Question about Whirlpool Duet GHW9150P Front Load Washer
Not draining and spinning
Control panel shows flashing F 02
  • atmaun Jan 12, 2010
    I cleaned the lint filter and its still not spinning for draining
    Sergeant:
    Champion:
  • 262 Answers
F2 IS A LONG DRAIN CYCLE CHECK TO SEE IF THE WASHER IS DRAINING AT THE WALL IF HOW MUCH CHANCES ARE THAT THE LINT FILTER IS STOPPED UP WHICH IS LOCATED BEHIND THE FRONT COVER ON THE PUMP ONCE YOU FIND THE PUMP YOU WILL SE A SLOT THAT LOOKS LIKE A CLEAN OUT WHICH IT IS IT ALSO LOOKS LIKE A HANDLE TURN THIS HANDLE COUNTER CLOCK WISE AND THIS OPENS THE FILTER CLEAN IT AND PUT BACK IN.MAKE SURE YOU HAVE PLENTY OF TOWELS FOR THIS IS WILL GET VERY WET VERY QUICK
Posted on Jan 09, 2009
F 02 flashing on control panel
F/02..
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Oct 21, 2012 | Kenmore HE3T Washer
My whirlpool washer is not spinning all the time then flashes 02 f
Hi, f-02 means long drain. remove panel below door, pump will be in center right in front of you. Remove cap and clean out pump. Make sure you unplug washer first before you start...
Take care
May 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F 02 I reset it to drain and spin for the first load. already took the bottom panel off and cleaned out the white container. still not working for the second load, still flashing F02.
f02 means long drain. something is stopping it from draining. takes the pump out and look in at the impeller, something could be caught in it
Feb 06, 2010 | Kenmore Elite 45986 Front Load Washer
Have error code of f 02 showing up on my duet. It is not finishing spin or drain cycle?
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer will not spin all of the water out after the spin sycle. There is a flashing F2 on the screen.
F/02 = Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Most likely cause is item 1.
  1. Check Screen Filter Assembly for foreign material lint, socks, coins, nails ect. To access the filter remove the lower front panel. The filter (white is located before the pump. Place a pan under the filter and remove it and clean then reassemble.
  2. Check the drain hose and make sure it is not plugged or kinked.
  3. Check the electrical connections at the pump and make sure the pump is running.
  4. If the above does not correct the problem, replace the pump.
Oct 31, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washer flashing 02 F. Maytag epic washer won't spin -flashing 02 F about 15 minutes into the cycle. We just had new electrical components put into it.
You need to use the HE detergent. I believe that is a drain problem. By using the regular detergent that causes more suds and in turn clogs your drain
Jul 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washer won't spin- flashing "f 02"
in the HE3 series it means the drain tube or pump is clogged
Mar 02, 2009 | Kenmore Elite 45986 Front Load Washer
Control panel reads E61 at wash cycle and E66 and drain and spin
Can you tell me what make this machine is? As it sounds like a heater problem??
Dec 28, 2008 | Washing Machines
It stops with 12 minutes left , beeps and shows f 02
f02/ is an indicater of long/clogged drain. did you try removing the access panel(3)screws across bottom of unit, behind the panel youll see a large thumbsrew attached to the drain pump thats probalby clogged, with debris
Apr 09, 2008 | Kenmore Elite 45986 Front Load Washer
Fault problem
F02= LONG DRAIN
off and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
Possible Causes / Procedure
or kinked.
Feb 12, 2008 | KitchenAid KHWS02R Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
209 people viewed this question
Dan Webster
Dan Webster
Sal De
