Question about Sony KP-57HW40 57" Rear Projection Television
Dull colors I have a Sony 57 inch widescreen Projection TV. Model number is KP-57HW40. The set is maybe 5 years old. About 4 months ago I noticed that the colors were no longer "vivid", instead they were dull. I didnt adjust anything. It just happened. I don't want to spend too much money in order to get it repaired since the price of flat screen TV's is low, yet I'm willing to spend a couple hundred bucks to get it working the way it used to. I imagine that if i get someone over the house to repair it they'll want 100 bucks before they even walk in the door. I do have some technical competence. Is this something that I should attempt to repair myself provided i have the right servicce manual?
  • raymille Jan 16, 2009
    WOW!! Thanks alot. When I removed the back cover and inspected the lenses i knew right then and there your suggestion was spot on. The lenses were covered with dust, and I don't mean just a little bit either. I used the right tools to do the job and in 5 minutes I had my old picture back. Again, thank you!!!
Remove the back panel and the inside panel which slides out on a track so you can get to the 3 crt lenses. Clean the dust off of the lenses with a soft lint free cloth, such as a camera lens cloth. You should be able to find one at a camera store or Radio Shack. Clean with a safe glass cleaner NOT WINDEX. Be sure not to scratch the lenses.
Posted on Jan 15, 2009
I have a Sony Color Rear Video Projector Model KP-57HW40. Its blue color is not working anymore and noticed some burn smell by the set which controls such blue color.
It may be the CRT drive board which is attached to the bottom of the Blue CRT. I would check that Board for signs of being burnt it may need to be replaced.
Jul 08, 2011 | Sony KP-57HW40 57" Rear Projection...
Sony kp-57hw40 double picture. regular and the other right next to it is red. tried auto focus and nothing happens. while holding auto focus btton down get red cross and white next to it. tv is 9 years...
Auto Focus button no longer work.Tv have a problems known as a convergence problems,it dead.Tv have colors lnes R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergnce board to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 13, 2010 | Sony KP-57HW40 57" Rear Projection...
Sony Projector Color Display
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Sony KP-57HW40 57" Rear Projection...
My sony kp-57hw40 projection tv picture is not as bright as usual. There is blue arc lines that show up at the bottom of the screen.
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Feb 07, 2010 | Sony KP-57HW40 57" Rear Projection...
Picture turns green ,usually within 10 minutes of turning it on.It will sometimes go back to normal color but generally returns to green.This happened when the set was much newer and Sony replaced all...
Green Tube maybe trying to short out or you can try adjusting screen drive to the Green Tube by turning control down a notch, Sony had a bad run on these with alot of Bad Tubes.
Dec 08, 2009 | Sony KP-57HW40 57" Rear Projection...
Sony projection tv 5 years old
you will need to call an electronic repair shop to get this problem resolved
Oct 30, 2008 | Sony KP-57WV700 57" Rear Projection HDTV
SONY 57' HDTV color projection TV, red color dominance on-screen
these tv's have a problem with bad crt's you could try to replace the red but a better choice would be all three
Oct 22, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony rear projection tv
Bad green crt, this set has a problem with bad crt's
Oct 13, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
128 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
