Question about Sony Playstation 3 (PS3) Console
My PS3 is constantly flashing a black screen. It happens at various times and may last for up to 3 seconds at a time. The pace is hard to determine. I've switched the hdmi cords several times with no solution. Do i need to send it back or is there a solution?
  • Anonymous Jan 31, 2009
    yep
  • Stephen Munn
    Stephen Munn May 11, 2010
    If this is not happening in the middle of a game, this could be a situation where your PS3 and TV are not agreeing with each other in terms of resolution. Make sure you don't have any resolutions set in your PS3's video options that cannot be displayed on your TV. Mine, for example, will do 1080i, but will not do 720p.
    If it is happening all the time, regardless of what the PS3 is doing, it's probably something wrong with your PS3. You might consider exchanging it for a new one. Good luck!
If you are sure it is not the cords then return the system or contact sony
Posted on Jan 09, 2009
After click on the game title. screen goes black
It is normal for the screen to go black for a couple of seconds once you click on the game title.
Although, for some games, the screen goes black for a longer period of time than other games. Another important factor that determines for how long the screen goes black is the health of your disc.
First of all, it is advised that you exercise patience and wait for a couple of minutes before trying anything. During this period of time, the game is trying to load all the necessary files required to run the game.
On the other hand, if the disc you are trying to play is not very clear or has scratches on its surface, this could make the game go on a black screen for longer than normal. So to prevent this from happening, make sure that the surface of our disc is very clean and is free from dust or scratches.
If you wait for about 5 minutes and it still doesn't work, then you can try ejecting the disc to see if it automatically quits the game and returns to the home screen. If it does, this means that the disc is probably bad and you are advised not to try loading it anymore as it could cause damage to your console.
Although you can try resetting the console if it still behaves this way before you confirm that the disc is bad. Below is the instruction oh how to do this.
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Hope this was helpful? Please comment for more information and thank you for using Fixya.
Mar 08, 2011 | Sony Playstation 3 (PS3) Console
PS3 press front on button goes green for a couple of seconds then goes to constant red. The red then stars flashing constant This happens on start up from cold
you are getting Red screen While using your ps3 and nothing else Right .................
if so then dont worry you can fix this easily with the help of repair guide available in net ....... you can download it and solve your problem its a big process but if you do correctly according to the guide then you can fix this....... All the best
Click here to download repair guide
Dec 13, 2010 | Sony Playstation 3 (PS3) Console
I yes when i put ps3 on console is fine but the screen stays black everything else ok
Try a soft video reset:
While the PS3 is OFF (solid red led in front)
Hold down the power button until you hear the SECOND BEEP, quickly release.
Screen should flash and you should get video afterwards.
Let me know what happens.
Oct 23, 2010 | Sony Playstation 3 (PS3) Console
A problem has occurred the last time the ps3 system was last used, and the system did not turn off correctly. after that thing pops up after i turn it on i press yes send to ps3 place and then it sends in...
Try a video reset first.
While the PS3 is off (red led)
Hold down the power button until you hear the second beep, quickly release.
Let me know if that solves your problem otherwise it's a corrupt file system.
Nov 20, 2009 | Sony Playstation 3 (PS3) Console
Flashing black and white vertical lines
Vertical lines in the display indicate a failing screen. New screens are expensive and not worth the labor and parts charges to repair it. It's new monitor time.
Jul 28, 2017 | Samsung LTN1535 15 in. HD-Ready LCD...
Screen goes black after windows XP logo, then no response.
I would suggest checking your hard drive to see whether or not it has a bad sector on it.
Dec 20, 2008 | HP Pavilion zd8000 Notebook
PS 3 Screen goes black
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like No Display Problme. You may check out the informative blog post at PS3 Repairs blog
Hope it helps to fix the problem.
Aug 31, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
77 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
