in the paper path either before the laser unit or on the final path (look carefully at the little paper separator fingers) that is impeding the paper run at one side?
Does the bypass tray give good or bad results? - if good, look for paper debris in the initial feed path.
Are any flexible plastic guides pulled out of shape to face back up the paper path - often caused by pulling a misfeed out backwards?
I find that paper scraps in the initial feed path can be impossible to see, so I have a piece of laminated paper to push through the feed path. It often finds bits I couldn't see.
Mar 05, 2009 | Brother HL 5250DN Laser Printer
Feeder wheels are spinning backwards
I see that you have mechanicals problem the doublex maybe faulty
i need from you to tray clean the printer all printer roller and tray to disable the doublex future from the driver try to print and send to me feed pack
Dec 05, 2007 | Brother HL 5250DN Laser Printer
Brother 5250DN printer noise
Check my solution here:
http://www.fixya.com/support/t641678-paper_tray_noise
Here's a solution for you with Brother HL 5250 D/DN/DNT
Change the paper setting tab in the tray to make sure you have a small gap between the top part of the paper and the bottom part.
so if this is the old settings : |paper| --> you want to make it: | paper| so you can have slide the paper back and forth.
DON'T adjust the setting to the next paper size because the roller wont catch the paper if it slide too far.
Good luck to all.
Nov 02, 2007 | Brother HL 5250DN Laser Printer
Brother HL 5250DN Laser Printer Logo
1,689 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
