Question about LG LS-L1210CL Mini Split Air Conditioner
E4 in an innovair a/c
After 30 mins the unit shuts down and blows hot air
  • 659 Answers
It sounds like you have a freon leak and may need a charge. When there is a leak, the compressor will run for awhile but without the proper charge, it will heat up and kick on on thermal overload. After the compressor cools, the unit will come back on. Have the unit serviced by a professional.
Posted on Mar 20, 2009
2 Suggested Answers
InMrFixIt
  • 121 Answers
SOURCE: e4 in an innovair a/c
Hi! jorget67
Sound like the compressor overload is tripped. Make sure the condenser is clean then reset the breaker on this circuit.
Sincerely, InMrFixIt
Posted on Jan 12, 2009
Error code E4 on cold star mini split unit
E4 usually means either blocked capillary, low refrigerant charge, high ambient temperature.
First: check the filters. The front panel opens up like the hood of a car and the filters are fine plastic meshes that you should be able to see through. If you can't see through them that means they are clogged. pull them put and clean them with water only and replace. If the filters are blocked the unit will be unable to refrigerate properly.
Second: check the capillary (water outlet). If the hose is clogged, water usually backs up and sometimes the A/C will start dripping into the room. This also makes cooling defficient. Do NOT try to force water through the hose. Sometimes there is debris in it and you will just make the plug harder to remove. The way to remove it is by sucking the water back, not pushing it forward. A technician should be able to do this for you. The other possibility is that the other end of the "hose" (on the outside) is clogged or under water. Just remove the obstruction.
Third: the ambient temperatre is too high and your BTUs are not sufficient to cool the space. In other words, your A/C is not big enough for the amount of heat/size of the room.
Fourth: have the refrigerant level checked by a qualified technician. They can refill the refrigerant. They have all the tools required.
Mar 20, 2014 | Heating & Cooling
Innovair vexus
i am gettin e9 on my innovair vexus ac unit
May 29, 2013 | Heating & Cooling
2009 Nissan Altima A/C blowing cold for 20 min. then blows hot
if the ac system is very strong and there a lot moisture in the air the a'c evaporator core will freeze up and stop air flow threw the cold core only use the recuiculation part to cool the car down about 5-10 min the turn the recuit off
Aug 22, 2012 | 2009 Nissan Altima
It heats upan i kant play more than 30 mins an wen it heats up its like realy hot idk wats wrong wit it its stop playing da game
Somthing is wrong with you air unit in your system and the reason it is shutting off is because a heating sensor is telling it too.....you gotta fix you air unit or keep a fan on the system while playing it......do not try to disable the heating sensor because the motherboard will blow up
Jul 30, 2009 | Sony Playstation 3 (PS3) Console
My domain air 2.65kw portable ac unit - E4
Make sure the filter is clean and the pump is operating.
Mar 08, 2009 | Heating & Cooling
Check the Capacitor.
Jan 12, 2009 | Heating & Cooling
Comp shuts off
Coils could be dirty. Compressor could be getting too hot and cutting off. Will have one fan motor that turns condenser fan and evaporator blower.
May 30, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
Unit shuts down
The E4 error in display its mean the wire sensor connector to thermostat is loose pls fix , or have a problem in PCB Board on thermostat, pls go to the nearest repairman to repair that.
Thank you,have a nice day
Edgz
Jan 22, 2008 | ACE -Air 18,000BTU Heat Pump A/C Free DVD...
LG LS-L1210CL Mini Split Air Conditioner Logo
936 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
