1997 Dodge Intrepid Logo
Posted on Jan 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oil return blocked?
Pulled socket ou of front right slot on 3.5 dodge. was covered with oil up 1+1/2 inches. stoped and left plug in.
This was the only plug to do that. If return blocked,how do I unblock(old way was a coathanger) the last time I did this to an old car. not brave enough to try this on this car before asking
Anonymous
Level 3:
President:
  • Master 2,559 Answers
  • Posted on Jan 09, 2009
Anonymous
Master
Level 3:
President:
Answers
2559
Questions
Helped
1213588
Points
9283
Oil around plug boot on that car is due to leaking valve cover seals.If you remove the valve cover,you will see big O rings that go around each of the plug holes,Just replace valve cover gasket set and problem should be solved.While you have it off,tou can look at the return for obstructions.
2014 dodge journey sxt 3.6 timing chain diagram
/* override srp image link color and background color */ .galleryImage { background-color: #002F56; color: rgb(0, 47, 86); } Fig. 1 Front cover pry pointsFig. 2 No. 1 piston TDC positionFig. 3 No. 1 piston TDC alignmentFig. 4 Camshaft TDC alignmentFig. 5 Timing chain alignmentFig. 6 Lefthand cam phaser alignmentFig. 7 Timing chain alignment marksFig. 8 Upper intake manifold tightening sequenceFig. 9 Valve cover tightening sequence. LefthandFig. 10 Valve cover tightening sequence. Righthand Print Options Print Text Only Print Text and images Print Timing Chain, Replace Caution: The magnetic timing wheels must not come in contact with magnets or any other strong magnetic field. This will destroy the timing wheels ability to correctly relay camshaft position to camshaft position sensor. 1. Disconnect battery ground cable. 2. Remove air cleaner housing assembly. 3. Remove upper intake manifold. 4. Remove valve covers. 5. Remove spark plugs, then raise and support vehicle. 6. Drain cooling system into suitable container. 7. Remove upper and lower oil pans. 8. Remove righthand engine mount bracket. 9. Remove bolts from front cover. 10. Carefully remove front cover by carefully prying at seven indicated points, Fig. 1. 11. Rotate crankshaft counterclockwise to place No. 1 position at TDC on exhaust stroke by aligning dimple on crankshaft with block/bearing junction, Fig. 2. Lefthand side cam phaser arrows should point toward each other and be parallel to valve cover sealing surface. 12. Mark rotation direction of following timing chains for reference during installation: a. Lefthand side cam chain. b. Righthand side cam chain. c. Oil pump chain. d. Primary chain. 13. Reset righthand cam chain tensioner by pushing back tensioner piston and installing tensioner pin tool No. 8514, or equivalent. 14. Reset lefthand cam chain tensioner by lifting pawl, pushing back piston and installing tensioner pin tool No. 8514, or equivalent. 15. Disengage oil pump chain tensioner spring from dowel pin, then remove oil pump chain tensioner. 16. Remove oil pump sprocket T45 retaining bolt, then remove oil pump sprocket and oil pump chain. 17. Install righthand camshaft phaser lock tool No. 10202, or equivalent. Minor rotation may be required to install camshaft phaser lock. 18. Loosen both intake oil control valves, then exhaust oil control valve. 19. Remove righthand camshaft phaser lock tool, then oil control valve from righthand side intake cam phaser. 20. Pull righthand side intake cam phaser off of camshaft, then remove righthand side cam chain. 21. Remove oil control valve, then pull righthand side exhaust cam phaser off camshaft. 22. Install lefthand camshaft phaser lock tool No. 10202, or equivalent. Minor rotation may be required to install camshaft phaser lock. 23. Loosen both intake oil control valve and exhaust oil control valve. 24. Remove lefthand camshaft phaser lock tool, then oil control valve from lefthand side exhaust cam phaser. 25. Pull lefthand side exhaust cam phaser off of camshaft, then remove lefthand side cam chain. 26. Remove oil control valve, then pull lefthand side intake cam phaser off of camshaft. 27. Reset primary chain tensioner by pushing back tensioner piston and installing tensioner pin tool No. 8514, or equivalent. Remove two T30 bolts, then primary chain tensioner. 28. Remove timing chain. 29. Reverse procedure to install, note following: a. Verify No. 1 piston is positioned at TDC by aligning dimple on crankshaft with block/bearing cap junction, Fig. 3. b. Verify camshafts are set at TDC by positioning alignment holes vertically, Fig. 4. c. Ensure timing chain plated link is located at 12 o'clock when dimple on crankshaft is aligned with block/bearing cap junction, Fig. 5. d. Position lefthand side cam phasers so that arrows point toward each other and are parallel to valve cover sealing surface, Fig. 6. e. Torque idler sprocket bolt to 18 ft. lbs. f. Torque oil control valve to 110 ft. lbs. g. Torque oil pump sprocket bolt to 18 ft. lbs. h. Ensure there are 12 chain pins between exhaust cam phaser triangle marking and intake cam phaser circle marking, Fig. 7. i. Torque upper intake manifold bolts to 80 inch lbs., in sequence, as illustrated in Fig. 8. j. Torque lefthand valve cover bolts in sequence, as illustrated in Fig. 9, to 106 inch lbs. k. Torque righthand valve cover bolts in sequence, as illustrated in Fig. 10, to 106 inch lbs. l. Torque timing chain tensioner to 106 inch lbs. m. Torque timing chain guide to 106 inch lbs.
Print - As Shown Print - Fit To Page / 1
  • Fig. 1 Front cover pry points
  • Fig. 2 No. 1 piston TDC position
  • Fig. 3 No. 1 piston TDC alignment
  • Fig. 4 Camshaft TDC alignment
  • Fig. 5 Timing chain alignment
  • Fig. 6 Lefthand cam phaser alignment
  • Fig. 7 Timing chain alignment marks
  • Fig. 8 Upper intake manifold tightening sequence
  • Fig. 9 Valve cover tightening sequence. Lefthand
  • Fig. 10 Valve cover tightening sequence. Righthand
How to change headlight on 2000 galant
  • 1
    Place the Mitsubishi on a flat service in park. Set the parking brake before continuing.
  • 2Open the Galant's hood and locate the headlight cover -- roughly 3-inch wide circular piece of plastic -- behind the headlight bulb intended for replacement. Turn this cover clockwise to unlock it and pull it from the headlight assembly, exposing the headlight socket below it.
    Hold the rear of the headlight socket and turn it counterclockwise to unlock it. Pull the headlight socket and bulb from the headlight assembly.
    Grab the bulb and pull it from the socket with a slight wiggling motion.
    5
    Pick up the new 9003 headlight bulb using a clean, lint-free cloth and line up its prong with the slots in the socket. Never tough the bulb with your bare hands, as the oils left by your hands can cause the bulb to burn out prematurely.
    6
    Slide the socket and new bulb into the headlight assembly and turn the socket clockwise to lock it into place.
    7
    Place the plastic cover behind the bulb and turn it counterclockwise to lock it into place.
    8
    Repeat Steps 1 through 7 for the headlight bulb on the other side of the Galant, if needed.
    9Close the Galant's hood.
    Read more: How to Put in a Headlight Bulb on a 2000 Mitsubishi Galant ' eHow.com http://www.ehow.com/how_8210819_put-bulb-2000-mitsubishi-galant.html#ixzz27iQwCdOe
    How do you remove timing cover on a 2001 dodge durango 5.9
    this thing, has a lot things to do. a certified technicians only can do the job. but if you wanna do it alone, here are some instruction(s) after removing the parts to have acces on it.
    1. Remove the crankshaft pulley using the appropriate socket.
    2. Remove the harmonic balancer using the harmonic balancer puller.
    3. Loosen the oil pan bolts.
    4. Remove the front two oil pan bolts--one on each side of the crankshaft--these two bolts help hold the timing cover in place.
    4. Remove the timing cover bolts using the appropriate socket.
    5.Pull the cover off the block.
    6.Remove the seal from the timing cover using a seal puller(if it is your problem).
    7. Clean the gasket mounting surfaces on the engine and timing cover with the scraper.
    8. Smear a thin layer of silicone on the timing cover's gasket mounting surface.
    9. Fit the gasket on the timing cover.
    10. Install the timing cover and tighten the bolts to it's specified torque.
    11. Reinstall the two oil pan bolts and tighten them to it's specified torque.
    12. Reinstall the accessories in reverse order of removal.
    1helpful
    93 accord timing belt installation
    • Car jack
    • Jack stands
    • Torque wrench
    • Chain wrench
    • 3/8 inch drive ratchet
    • 1/2 inch drive ratchet
    • 10 mm wrench
    • 12 mm wrench
    • 10 mm socket (3/8 inch)
    • 14 mm socket (3/8 inch)
    • 17 mm socket (1/2 inch)
    • 19 mm socket (1/2 inch)
    • Timing belt
    • Balancer belt
    • Bottle of Liquid Paper
  • Disconnect the negative battery terminal. Using a ½-inch-drive ratchet and the 19 mm socket, turn the center bolt on the crankshaft so that number-one cylinder piston is at top dead center (TDC). You will know you ware at TDC when the mark on the crank is in alignment with the arrow on the timing cover.
  • Disconnect the cruise control connector and remove the cruise control actuator. Loosen the upper mounting bolt with the 14 mm socket. Use a 12 mm socket to loosen the lower nut then use a 10 mm socket to loosen the adjuster from the power steering pump and remove the belt.
  • Loosen the upper air conditioner mounting bolt using the 14 mm socket. Use the 12 mm socket to loosen the lower nut and adjusting bolt on the alternator and remove the alternator/AC belt. Remove the valve cover using a 10 mm socket.
  • Place the jack behind the left front wheel where the arrow is located indicating the jack location, and raise the vehicle. Put the jack stand under the subframe behind the jack, then lower the jack. Remove the left front wheel for easy access to the crank pulley. Using a block of wood atop the jack, place the jack under the oil pan and lift with slight pressure to hold the engine in place. Remove the side engine mount using a 17 mm deep socket.
  • Take off the dipstick, pipe tube and upper timing cover using a 10 mm socket.
    Then remove the timing belt adjuster rubber seal without loosening the adjuster nut. Take off the crankshaft pulley bolt. Use the chain wrench to hold the the crankshaft pulley while turning the crankshaft pulley bolt with a 19 mm socket. Use the 10 mm wrench and 10 mm socket to remove the bolts on the lower cover. Remove the lower cover and mark the location of the cam, crank and balancer shaft with Liquid Paper. Remove the balancer shaft belt and timing belt. Install the timing belt and the balancer shaft belt in the reverse order of removing them. During Installation of the crank pulley, coat the threads of the crank pulley bolt with engine oil and tighten it to 159 foot-pounds. Finally, adjust the tension of the power steering and alternator belts as well.
    My 2001 jeep grand Cherokee will not start don?t know why no codes are coming up put new cam sen, crank sen, coil pack, new ecu, new coolant temp sen, it turns over but will not run has injector pulse and...
    Timing Chain, Sprockets, Front Cover and Seal REMOVAL & INSTALLATION 2.5L and 4.0L Engines
    1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
    2. Remove or disconnect the following:
      • Negative battery cable
      • Accessory drive belt
      • Cooling fan and shroud
      • Crankshaft damper
      • Front crankshaft seal
      • Accessory brackets
      • Front cover
      • Oil slinger
    3. Rotate the crankshaft so that the timing marks are aligned. Fig. 1: Timing chain alignment marks — 2.5L and 4.0L engines 7924pg20.gif
    4. Remove the timing chain and sprockets. To install:
    5. For 2.5L engines, turn the timing chain tensioner lever to the unlock (down) position. Pull the tensioner block toward the tensioner lever to compress the spring. Hold the block and turn the tensioner lever to the lock (up) position. Fig. 2: Timing chain tensioner — 2.5L engines 7924pg19.gif
    6. Install the timing chain and sprockets with the timing marks aligned. Tighten the camshaft sprocket bolt to 80 ft. lbs. (108 Nm) for 2.5L engines or to 50 ft. lbs. (68 Nm) for 4.0L engines.
    7. For 2.5L engines, release the timing chain tensioner.
    8. Install or connect the following:
      • Oil slinger
      • New front crankshaft seal to the front cover
      • Front cover, using a new gasket
      • Timing Case Cover Alignment and Seal Installation Tool 6139 in the crankshaft opening to center the front cover Fig. 3: Timing Case Cover Alignment and Seal Installation Tool 6139 — 2.5L and 4.0L engines 7924pg21.gif
    9. Tighten the front cover bolts as follows:
      1. Step 1: Cover-to-block 1⁄4 inch bolts to 60 inch lbs. (7 Nm)
      2. Step 2: Cover-to-block 5⁄16 inch bolts to 16 ft. lbs. (22 Nm)
      3. Step 3: Oil pan-to-cover 1⁄4 inch bolts to 85 inch lbs. (9.5 Nm)
      4. Step 4: Oil pan-to-cover 5⁄16 inch bolts to 11 ft. lbs. (15 Nm)
    10. Install or connect the following:
      • Crankshaft damper. Tighten the bolt to 80 ft. lbs. (108 Nm).
    11. Start the engine and check for leaks.
    2helpful
    2answers
    Firing order for 1990 dodge dakota 4x4 318 cu. in.
    For the 1990 Dodge Dakota 318 cubic inch = 5.2L
    Firing Order:
    1-8-4-3-6-5-7-2
    Cylinders:
    ..........(back)...........
    |...8...|..........|...7...|
    |...6...|..........|...5...|
    |...4...|..........|...3...|
    |...2...|..........|...1...|
    ..........(front)
    Distributor:
    ............3
    ....4..............6...
    .......................(+)-screw: rounded-end of Cap
    8......................5
    (+)-screw: square end of Cap
    .....1...............7
    ..............2
    .........(front)
    Rotation: Clockwise
    Let me know if this helped, or if you have additional information questions. Feel Free to contact me at FixYa.com!
    2helpful
    2answers
    Need diagram for firing order to a 2000 Dodge Durango Magnum,4.7
    I apologize for the late response...Due to the bad economic situation this site has had a substantial (+50%) increase in the number of questions being asked in the last four months.
    For the 4.7L:
    Firing Order:
    1-8-4-3-6-5-7-2
    Cylinders:
    8----------7
    6----------5
    4----------3
    2----------1
    (Front of Vehicle)
    Let me know if this helped, or if you have additional information or questions. Feel free to contact me at FixYa.com!
    3helpful
    2answers
    How do I change the rear and front Differential fluid?
    There is a drain plug on some vehicles at the bottom side of the differential that must be removed to drain the old oil out but on others you must remove the cover which has at least ten bolts that are in a circle pattern around the differential cover. After removing the cover and draining the old oil out dry out the excess oil left inside the casing with a clean rag, scrape off any old gasket material on both the differential casing and the cover. Purchase a gasket for the cover and reinstall the cover tightening the bolts in a criss cross or X pattern not too tight . Proceed to locate the filler plug on the upper right or left side of the differential, this plug is usually removed with the square end of a 3/8" socket wrench just using the square end of the socket wrench should do it or you may need a large hex head allen wrench but usually using a short extention with the socket wrench to get the clearance to turn the square end of the extention or socket wrench inside the plug will work, some times the plug is very tight and you may need to use a 1/2' drive socket wrench with a 1/2" to 3/8" reducer or adapter to acheive the neccessary torque required to crack the filler plug free, now get a coulple of 80/90 weight gear oil quarts and cut the filler tip back a bit with a razor or utility knife and using a 3/8" length of rubber hose slide it over the end of the tip tighten a small hose clamp on to the hose to prevent it from sliding off the filler tip, then feed the end of the hose into the filler hole on the differential and invert and sqeeze the container of oil to force the oil into the differential until it fills and over flows out the filler hole, screw in the filler plug and tighten. Use this general procedure for both the front and back differentials.
    22helpful
    2answers
    How to change front blower motor in a 2003 dodge caravan
    Removal & Installation
    CAUTION The Supplemental Inflatable Restraint (SIR) system must be disarmed before removing the blower motor assembly. Failure to do so may cause accidental deployment of the air bag, resulting in unnecessary SIR system repairs and/or personal injury.
    1. Disconnect and isolate the negative battery cable, then wait 2 minutes before proceeding with the removal. This will effectively disable the air bag system preventing possible personal injury.
    2. Remove the glove box from the instrument panel
    The blower motor is located behind the glovebox, behind the blower motor cover
    1. Remove the A/C-heater blower motor cover.
    2. Disconnect the blower motor wiring connector.
    3. Remove the blower motor wiring grommet and feed the wiring through the blower motor housing.
    4. Remove the blower motor mounting screws.
    Once the cover is removed, unplug the electrical connector and push it through the opening in the housing
    The blower motor is secured to the housing with three small screws
    1. Allow the blower motor assembly to drop downward to clear the instrument panel and remove from vehicle.
    To install:
    1. Place the blower motor assembly into position on the A/C-heater unit and tighten the mounting screws.
    2. Route the blower motor wiring through the blower motor housing and seat the wiring grommet in the hole of the blower motor housing.
    3. Reconnect the blower motor electrical connector.
    4. Install the A/C-heater blower motor cover.
    5. Install the glove box into the instrument panel.
    6. Reconnect the negative battery cable. Check blower motor operation.
    2answers
    PCV valve location
    if i know what you are asking, look at where you put your oil in. on the valve cover to the top right should be a plug with a tubeing runs to your air clear tube where the air mass sensor and carb is located. i think that is what you are looking for.
    Top Dodge Experts
    ZJ Limited
    ZJ Limited
    Thomas Perkins
    Thomas Perkins
    Arnie Burke
    Arnie Burke
    Are you a Dodge Expert? Answer questions, earn points and help others
