Question about Gateway 3522GZ Notebook
Blue screen with an internal malfunction...
I have a Gateway laptop and the model is 3522GZ i recently started experiencing problem with it, a blue screen would appear stating it ran into an internal problem and would suggest uninstalling any new devices but i barely have any new programs on it. The message would read " if this is the first time experiencing this problem then restart and press F8 to select the safe mode" but the advanced set-up box will not appear and the blue screen is happening more often, any help you can provide is greatly appreciated. Nima
    Problem Solver:
  • 14 Answers
Sounds like you have a virus. Run your virus scan.
Let me know if your problem is solved and rate me as FIXYA!
Posted on Jan 09, 2009
3522gz connection problem
Connecting to or from what?
May 12, 2014 | Gateway 3522GZ Notebook
Acer blue screen with warning
Please tell us the FULL brand number and model number of your Acer computer. Then tell us the happenings from the time you turn on the laptop until the blue screen shows. Then tell us what the blue screen warning says.
Aug 28, 2013 | Acer Aspire One 521 532H 533 D260 NAV50...
Gateway 3522 laptop won't boot up
HDD problem, try to fix boot record and test HDD with Hierens Boot CD
Nov 13, 2012 | Gateway 3522GZ Notebook
Gateway laptop blue screen ID58
Contact resistance problem probably near the lcd screen. connector for flexible circuit may need eraser cleaning and reconnect.
Mar 08, 2012 | Gateway Computers & Internet
Battery of my laptop Gateway 3522gz is not being detected. Please advise.
THERE IS A HIGH POSSIBILITY THAT YOUR BATTERY IS DAMAGED.... TRY GETTING YOUR NOTEBOOK TO AUTHORIZED CENTER
Mar 08, 2011 | Gateway 3522GZ Notebook
My Gateway MT6705 seems to power on because the blue light will come on and I will here the cd rom spin for a second and sometimes the fan but the screen never lights up and it seems like the laptop is...
1. Your pc have a bad LCD and will have to serviced
2. If the blue light is the indication of proper "on" status then you have a malfunction
in the video/LCD
I am not sure of the repair cost but a qualified tech can determine this.
3. Check if you have inadvertently turn your brightness down or put the laptop in sleep
mode.
IF you have dropped the laptop you could have disconnected the video cable that go to
the LCD screen
Oct 07, 2010 | Gateway MT6705 Notebook
***STOP OXOOOOCIFS(OXOOOOOOOO,OXOOOOOOOO,OXOOOOOOOO,OXOOOOOOOO)ON A BLUE SCREEN,CAN I CURE THIS?
The first step is to determine whether your computer is getting a blue screen because of an internal program problem or a hardware malfunction. 80% of the time, blue screens are caused by internal issues,
The most common symptoms or signs of a hardware issue is a pattern of consistent behavior leading up to the blue screen crash. In the case of an over heating problem, you likely would notice that your fan in your computer was running more often - or not at all. This would likely also come with an increasingly repetitive crash cycle. For example, your system shuts down 10 minutes after you turn it on regardless of what you are doing. Also, if you have recently installed something new on your system like more memory or a new hard drive / web cam or other actual physical device, try taking it out and see if that fixes the problem.
Dec 23, 2009 | Acer Aspire 5500 5570-2609 Laptop
Gateway laptop 3522gz display went "dark" after 2 years.
It sounds like LCD backlight problem. Bring your laptop to a repair shop.
Dec 04, 2008 | Gateway 3522GZ Notebook
Gateway 3522GZ display
Some searching on forums convinced me the inverter had failed. Picked one up for $65, removed the frame around the screen, removed the mounting screw for the inverter, and unplugged both ends of the old and plugged in the new. Put it back togeher and fired it up, bright again. Key here was that a remote monitor still worked which meant video card was OK. The lamp could have been bad, but apparently the life of lamps is pretty decent.
Aug 31, 2008 | Gateway 3522GZ Notebook
Gateway 3522GZ Notebook Logo
120 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
