Question about Envision EN-7100e 17" Flat Panel LCD Monitor
My Envision 7100 Stop Working
My Envision 7100 stopped working on any monitor. Even power connects to the monitor with green power light on. I have no clue at all. Who can fix this?
  • ablais Apr 01, 2009
    Green power light always on. None of the buttons work--even power (always on). Plug it into a PC --- nothing happens. Help.
  • Anonymous Apr 09, 2009
    I have the same problem, except that for some unknown reason, the monitor works properly at times. Still has buttons not working.
    President:
  • 814 Answers
These are all some component failure problem in the monitor circuits. This may have been caused by faulty components or overheating of the components causing intermittent or permanent failure of some components in the circuits.This causes the feedback circuits to sense incorrect voltages or currents in the circuits and turn on the protection circuit. It may also cause total failure of the power supply circuit and a loss of power to the monitor. These units should be returned to dealers for servicing. Hope this helps you .
Posted on Apr 14, 2009
Hello when I turn on my monitor and computer this morning I have a black screen on my envision monitor and the green light keeps blinking do you know how to fix this
Unplug everything from the tower. Including power cord.
Press the power button for 5 secs.
Proceed to connect, power line, mouse, keyboard and monitor
That should reset the power or hibernation mode that you might have issues.
If everything looks normal, proceed to connect your remaining devices.
You must be aware that having a BIOS settings to boot from USB, DVD or USB-FLOPPY might prevent to boot into windows.
Feb 24, 2015 | Envision Computers & Internet
Envision en-7500 won't power on
The problem is in the power supply board, at least one capacitor is open, sometimes will bulge at the top making it easier to spot.
Jun 10, 2012 | MPC Computers Envision EN 7500 17" Flat...
I have an Envision 7100 Monitor. Before going on vacation 2 weeks ago it was operating perfectly when connected to my Hewlett Packard PC. However, on my return the monitor screen remains blank (dark)...
The power supply may have become unstable due to bad DC filter caps, the power supply is always running 24/7 even when the power switch is OFF.
Look for bad cpas with domed tops.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Mar 22, 2011 | Envision Computers & Internet
My monitor will not work it is flashing a green light on the led indicator
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ENVISION monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
May 20, 2010 | Envision EN7410 17" LCD Monitor
My Envision H22w Monitor has a green light that is blinking but is not working. IT was working earlier but just went off.
mine just did this tonight. envision has a 3 year warranty and mine was within that so i am rma'ing it.
Sep 29, 2009 | Envision H22W 22" Monitor
Envision Monitor 22", when plug in the power core, the Green power light would blink repeatedly non stop. Screen would show nothing just a blank screen... it a one year old monitor, and was working fine...
Hi, when connected to a portable you sometime must hold function key then press F5 or F6 to switch between the portable screen and the aux monitor, have you tried the monitor with another computer. If this does not work, it might require internal repairs...
Aug 13, 2009 | Computers & Internet
Won't turn on
This is a problem with either the power supply or or logic circuit. It could also be caused by a failure in the back light circuits. One of these problems has caused the power supply to go into protection mode and will not turn on due to bad voltages sensed in the feedback circuits. Return to dealer for service. Hope this helps you .
Dec 26, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Envision EN7410e monitor
hi this is jannet and am expert to solve your issues kindly call us to this numaber +1(518)348-9393
Oct 06, 2017 | Computers & Internet
Just fixed mine. Maybe it's a few years late. Hope you guys still have the display. It's the power supply board. I've just replaced 4 bulge capacitors near one edge of the PS. They are 2x1000uF 10V, 1x470uF 25V & 1x470 10V. I salvaged my parts from an old CRT monitor. Hey you can go green with your repairs too!
Apr 25, 2008 | Envision EN7410 17" LCD Monitor
ENVISION EN-985E MONITOR PROBLEM
When using this monitor on a PC running Windows Vista Home Premium the screen text is blurry and hard to read . I have tried working with the Clear Type in Vista and that does not help . I have reloaded the driver for this monitor and this did not help either . Any suggestions ?
Steve
Dec 05, 2007 | Envision EN-985e Monitor
Envision EN-7100e 17" Flat Panel LCD Monitor Logo
257 people viewed this question
Top Envision Computers & Internet Experts
Cleverer2
Steve
Martin Murray
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
